Flexible shaft drive bondtech gear extruder anyone?
piercet
Contact:
Post by piercet » Sat Mar 31, 2018 11:26 pm
My new toy:
The NovaPro Mk II Flex cable edition is a remote drive extruder using a 40:1 gear ratio main drive with a Bondtech gear 3:1 final drive. It will be driven by a gantry mounted NEMA 17 moons motor mounted up near the filament pivot. A dual extruder variant is in the works.
koniglar
Re: Flexible shaft drive bondtech gear extruder anyone?
Post by koniglar » Mon Apr 02, 2018 8:02 am
Very cool!
Subscribed to keep an eye on this.
inventabuild
Post by inventabuild » Wed Aug 15, 2018 8:06 pm
Neat, I'm looking forward to seeing the dual extruder version.
OutcastZeroOne
Post by OutcastZeroOne » Thu Aug 16, 2018 7:51 pm
So it’s a Zesty Nimble with bondtech gears
piercet
Contact:
Post by piercet » Thu Sep 06, 2018 7:48 pm
An open source zesty nimble with a complete build at home parts list once I'm done with an existant taz mount and bondtech gears.
piercet
Contact:
Post by piercet » Thu Sep 06, 2018 7:49 pm
Motor mount now exists. This one goes with my backbrace mod. There will be a dual motor mount variant and a conventional 90 degree mount once I get further along in testing.
next up, the motor end of the cable cover holder thing.
piercet
Contact:
Post by piercet » Mon Sep 10, 2018 11:29 pm
Now the motor mount and support bits exist. Next up, extruder mounts then testing on the taz
koniglar
Post by koniglar » Wed Sep 12, 2018 2:13 pm
Looking good!
piercet
Contact:
Post by piercet » Sat Dec 01, 2018 2:24 am
Ok, this has progressed to the point where its probably time to have others start looking at it. Many files incoming.
Novapro_III_flex__motor_mount_spring_guide_hat_1_0_a.stl
(404.67 KiB) Downloaded 17 times
Novapro_III_flex_Motor_mount_coupler_housing_1_0_a.stl
(426.45 KiB) Downloaded 17 times
Novapro_III_flex_Taz_6_style_mount_1_0_a.stl
(278.79 KiB) Downloaded 14 times
Novapro_III_flex_Fan_extension_1_0_a.stl
(81.53 KiB) Downloaded 13 times
Novapro_III_flex_Fan_housing_0_5_f.stl
(109.46 KiB) Downloaded 10 times
Novapro_III_flex_Cable_anchor_0_8_f.stl
(202.72 KiB) Downloaded 14 times
piercet
Contact:
Post by piercet » Sat Dec 01, 2018 2:25 am
more files
Novapro_III_flex_motor_mount_1_0_a.stl
(228.89 KiB) Downloaded 13 times
Novapro_III_flex_tbottom_gear_housing_1_0_a.stl
(202.82 KiB) Downloaded 13 times
Novapro_III_flex_top_gear_housing_1_0_a.stl
(294.61 KiB) Downloaded 16 times
Novapro_III_flex_Main_body_1_0_a.stl
(511.41 KiB) Downloaded 12 times
NovaPro_Idler_Latch_1_2_a.stl
(184.46 KiB) Downloaded 12 times
NovaPro_Idler_Half_2_RH_2_0_a.stl
(74.3 KiB) Downloaded 16 times
NovaPro_Idler_Half_1_RH_2_0_a.stl
(59.36 KiB) Downloaded 14 times
