Taz 5 Cura Pronterface issue
I have loaded Pronterface and Lulzbot Cura but when I click the control button in Cura the Pronterface dashborad doesn’t come up. I’ve tried uninstalling both and re-installing to no avail. Suggestions?
Also, when printing stl files from Cura it stops injecting. Pronterface seems to print gcode file just fine.
Check your print window options: Cura > File > Preferences > Print Window > Printing Window Type- Make sure that “Pronterface UI” is selected. Save the changes if not, close, and reopen Cura.
Thank you, knew it had to be something simple!!
