AO-101 60mm Print Height Increase
antfurn
Re: AO-101 60mm Print Height Increase
Post by antfurn » Tue Jul 09, 2013 12:41 pm
Pics as requested :D
The strip down
The strip down
All back together again
159mm tall vase (in lulzbot green)
Antony
antfurn
Post by antfurn » Tue Jul 09, 2013 12:44 pm
Quick warning: Make sure you check how your cables move after this upgrade. I had to add a clip to stop my x-axis stepper motor wires from catching under electronics enclosure. Nearly ripped them out :oops: the first time I raised z-axis to the top.
Antony
Gemini64
Post by Gemini64 » Tue Jul 09, 2013 9:05 pm
Very nice, thanks for sharing. :)
jebba
Site Admin
Post by jebba » Wed Jul 10, 2013 7:17 am
Woo! Nice one. :)
lotw
Post by lotw » Wed Jul 10, 2013 10:35 am
Very nice, thinking of doing that mod after I finish testing the new design I am testing for lead screw couplers.
antfurn
Post by antfurn » Sat Jul 13, 2013 3:31 pm
Time lapse video printing a 16cm tall version of Humphrey 8-)
http://youtu.be/vFbMNoVkGK0
Antony
mhullin
Post by mhullin » Mon Oct 14, 2013 11:10 am
This looks great. My printer is cranking out the new parts as I type.
A couple of questions - I'm assuming I'll need to add the little nuts into the new parts. I've looked through the parts section of the site and I don't see them.
Anyone know the specs for those?
Anyone have a source for them?
To install them, do I just heat them up w/ a soldering iron and press them into place?
Thanks in advance.
Mark
antfurn
Post by antfurn » Mon Oct 14, 2013 11:14 am
The AO-101 z-axis parts don't use heat-inserts. The existing nuts can just be removed and re-used in the updated parts.
Antony
piercet
Contact:
Post by piercet » Mon Oct 14, 2013 5:54 pm
On the off chance you were referring to the Taz Style x ends parts in the other thread here: http://forum.lulzbot.com/viewtopic.php?f=16&t=306 Those parts can be installed with a soldering iron and can be sourced from Mcmaster Carr.
Theycallmejohn
Post by Theycallmejohn » Mon Dec 30, 2013 10:15 am
That is pretty cool. I think I might have to start printing those parts out.
BTW: Those LED lighting strips are pretty cool. Is there a tutorial on how to do that?
