Page 8 of 9
Re: Latest marlin firmware for TAZ 5
Posted: Fri Apr 22, 2016 3:25 pm
by movingimage
Your points make sense! I can set up the compile environment, I'm just being lazy :)
Posted: Tue May 03, 2016 8:09 pm
by JK47TheWeapon
Sebatian,
I loaded up your code tonight. A few issues I am having:
* It retracts and forward in very tiny increments at incredibly high rate. Sounds like I'm grinding the extruder gear, because of how often it is trying to. (Using same STLs I did before which did not do this.)
* I stops printing for anywhere from 10 seconds to 2 minutes randomly. (maybe bug #3287 or #3284)
This message shows when it stalls out:
Recv: echo:busy: processing
* Seeing alot of checksum mismatches, and it not receiving lines:
Send: N98630 G1 F3000 X135.789 Y164.683 E8608.87939*54
Recv: Error:Line Number is not Last Line Number+1, Last Line: 98629
Recv: Resend: 98630
Can you merge your changes into RC5 or RC6?
Sebastian wrote:....
Have fun, at your own risk as always :)
Posted: Wed May 04, 2016 7:53 am
by Sebastian
I guess your problems are related to a bug I fixed a few days after I posted the code here.
You can find the latest code here: https://github.com/Sebastianv650/Marlin ... VANCE-2ISR
I'm in the process of a re-implementation to the latest Marlin RCBugFix, but it takes some time. It's very bad for me that they made bigger changes to stepper.cpp and planner.cpp with the last commits - now they use objects. I have nearly no practice in coding, I need it only once a year or so, so it's a hughe effort for me to read through all the changes and make it working again. And I'm afraid I will do it at least once more when they introduce the extruder mixing feature.. :?
Posted: Wed May 04, 2016 11:22 pm
by JK47TheWeapon
Thanks for the status update. For now, I jumped to the RCBugFix branch and your config files.
Posted: Thu May 05, 2016 7:37 am
by Sebastian
It should be safe now to use the code from my Fork on Github. I changed the behaviour of the extruder interrupt. It's now distributing the esteps instead of firing up to 4 in a batch. I get nearly no communication errors now during print, seems to be quite perfect now.
By the way, the communication errors are due to a bug in Marlin, the advance thing makes it worse but it's not the source. That's why the link points to the RC4 code base and not to the latest RCBugFix that's also available on my repo. The changes they did in RC6 and later slow down the ISR routines which leads to much more errors than in RC4. One important function from the serial communications seems to get interrupted by the ISR..
Sebastian wrote: You can find the latest code here: https://github.com/Sebastianv650/Marlin ... VANCE-2ISR
Posted: Thu May 12, 2016 7:00 pm
by billyd
Your last link in the post before this one is not setup for a Taz 5. Do we just overwrite the configuration.h and the configuration_adv.h with your Taz 5 firmware from your previous version? Are there any other reqiured files? Or is this one not ready for Taz 5 use? Sorry I only have enough knowledge to be dangerous.
Posted: Fri May 13, 2016 12:12 pm
by Sebastian
The version on github.com is a stock marlin config. You can take you current taz config files as a reference and edit the new ones with your values.
Or you wait until mid next week. I got advance to stabile also in RC6 and will provide a configured download for all the users here who wants more ;)
Posted: Fri May 13, 2016 2:48 pm
by billyd
Sebastian wrote:The version on github.com is a stock marlin config. You can take you current taz config files as a reference and edit the new ones with your values.
I will wait, thanks again for all your hard work!
Posted: Tue May 17, 2016 9:02 am
by Sebastian
billyd wrote:I will wait, thanks again for all your hard work!
Time to wait is over: viewtopic.php?f=18&t=4464&p=26568#p26568
Posted: Sat Jul 23, 2016 8:26 am
by eussrh
Thanks for all your hard work. I was going to create a version so I could use Mesh leveling, but now I don't have to. Glad I checked the forums. 8-)
