Camera mount rasp pi
InfiniteGinger
Post by InfiniteGinger » Tue Apr 04, 2017 8:00 pm
hey there!
Looking for camera mount suggestions for my taz6. been using this one http://www.thingiverse.com/thing:2125257 and I loved it until I installed my dual tool head...Now not so much haha. What mounts are you using?
kmanley57
Re: Camera mount rasp pi
Post by kmanley57 » Wed Apr 05, 2017 6:31 am
I have this one currently, but I have not tried the dual head with it yet.
http://www.thingiverse.com/thing:1570968
InfiniteGinger
Post by InfiniteGinger » Wed Apr 05, 2017 8:49 pm
kmanley57 wrote:I have this one currently, but I have not tried the dual head with it yet.
Thanks! i'll give it a try. I like the velcro
kcchen_00
Post by kcchen_00 » Thu Apr 06, 2017 1:43 am
Here's my contribution to this cause. https://www.thingiverse.com/thing:949219
The mount portion slides onto the aluminum bed. It requires at least one M3 x 5mm screw to secure the pivot in the position you want. I made accommodations for M3 screws and nuts to secure the mount to the aluminum plate... but I found that the mount slides onto the plate and is fairly secure.
You'll need a longer raspi cam flat cable so it moves freely with the bed. I started using a USB webcam (Logitec C270) to get a longer cable to reach my Pi.
Printer needs to well tuned for the Print-in-Place mount... if you have problems, try reducing the flow rate / multiplier. This should create the clearances between parts to allow the GoPro portion of the mount to rotate.
Lastly, I'm using a multi-section post vs the single post. The articulation from the two sections accommodates the extra space the dual extruder needs.
Hope that helps... lots of choices out on Thingiverse.
