Latest Firmware for TAZ5 - advanced development version
Sebastian
Re: Latest Firmware for TAZ5 - advanced development version
Post by Sebastian » Tue Jan 17, 2017 10:44 am
I started the print at 49,9mm height, now it's at 52,1mm and running. Looks like I can't reproduce your freezing system.
Only difference to your system: I'm "printing" with cold bed and nozzle, I don't want to heat the nozzle because I'm afraid remaining peaces of plastic might burn in and block the nozzle.
It looks like it's a problem with very specific settings. There are other issues at Marlin git, one related to bed leveling for example. The printer there is also freezing with very specific lines of gcode.
If you send me also your config and config_adv files I would test it with exact your settings. If it's compatible, for example what means your M73 command?
billyd
Post by billyd » Tue Jan 17, 2017 12:51 pm
Sebastian wrote:I started the print at 49,9mm height, now it's at 52,1mm and running. Looks like I can't reproduce your freezing system.
I think it's related to heating the extruder so by leaving yours off it may not happen.
That M73 command is something I stole from a different printer's startup gcode. That code section in the beginning was from a makerbot r2 purge/prime routine and it ended with the M73. I left it in and have been using it in my Taz for years without issue. But it is ignored by Marlin and I should remove it... forgot it was in there.
I'll give you my .h files tonight when I get home. I do think I went overboard on increasing the values to prevent thermal runaway and was thinking of resetting them back to default and looking for another way to solve that problem. I have a hunch it is related to the freezing in my case...
ps Just realized my .h files are already here at the top of the previous page of this thread. However the thermal runaway parameters are stock because I still hadn't changed them and wasn't seeing the thermal runaway issue with any great regularity yet. In fact I really didn't start having a lot of these problems until I increased my hot end to 250 after making those thermal runaway changes.
billyd
Post by billyd » Tue Jan 17, 2017 5:23 pm
Code: Select all
 * Marlin 3D Printer Firmware
 * Copyright (C) 2016 MarlinFirmware [https://github.com/MarlinFirmware/Marlin]
 * Based on Sprinter and grbl.
 * Copyright (C) 2011 Camiel Gubbels / Erik van der Zalm
 * This program is free software: you can redistribute it and/or modify
 * it under the terms of the GNU General Public License as published by
 * the Free Software Foundation, either version 3 of the License, or
 * (at your option) any later version.
 * This program is distributed in the hope that it will be useful,
 * but WITHOUT ANY WARRANTY; without even the implied warranty of
 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 * GNU General Public License for more details.
 * You should have received a copy of the GNU General Public License
 * along with this program.  If not, see <http://www.gnu.org/licenses/>.
 * Configuration.h
 * Basic settings such as:
 * - Type of electronics
 * - Type of temperature sensor
 * - Printer geometry
 * - Endstop configuration
 * - LCD controller
 * - Extra features
 * Advanced settings can be found in Configuration_adv.h
#ifndef CONFIGURATION_H
#define CONFIGURATION_H
 *  **  ATTENTION TO ALL DEVELOPERS  **
 * You must increment this version number for every significant change such as,
 * but not limited to: ADD, DELETE RENAME OR REPURPOSE any directive/option.
 * Note: Update also Version.h !
#define CONFIGURATION_H_VERSION 010100
//============================= Getting Started =============================
 * Here are some standard links for getting your machine calibrated:
 * http://reprap.org/wiki/Calibration
 * http://youtu.be/wAL9d7FgInk
 * http://calculator.josefprusa.cz
 * http://reprap.org/wiki/Triffid_Hunter%27s_Calibration_Guide
 * http://www.thingiverse.com/thing:5573
 * https://sites.google.com/site/repraplogphase/calibration-of-your-reprap
 * http://www.thingiverse.com/thing:298812
//============================= DELTA Printer ===============================
// For a Delta printer replace the configuration files with the files in the
// example_configurations/delta directory.
//============================= SCARA Printer ===============================
// For a Scara printer replace the configuration files with the files in the
// example_configurations/SCARA directory.
// @section info
// BELOW AUTOMATIC VERSIONING FROM SEBASTIAN MAY NEED TO DELETE
#if ENABLED(USE_AUTOMATIC_VERSIONING)
  #include "_Version.h"
#else
  #include "Version.h"
#endif
// User-specified version info of this build to display in [Pronterface, etc] terminal window during
// startup. Implementation of an idea by Prof Braino to inform user that any changes made to this
// build by the user have been successfully uploaded into firmware.
#define STRING_CONFIG_H_AUTHOR "(billyd, Taz 5)" // Who made the changes.
#define SHOW_BOOTSCREEN
#define STRING_SPLASH_LINE1 SHORT_BUILD_VERSION // will be shown during bootup in line 1
//#define STRING_SPLASH_LINE2 WEBSITE_URL         // will be shown during bootup in line 2
// *** VENDORS PLEASE READ *****************************************************
// Marlin now allow you to have a vendor boot image to be displayed on machine
// start. When SHOW_CUSTOM_BOOTSCREEN is defined Marlin will first show your
// custom boot image and them the default Marlin boot image is shown.
// We suggest for you to take advantage of this new feature and keep the Marlin
// boot image unmodified. For an example have a look at the bq Hephestos 2
// example configuration folder.
//#define SHOW_CUSTOM_BOOTSCREEN
// @section machine
 * Select which serial port on the board will be used for communication with the host.
 * This allows the connection of wireless adapters (for instance) to non-default port pins.
 * Serial port 0 is always used by the Arduino bootloader regardless of this setting.
 * :[0, 1, 2, 3, 4, 5, 6, 7]
#define SERIAL_PORT 0
 * This setting determines the communication speed of the printer.
 * 250000 works in most cases, but you might try a lower speed if
 * you commonly experience drop-outs during host printing.
 * :[2400, 9600, 19200, 38400, 57600, 115200, 250000]
#define BAUDRATE 115200
// Enable the Bluetooth serial interface on AT90USB devices
//#define BLUETOOTH
// The following define selects which electronics board you have.
// Please choose the name from boards.h that matches your setup
#ifndef MOTHERBOARD
  #define MOTHERBOARD BOARD_RAMBO
#endif
// Optional custom name for your RepStrap or other custom machine
// Displayed in the LCD "Ready" message
// #define CUSTOM_MACHINE_NAME "TAZ 5 by billyd                           "
// Define this to set a unique identifier for this printer, (Used by some programs to differentiate between machines)
// You can use an online service to generate a random UUID. (eg http://www.uuidgenerator.net/version4)
//#define MACHINE_UUID "00000000-0000-0000-0000-000000000000"
// This defines the number of extruders
// :[1, 2, 3, 4]
#define EXTRUDERS 1
// Enable if your E steppers or extruder gear ratios are not identical
//#define DISTINCT_E_FACTORS
// For Cyclops or any "multi-extruder" that shares a single nozzle.
//#define SINGLENOZZLE
// A dual extruder that uses a single stepper motor
// Don't forget to set SSDE_SERVO_ANGLES and HOTEND_OFFSET_X/Y/Z
//#define SWITCHING_EXTRUDER
//#if ENABLED(SWITCHING_EXTRUDER)
//  #define SWITCHING_EXTRUDER_SERVO_NR 0
//  #define SWITCHING_EXTRUDER_SERVO_ANGLES { 0, 90 } // Angles for E0, E1
  //#define HOTEND_OFFSET_Z {0.0, 0.0}
//#endif
 * "Mixing Extruder"
 *   - Adds a new code, M165, to set the current mix factors.
 *   - Extends the stepping routines to move multiple steppers in proportion to the mix.
 *   - Optional support for Repetier Host M163, M164, and virtual extruder.
 *   - This implementation supports only a single extruder.
 *   - Enable DIRECT_MIXING_IN_G1 for Pia Taubert's reference implementation
// #define MIXING_EXTRUDER
// #if ENABLED(MIXING_EXTRUDER)
//  #define MIXING_STEPPERS 2        // Number of steppers in your mixing extruder
//  #define MIXING_VIRTUAL_TOOLS 16  // Use the Virtual Tool method with M163 and M164
  // #define DIRECT_MIXING_IN_G1    // Allow ABCDHI mix factors in G1 movement commands
// #endif
// Offset of the extruders (uncomment if using more than one and relying on firmware to position when changing).
// The offset has to be X=0, Y=0 for the extruder 0 hotend (default extruder).
// For the other hotends it is their distance from the extruder 0 hotend.
//#define HOTEND_OFFSET_X {0.0, 20.00} // (in mm) for each extruder, offset of the hotend on the X axis
//#define HOTEND_OFFSET_Y {0.0, 5.00}  // (in mm) for each extruder, offset of the hotend on the Y axis
 * Select your power supply here. Use 0 if you haven't connected the PS_ON_PIN
 * 0 = No Power Switch
 * 1 = ATX
 * 2 = X-Box 360 203Watts (the blue wire connected to PS_ON and the red wire to VCC)
 * :{ 0:'No power switch', 1:'ATX', 2:'X-Box 360' }
#define POWER_SUPPLY 1
//#if POWER_SUPPLY > 0
  // Enable this option to leave the PSU off at startup.
  // Power to steppers and heaters will need to be turned on with M80.
  //#define PS_DEFAULT_OFF
//#endif
// @section temperature
//============================= Thermal Settings ============================
 * --NORMAL IS 4.7kohm PULLUP!-- 1kohm pullup can be used on hotend sensor, using correct resistor and table
 * Temperature sensors available:
 *    -3 : thermocouple with MAX31855 (only for sensor 0)
 *    -2 : thermocouple with MAX6675 (only for sensor 0)
 *    -1 : thermocouple with AD595
 *     0 : not used
 *     1 : 100k thermistor - best choice for EPCOS 100k (4.7k pullup)
 *     2 : 200k thermistor - ATC Semitec 204GT-2 (4.7k pullup)
 *     3 : Mendel-parts thermistor (4.7k pullup)
 *     4 : 10k thermistor !! do not use it for a hotend. It gives bad resolution at high temp. !!
 *     5 : 100K thermistor - ATC Semitec 104GT-2 (Used in ParCan & J-Head) (4.7k pullup)
 *     6 : 100k EPCOS - Not as accurate as table 1 (created using a fluke thermocouple) (4.7k pullup)
 *     7 : 100k Honeywell thermistor 135-104LAG-J01 (4.7k pullup)
 *    71 : 100k Honeywell thermistor 135-104LAF-J01 (4.7k pullup)
 *     8 : 100k 0603 SMD Vishay NTCS0603E3104FXT (4.7k pullup)
 *     9 : 100k GE Sensing AL03006-58.2K-97-G1 (4.7k pullup)
 *    10 : 100k RS thermistor 198-961 (4.7k pullup)
 *    11 : 100k beta 3950 1% thermistor (4.7k pullup)
 *    12 : 100k 0603 SMD Vishay NTCS0603E3104FXT (4.7k pullup) (calibrated for Makibox hot bed)
 *    13 : 100k Hisens 3950  1% up to 300°C for hotend "Simple ONE " & "Hotend "All In ONE"
 *    20 : the PT100 circuit found in the Ultimainboard V2.x
 *    60 : 100k Maker's Tool Works Kapton Bed Thermistor beta=3950
 *    66 : 4.7M High Temperature thermistor from Dyze Design
 *    70 : the 100K thermistor found in the bq Hephestos 2
 *       1k ohm pullup tables - This is atypical, and requires changing out the 4.7k pullup for 1k.
 *                              (but gives greater accuracy and more stable PID)
 *    51 : 100k thermistor - EPCOS (1k pullup)
 *    52 : 200k thermistor - ATC Semitec 204GT-2 (1k pullup)
 *    55 : 100k thermistor - ATC Semitec 104GT-2 (Used in ParCan & J-Head) (1k pullup)
 *  1047 : Pt1000 with 4k7 pullup
 *  1010 : Pt1000 with 1k pullup (non standard)
 *   147 : Pt100 with 4k7 pullup
 *   110 : Pt100 with 1k pullup (non standard)
 *         Use these for Testing or Development purposes. NEVER for production machine.
 *   998 : Dummy Table that ALWAYS reads 25°C or the temperature defined below.
 *   999 : Dummy Table that ALWAYS reads 100°C or the temperature defined below.
 * :{ '0': "Not used", '1':"100k / 4.7k - EPCOS", '2':"200k / 4.7k - ATC Semitec 204GT-2", '3':"Mendel-parts / 4.7k", '4':"10k !! do not use for a hotend. Bad resolution at high temp. !!", '5':"100K / 4.7k - ATC Semitec 104GT-2 (Used in ParCan & J-Head)", '6':"100k / 4.7k EPCOS - Not as accurate as Table 1", '7':"100k / 4.7k Honeywell 135-104LAG-J01", '8':"100k / 4.7k 0603 SMD Vishay NTCS0603E3104FXT", '9':"100k / 4.7k GE Sensing AL03006-58.2K-97-G1", '10':"100k / 4.7k RS 198-961", '11':"100k / 4.7k beta 3950 1%", '12':"100k / 4.7k 0603 SMD Vishay NTCS0603E3104FXT (calibrated for Makibox hot bed)", '13':"100k Hisens 3950  1% up to 300°C for hotend 'Simple ONE ' & hotend 'All In ONE'", '20':"PT100 (Ultimainboard V2.x)", '51':"100k / 1k - EPCOS", '52':"200k / 1k - ATC Semitec 204GT-2", '55':"100k / 1k - ATC Semitec 104GT-2 (Used in ParCan & J-Head)", '60':"100k Maker's Tool Works Kapton Bed Thermistor beta=3950", '66':"Dyze Design 4.7M High Temperature thermistor", '70':"the 100K thermistor found in the bq Hephestos 2", '71':"100k / 4.7k Honeywell 135-104LAF-J01", '147':"Pt100 / 4.7k", '1047':"Pt1000 / 4.7k", '110':"Pt100 / 1k (non-standard)", '1010':"Pt1000 / 1k (non standard)", '-3':"Thermocouple + MAX31855 (only for sensor 0)", '-2':"Thermocouple + MAX6675 (only for sensor 0)", '-1':"Thermocouple + AD595",'998':"Dummy 1", '999':"Dummy 2" }
#define TEMP_SENSOR_0 5 //NON STANDARD FOR TAZ THIS IS FOR E3D V6
#define TEMP_SENSOR_1 0
#define TEMP_SENSOR_2 0
#define TEMP_SENSOR_3 0
#define TEMP_SENSOR_BED 7 //MAY BE DIFFERENT FOR TAZ 5 OWNERS I HAVE CUSTOM BED
// Dummy thermistor constant temperature readings, for use with 998 and 999
// NOT SURE WHAT THIS IS, LEAVING IN FOR NOW, NOT IN SEBASTIANS PREVIOUS VERSIONS OF ADVANCE
#define DUMMY_THERMISTOR_998_VALUE 25
#define DUMMY_THERMISTOR_999_VALUE 100
// Use temp sensor 1 as a redundant sensor with sensor 0. If the readings
// from the two sensors differ too much the print will be aborted.
//#define TEMP_SENSOR_1_AS_REDUNDANT
#define MAX_REDUNDANT_TEMP_SENSOR_DIFF 10
// Extruder temperature must be close to target for this long before M109 returns success
#define TEMP_RESIDENCY_TIME 10  // (seconds)
#define TEMP_HYSTERESIS 3       // (degC) range of +/- temperatures considered "close" to the target one
#define TEMP_WINDOW     1       // (degC) Window around target to start the residency timer x degC early.
// Bed temperature must be close to target for this long before M190 returns success
#define TEMP_BED_RESIDENCY_TIME 10  // (seconds)
#define TEMP_BED_HYSTERESIS 3       // (degC) range of +/- temperatures considered "close" to the target one
#define TEMP_BED_WINDOW     1       // (degC) Window around target to start the residency timer x degC early.
// The minimal temperature defines the temperature below which the heater will not be enabled It is used
// to check that the wiring to the thermistor is not broken.
// Otherwise this would lead to the heater being powered on all the time.
#define HEATER_0_MINTEMP 5
#define HEATER_1_MINTEMP 5
#define HEATER_2_MINTEMP 5
#define HEATER_3_MINTEMP 5
#define BED_MINTEMP 5
// When temperature exceeds max temp, your heater will be switched off.
// This feature exists to protect your hotend from overheating accidentally, but *NOT* from thermistor short/failure!
// You should use MINTEMP for thermistor short/failure protection.
#define HEATER_0_MAXTEMP 300
#define HEATER_1_MAXTEMP 275
#define HEATER_2_MAXTEMP 275
#define HEATER_3_MAXTEMP 275
#define BED_MAXTEMP 120
//============================= PID Settings ================================
// PID Tuning Guide here: http://reprap.org/wiki/PID_Tuning
// Comment the following line to disable PID and enable bang-bang.
#define PIDTEMP
#define BANG_MAX 255 // limits current to nozzle while in bang-bang mode; 255=full current
#define PID_MAX BANG_MAX // limits current to nozzle while PID is active (see PID_FUNCTIONAL_RANGE below); 255=full current
#if ENABLED(PIDTEMP)
  //#define PID_AUTOTUNE_MENU // Add PID Autotune to the LCD "Temperature" menu to run M303 and apply the result.
  //#define PID_DEBUG // Sends debug data to the serial port.
  //#define PID_OPENLOOP 1 // Puts PID in open loop. M104/M140 sets the output power from 0 to PID_MAX
  //#define SLOW_PWM_HEATERS // PWM with very low frequency (roughly 0.125Hz=8s) and minimum state time of approximately 1s useful for heaters driven by a relay
  //#define PID_PARAMS_PER_HOTEND // Uses separate PID parameters for each extruder (useful for mismatched extruders)
                                  // Set/get with gcode: M301 E[extruder number, 0-2]
  #define PID_FUNCTIONAL_RANGE 10 // If the temperature difference between the target temperature and the actual temperature
                                  // is more than PID_FUNCTIONAL_RANGE then the PID will be shut off and the heater will be set to min/max.
  #define PID_INTEGRAL_DRIVE_MAX PID_MAX  //limit for the integral term THIS IS FROM PREVIOUS VERSION OF SEBASTIAN MIGHT NEED TO DELETE
  #define K1 0.95 //smoothing factor within the PID
  // If you are using a pre-configured hotend then you can use one of the value sets by uncommenting it
  // Ultimaker
  #define  DEFAULT_Kp 17.48 //NON STANDARD FOR TAZ 5 THIS IS FOR E3D V6
  #define  DEFAULT_Ki 1.20
  #define  DEFAULT_Kd 63.57
  // MakerGear
  //#define  DEFAULT_Kp 7.0
  //#define  DEFAULT_Ki 0.1
  //#define  DEFAULT_Kd 12
  // Mendel Parts V9 on 12V
  //#define  DEFAULT_Kp 63.0
  //#define  DEFAULT_Ki 2.25
  //#define  DEFAULT_Kd 440
#endif // PIDTEMP
//============================= PID > Bed Temperature Control ===============
// Select PID or bang-bang with PIDTEMPBED. If bang-bang, BED_LIMIT_SWITCHING will enable hysteresis
// Uncomment this to enable PID on the bed. It uses the same frequency PWM as the extruder.
// If your PID_dT is the default, and correct for your hardware/configuration, that means 7.689Hz,
// which is fine for driving a square wave into a resistive load and does not significantly impact you FET heating.
// This also works fine on a Fotek SSR-10DA Solid State Relay into a 250W heater.
// If your configuration is significantly different than this and you don't understand the issues involved, you probably
// shouldn't use bed PID until someone else verifies your hardware works.
// If this is enabled, find your own PID constants below.
#define PIDTEMPBED
//#define BED_LIMIT_SWITCHING
// This sets the max power delivered to the bed, and replaces the HEATER_BED_DUTY_CYCLE_DIVIDER option.
// all forms of bed control obey this (PID, bang-bang, bang-bang with hysteresis)
// setting this to anything other than 255 enables a form of PWM to the bed just like HEATER_BED_DUTY_CYCLE_DIVIDER did,
// so you shouldn't use it unless you are OK with PWM on your bed.  (see the comment on enabling PIDTEMPBED)
#define MAX_BED_POWER 255 // limits duty cycle to bed; 255=full current
#if ENABLED(PIDTEMPBED)
  //#define PID_BED_DEBUG // Sends debug data to the serial port.
  //120V 250W silicone heater into 4mm borosilicate (MendelMax 1.5+)
  //from FOPDT model - kp=.39 Tp=405 Tdead=66, Tc set to 79.2, aggressive factor of .15 (vs .1, 1, 10)
  #define  DEFAULT_bedKp 417.81 // THESE PIDS ARE FOR MY CUSTOM BED NOT FOR TAZ 5
  #define  DEFAULT_bedKi 24.43
  #define  DEFAULT_bedKd 1786.65
  //from pidautotune
  //#define  DEFAULT_bedKp 97.1
  //#define  DEFAULT_bedKi 1.41
  //#define  DEFAULT_bedKd 1675.16
  // FIND YOUR OWN: "M303 E-1 C8 S90" to run autotune on the bed at 90 degreesC for 8 cycles.
#endif // PIDTEMPBED
// @section extruder
// This option prevents extrusion if the temperature is below EXTRUDE_MINTEMP.
// It also enables the M302 command to set the minimum extrusion temperature
// or to allow moving the extruder regardless of the hotend temperature.
// *** IT IS HIGHLY RECOMMENDED TO LEAVE THIS OPTION ENABLED! ***
#define PREVENT_COLD_EXTRUSION
#define EXTRUDE_MINTEMP 170
// This option prevents a single extrusion longer than EXTRUDE_MAXLENGTH.
// Note that for Bowden Extruders a too-small value here may prevent loading.
#define PREVENT_LENGTHY_EXTRUDE
#define EXTRUDE_MAXLENGTH 300 // WAS 200 IN ORIGINAL CONFIG.H
//======================== Thermal Runaway Protection =======================
 * Thermal Protection protects your printer from damage and fire if a
 * thermistor falls out or temperature sensors fail in any way.
 * The issue: If a thermistor falls out or a temperature sensor fails,
 * Marlin can no longer sense the actual temperature. Since a disconnected
 * thermistor reads as a low temperature, the firmware will keep the heater on.
 * If you get "Thermal Runaway" or "Heating failed" errors the
 * details can be tuned in Configuration_adv.h
#define THERMAL_PROTECTION_HOTENDS // Enable thermal protection for all extruders
#define THERMAL_PROTECTION_BED     // Enable thermal protection for the heated bed
//============================= Mechanical Settings =========================
// @section machine
// Uncomment one of these options to enable CoreXY, CoreXZ, or CoreYZ kinematics
// either in the usual order or reversed
//#define COREXY
//#define COREXZ
//#define COREYZ
//#define COREYX
//#define COREZX
//#define COREZY
// Enable this option for Toshiba steppers
//#define CONFIG_STEPPERS_TOSHIBA
//============================== Endstop Settings ===========================
// @section homing
// Specify here all the endstop connectors that are connected to any endstop or probe.
// Almost all printers will be using one per axis. Probes will use one or more of the
// extra connectors. Leave undefined any used for non-endstop and non-probe purposes.
#define USE_XMIN_PLUG
#define USE_YMIN_PLUG
#define USE_ZMIN_PLUG
//#define USE_XMAX_PLUG
//#define USE_YMAX_PLUG
//#define USE_ZMAX_PLUG
// coarse Endstop Settings
#define ENDSTOPPULLUPS // Comment this out (using // at the start of the line) to disable the endstop pullup resistors
#if DISABLED(ENDSTOPPULLUPS)
  // fine endstop settings: Individual pullups. will be ignored if ENDSTOPPULLUPS is defined
  //#define ENDSTOPPULLUP_XMAX
  //#define ENDSTOPPULLUP_YMAX
  //#define ENDSTOPPULLUP_ZMAX
  //#define ENDSTOPPULLUP_XMIN
  //#define ENDSTOPPULLUP_YMIN
  //#define ENDSTOPPULLUP_ZMIN
  //#define ENDSTOPPULLUP_ZMIN_PROBE
#endif
// Mechanical endstop with COM to ground and NC to Signal uses "false" here (most common setup).
#define X_MIN_ENDSTOP_INVERTING true // set to true to invert the logic of the endstop.
#define Y_MIN_ENDSTOP_INVERTING true // set to true to invert the logic of the endstop.
#define Z_MIN_ENDSTOP_INVERTING true // set to true to invert the logic of the endstop.
#define X_MAX_ENDSTOP_INVERTING true // set to true to invert the logic of the endstop.
#define Y_MAX_ENDSTOP_INVERTING true // set to true to invert the logic of the endstop.
#define Z_MAX_ENDSTOP_INVERTING true // set to true to invert the logic of the endstop.
#define Z_MIN_PROBE_ENDSTOP_INVERTING false // set to true to invert the logic of the probe.
// Enable this feature if all enabled endstop pins are interrupt-capable.
// This will remove the need to poll the interrupt pins, saving many CPU cycles.
//#define ENDSTOP_INTERRUPTS_FEATURE
//============================== Movement Settings ============================
// @section motion
 * Default Settings
 * These settings can be reset by M502
 * You can set distinct factors for each E stepper, if needed.
 * If fewer factors are given, the last will apply to the rest.
 * Note that if EEPROM is enabled, saved values will override these.
 * Default Axis Steps Per Unit (steps/mm)
 * Override with M92
 *                                      X, Y, Z, E0 [, E1[, E2[, E3]]]
#define DEFAULT_AXIS_STEPS_PER_UNIT   { 100.5, 100.5, 1600, 853 }
 * Default Max Feed Rate (mm/s)
 * Override with M203
#define DEFAULT_MAX_FEEDRATE          { 800, 800, 8, 40 }
 * Default Max Acceleration (change/s) change = mm/s
 * (Maximum start speed for accelerated moves)
 * Override with M201
#define DEFAULT_MAX_ACCELERATION      { 3000, 3000, 100, 10000 }
 * Default Acceleration (change/s) change = mm/s
 * Override with M204
 *   M204 P    Acceleration
 *   M204 R    Retract Acceleration
 *   M204 T    Travel Acceleration
#define DEFAULT_ACCELERATION          900    // X, Y, Z and E acceleration for printing moves
#define DEFAULT_RETRACT_ACCELERATION  2400    // E acceleration for retracts
#define DEFAULT_TRAVEL_ACCELERATION   1200    // X, Y, Z acceleration for travel (non printing) moves
 * Default Jerk (mm/s)
 * Override with M205 X Y Z E
 * "Jerk" specifies the minimum speed change that requires acceleration.
 * When changing speed and direction, if the difference is less than the
 * value set here, it may happen instantaneously.
#define DEFAULT_XJERK                 8.0
#define DEFAULT_YJERK                 8.0
#define DEFAULT_ZJERK                  0.4
#define DEFAULT_EJERK                  10.0
//============================= Z Probe Options =============================
// @section probes
// Probe Type
// Probes are sensors/switches that are activated / deactivated before/after use.
// Allen Key Probes, Servo Probes, Z-Sled Probes, FIX_MOUNTED_PROBE, etc.
// You must activate one of these to use Auto Bed Leveling below.
// Use M851 to set the Z probe vertical offset from the nozzle. Store with M500.
// A Fix-Mounted Probe either doesn't deploy or needs manual deployment.
// For example an inductive probe, or a setup that uses the nozzle to probe.
// An inductive probe must be deactivated to go below
// its trigger-point if hardware endstops are active.
//#define FIX_MOUNTED_PROBE
// The BLTouch probe emulates a servo probe.
// The default connector is SERVO 0. Set Z_ENDSTOP_SERVO_NR below to override.
//#define BLTOUCH
// Z Servo Probe, such as an endstop switch on a rotating arm.
//#define Z_ENDSTOP_SERVO_NR 0
//#define Z_SERVO_ANGLES {70,0} // Z Servo Deploy and Stow angles
// Enable if you have a Z probe mounted on a sled like those designed by Charles Bell.
//#define Z_PROBE_SLED
//#define SLED_DOCKING_OFFSET 5 // The extra distance the X axis must travel to pickup the sled. 0 should be fine but you can push it further if you'd like.
// Z Probe to nozzle (X,Y) offset, relative to (0, 0).
// X and Y offsets must be integers.
// In the following example the X and Y offsets are both positive:
// #define X_PROBE_OFFSET_FROM_EXTRUDER 10
// #define Y_PROBE_OFFSET_FROM_EXTRUDER 10
//    +-- BACK ---+
//  L |    (+) P  | R <-- probe (20,20)
//  E |           | I
//  F | (-) N (+) | G <-- nozzle (10,10)
//  T |           | H
//    |    (-)    | T
//    O-- FRONT --+
//  (0,0)
#define X_PROBE_OFFSET_FROM_EXTRUDER 10  // X offset: -left  +right  [of the nozzle]
#define Y_PROBE_OFFSET_FROM_EXTRUDER 10  // Y offset: -front +behind [the nozzle]
#define Z_PROBE_OFFSET_FROM_EXTRUDER 0   // Z offset: -below +above  [the nozzle]
// X and Y axis travel speed (mm/m) between probes
#define XY_PROBE_SPEED 8000
// Speed for the first approach when double-probing (with PROBE_DOUBLE_TOUCH)
#define Z_PROBE_SPEED_FAST HOMING_FEEDRATE_Z
// Speed for the "accurate" probe of each point
#define Z_PROBE_SPEED_SLOW (Z_PROBE_SPEED_FAST / 2)
// Use double touch for probing
//#define PROBE_DOUBLE_TOUCH
// Allen Key Probe is defined in the Delta example configurations.
// *** PLEASE READ ALL INSTRUCTIONS BELOW FOR SAFETY! ***
// To continue using the Z-min-endstop for homing, be sure to disable Z_SAFE_HOMING.
// Example: To park the head outside the bed area when homing with G28.
// To use a separate Z probe, your board must define a Z_MIN_PROBE_PIN.
// For a servo-based Z probe, you must set up servo support below, including
// NUM_SERVOS, Z_ENDSTOP_SERVO_NR and Z_SERVO_ANGLES.
// - RAMPS 1.3/1.4 boards may be able to use the 5V, GND, and Aux4->D32 pin.
// - Use 5V for powered (usu. inductive) sensors.
// - Otherwise connect:
//   - normally-closed switches to GND and D32.
//   - normally-open switches to 5V and D32.
// Normally-closed switches are advised and are the default.
// The Z_MIN_PROBE_PIN sets the Arduino pin to use. (See your board's pins file.)
// Since the RAMPS Aux4->D32 pin maps directly to the Arduino D32 pin, D32 is the
// default pin for all RAMPS-based boards. Most boards use the X_MAX_PIN by default.
// To use a different pin you can override it here.
// WARNING:
// Setting the wrong pin may have unexpected and potentially disastrous consequences.
// Use with caution and do your homework.
//#define Z_MIN_PROBE_PIN X_MAX_PIN
// Enable Z_MIN_PROBE_ENDSTOP to use _both_ a Z Probe and a Z-min-endstop on the same machine.
// With this option the Z_MIN_PROBE_PIN will only be used for probing, never for homing.
//#define Z_MIN_PROBE_ENDSTOP
// Enable Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN to use the Z_MIN_PIN for your Z_MIN_PROBE.
// The Z_MIN_PIN will then be used for both Z-homing and probing.
#define Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN
// To use a probe you must enable one of the two options above!
// Enable Z Probe Repeatability test to see how accurate your probe is
//#define Z_MIN_PROBE_REPEATABILITY_TEST
 * Z probes require clearance when deploying, stowing, and moving between
 * probe points to avoid hitting the bed and other hardware.
 * Servo-mounted probes require extra space for the arm to rotate.
 * Inductive probes need space to keep from triggering early.
 * Use these settings to specify the distance (mm) to raise the probe (or
 * lower the bed). The values set here apply over and above any (negative)
 * probe Z Offset set with Z_PROBE_OFFSET_FROM_EXTRUDER, M851, or the LCD.
 * Only integer values >= 1 are valid here.
 * Example: `M851 Z-5` with a CLEARANCE of 4  =>  9mm from bed to nozzle.
 *     But: `M851 Z+1` with a CLEARANCE of 2  =>  2mm from bed to nozzle.
#define Z_CLEARANCE_DEPLOY_PROBE   10 // Z Clearance for Deploy/Stow
#define Z_CLEARANCE_BETWEEN_PROBES  5 // Z Clearance between probe points
// For M851 give a range for adjusting the Z probe offset
#define Z_PROBE_OFFSET_RANGE_MIN -20
#define Z_PROBE_OFFSET_RANGE_MAX 20
// For Inverting Stepper Enable Pins (Active Low) use 0, Non Inverting (Active High) use 1
// :{ 0:'Low', 1:'High' }
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define E_ENABLE_ON 0 // For all extruders
// Disables axis stepper immediately when it's not being used.
// WARNING: When motors turn off there is a chance of losing position accuracy!
#define DISABLE_X false
#define DISABLE_Y false
#define DISABLE_Z false
// Warn on display about possibly reduced accuracy
//#define DISABLE_REDUCED_ACCURACY_WARNING
#define DISABLE_E false // For all extruders
#define DISABLE_INACTIVE_EXTRUDER true //disable only inactive extruders and keep active extruder enabled
// @section machine
// Invert the stepper direction. Change (or reverse the motor connector) if an axis goes the wrong way.
#define INVERT_X_DIR false
#define INVERT_Y_DIR true
#define INVERT_Z_DIR false
// For direct drive extruder v9 set to true, for geared extruder set to false.
#define INVERT_E0_DIR true
#define INVERT_E1_DIR true
#define INVERT_E2_DIR true
#define INVERT_E3_DIR true
// @section homing
//#define Z_HOMING_HEIGHT 4  // (in mm) Minimal z height before homing (G28) for Z clearance above the bed, clamps, ...
                             // Be sure you have this distance over your Z_MAX_POS in case.
// ENDSTOP SETTINGS:
// Sets direction of endstops when homing; 1=MAX, -1=MIN
// :[-1, 1]
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
#define min_software_endstops true // If true, axis won't move to coordinates less than HOME_POS.
#define max_software_endstops true  // If true, axis won't move to coordinates greater than the defined lengths below.
// @section machine
// Travel limits after homing (units are in mm)
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define X_MAX_POS 298
#define Y_MAX_POS 275
#define Z_MAX_POS 250
 * Filament Runout Sensor
 * A mechanical or opto endstop is used to check for the presence of filament.
 * RAMPS-based boards use SERVO3_PIN.
 * For other boards you may need to define FIL_RUNOUT_PIN.
 * By default the firmware assumes HIGH = has filament, LOW = ran out
//#define FILAMENT_RUNOUT_SENSOR
#if ENABLED(FILAMENT_RUNOUT_SENSOR)
  #define FIL_RUNOUT_INVERTING false // set to true to invert the logic of the sensor.
  #define ENDSTOPPULLUP_FIL_RUNOUT // Uncomment to use internal pullup for filament runout pins if the sensor is defined.
  #define FILAMENT_RUNOUT_SCRIPT "M600"
#endif
//============================ Mesh Bed Leveling ============================
//#define MESH_BED_LEVELING    // Enable mesh bed leveling.
#if ENABLED(MESH_BED_LEVELING)
  #define MESH_INSET 10        // Mesh inset margin on print area
  #define MESH_NUM_X_POINTS 3  // Don't use more than 7 points per axis, implementation limited.
  #define MESH_NUM_Y_POINTS 3
  #define MESH_HOME_SEARCH_Z 4  // Z after Home, bed somewhere below but above 0.0.
  //#define MESH_G28_REST_ORIGIN // After homing all axes ('G28' or 'G28 XYZ') rest at origin [0,0,0]
  //#define MANUAL_BED_LEVELING  // Add display menu option for bed leveling.
  #if ENABLED(MANUAL_BED_LEVELING)
    #define MBL_Z_STEP 0.025  // Step size while manually probing Z axis.
  #endif  // MANUAL_BED_LEVELING
  // Gradually reduce leveling correction until a set height is reached,
  // at which point movement will be level to the machine's XY plane.
  // The height can be set with M420 Z<height>
  #define ENABLE_LEVELING_FADE_HEIGHT
#endif  // MESH_BED_LEVELING
//============================ Auto Bed Leveling ============================
// @section bedlevel
 * Select one form of Auto Bed Leveling below.
 *  If you're also using the Probe for Z Homing, it's
 *  highly recommended to enable Z_SAFE_HOMING also!
 * - 3POINT
 *   Probe 3 arbitrary points on the bed (that aren't collinear)
 *   You specify the XY coordinates of all 3 points.
 *   The result is a single tilted plane. Best for a flat bed.
 * - LINEAR
 *   Probe several points in a grid.
 *   You specify the rectangle and the density of sample points.
 * - BILINEAR
 *   The result is a mesh, best for large or uneven beds.
//#define AUTO_BED_LEVELING_3POINT
//#define AUTO_BED_LEVELING_LINEAR
//#define AUTO_BED_LEVELING_BILINEAR
 * Enable detailed logging of G28, G29, M48, etc.
 * Turn on with the command 'M111 S32'.
 * NOTE: Requires a lot of PROGMEM!
//#define DEBUG_LEVELING_FEATURE
#if ENABLED(AUTO_BED_LEVELING_LINEAR) || ENABLED(AUTO_BED_LEVELING_BILINEAR)
  // Set the number of grid points per dimension.
  #define ABL_GRID_MAX_POINTS_X 3
  #define ABL_GRID_MAX_POINTS_Y ABL_GRID_MAX_POINTS_X
  // Set the boundaries for probing (where the probe can reach).
  #define LEFT_PROBE_BED_POSITION 15
  #define RIGHT_PROBE_BED_POSITION 170
  #define FRONT_PROBE_BED_POSITION 20
  #define BACK_PROBE_BED_POSITION 170
  // The Z probe minimum outer margin (to validate G29 parameters).
  #define MIN_PROBE_EDGE 10
  // Probe along the Y axis, advancing X after each column
  //#define PROBE_Y_FIRST
  #if ENABLED(AUTO_BED_LEVELING_BILINEAR)
    // Experimental Subdivision of the grid by Catmull-Rom method.
    // Synthesizes intermediate points to produce a more detailed mesh.
    //#define ABL_BILINEAR_SUBDIVISION
    #if ENABLED(ABL_BILINEAR_SUBDIVISION)
      // Number of subdivisions between probe points
      #define BILINEAR_SUBDIVISIONS 3
    #endif
  #endif
#elif ENABLED(AUTO_BED_LEVELING_3POINT)
  // 3 arbitrary points to probe.
  // A simple cross-product is used to estimate the plane of the bed.
  #define ABL_PROBE_PT_1_X 15
  #define ABL_PROBE_PT_1_Y 180
  #define ABL_PROBE_PT_2_X 15
  #define ABL_PROBE_PT_2_Y 20
  #define ABL_PROBE_PT_3_X 170
  #define ABL_PROBE_PT_3_Y 20
#endif
 * Commands to execute at the end of G29 probing.
 * Useful to retract or move the Z probe out of the way.
//#define Z_PROBE_END_SCRIPT "G1 Z10 F12000\nG1 X15 Y330\nG1 Z0.5\nG1 Z10"
// @section homing
// The center of the bed is at (X=0, Y=0)
//#define BED_CENTER_AT_0_0
// Manually set the home position. Leave these undefined for automatic settings.
// For DELTA this is the top-center of the Cartesian print volume.
//#define MANUAL_X_HOME_POS 0
//#define MANUAL_Y_HOME_POS 0
//#define MANUAL_Z_HOME_POS 0 // Distance between the nozzle to printbed after homing
// Use "Z Safe Homing" to avoid homing with a Z probe outside the bed area.
// With this feature enabled:
// - Allow Z homing only after X and Y homing AND stepper drivers still enabled.
// - If stepper drivers time out, it will need X and Y homing again before Z homing.
// - Move the Z probe (or nozzle) to a defined XY point before Z Homing when homing all axes (G28).
// - Prevent Z homing when the Z probe is outside bed area.
//#define Z_SAFE_HOMING
#if ENABLED(Z_SAFE_HOMING)
  #define Z_SAFE_HOMING_X_POINT ((X_MIN_POS + X_MAX_POS) / 2)    // X point for Z homing when homing all axis (G28).
  #define Z_SAFE_HOMING_Y_POINT ((Y_MIN_POS + Y_MAX_POS) / 2)    // Y point for Z homing when homing all axis (G28).
#endif
// Homing speeds (mm/m)
#define HOMING_FEEDRATE_XY (50*60)
#define HOMING_FEEDRATE_Z  (4*60)
//============================= Additional Features ===========================
// @section extras
// EEPROM
// The microcontroller can store settings in the EEPROM, e.g. max velocity...
// M500 - stores parameters in EEPROM
// M501 - reads parameters from EEPROM (if you need reset them after you changed them temporarily).
// M502 - reverts to the default "factory settings".  You still need to store them in EEPROM afterwards if you want to.
//define this to enable EEPROM support
#define EEPROM_SETTINGS
#if ENABLED(EEPROM_SETTINGS)
  // To disable EEPROM Serial responses and decrease program space by ~1700 byte: comment this out:
  #define EEPROM_CHITCHAT // Please keep turned on if you can.
#endif
// Host Keepalive
// When enabled Marlin will send a busy status message to the host
// every couple of seconds when it can't accept commands.
#define HOST_KEEPALIVE_FEATURE        // Disable this if your host doesn't like keepalive messages
#define DEFAULT_KEEPALIVE_INTERVAL 2  // Number of seconds between "busy" messages. Set with M113.
// M100 Free Memory Watcher
//#define M100_FREE_MEMORY_WATCHER // uncomment to add the M100 Free Memory Watcher for debug purpose
// G20/G21 Inch mode support
//#define INCH_MODE_SUPPORT
// M149 Set temperature units support
//#define TEMPERATURE_UNITS_SUPPORT
#define PREHEAT_1_TEMP_HOTEND 216
#define PREHEAT_1_TEMP_BED     61
#define PREHEAT_1_FAN_SPEED     0 // Value from 0 to 255
#define PREHEAT_2_TEMP_HOTEND 246
#define PREHEAT_2_TEMP_BED    101
#define PREHEAT_2_FAN_SPEED     0 // Value from 0 to 255
// Nozzle Park -- EXPERIMENTAL
// When enabled allows the user to define a special XYZ position, inside the
// machine's topology, to park the nozzle when idle or when receiving the G27
// command.
// The "P" paramenter controls what is the action applied to the Z axis:
//    P0: (Default) If current Z-pos is lower than Z-park then the nozzle will
//        be raised to reach Z-park height.
//    P1: No matter the current Z-pos, the nozzle will be raised/lowered to
//        reach Z-park height.
//    P2: The nozzle height will be raised by Z-park amount but never going over
//        the machine's limit of Z_MAX_POS.
//#define NOZZLE_PARK_FEATURE
#if ENABLED(NOZZLE_PARK_FEATURE)
  // Specify a park position as { X, Y, Z }
  #define NOZZLE_PARK_POINT { (X_MIN_POS + 10), (Y_MAX_POS - 10), 20 }
#endif
// Clean Nozzle Feature -- EXPERIMENTAL
// When enabled allows the user to send G12 to start the nozzle cleaning
// process, the G-Code accepts two parameters:
//   "P" for pattern selection
//   "S" for defining the number of strokes/repetitions
// Available list of patterns:
//   P0: This is the default pattern, this process requires a sponge type
//       material at a fixed bed location, the cleaning process is based on
//       "strokes" i.e. back-and-forth movements between the starting and end
//       points.
//   P1: This starts a zig-zag pattern between (X0, Y0) and (X1, Y1), "T"
//       defines the number of zig-zag triangles to be done. "S" defines the
//       number of strokes aka one back-and-forth movement. As an example
//       sending "G12 P1 S1 T3" will execute:
//         |  (X0, Y1) |     /\        /\        /\     | (X1, Y1)
//       A |           |   /    \    /    \    /    \   |
//         |  (X0, Y0) | /        \/        \/        \ | (X1, Y0)
//                       |________|_________|_________|
//                           T1        T2        T3
// Caveats: End point Z should use the same value as Start point Z.
// Attention: This is an EXPERIMENTAL feature, in the future the G-code arguments
// may change to add new functionality like different wipe patterns.
//#define NOZZLE_CLEAN_FEATURE
#if ENABLED(NOZZLE_CLEAN_FEATURE)
  // Number of pattern repetitions
  #define NOZZLE_CLEAN_STROKES  12
  // Specify positions as { X, Y, Z }
  #define NOZZLE_CLEAN_START_POINT { 30, 30, (Z_MIN_POS + 1)}
  #define NOZZLE_CLEAN_END_POINT   {100, 60, (Z_MIN_POS + 1)}
  // Moves the nozzle to the initial position
  #define NOZZLE_CLEAN_GOBACK
#endif
// Print job timer
// Enable this option to automatically start and stop the
// print job timer when M104/M109/M190 commands are received.
// M104 (extruder without wait) - high temp = none, low temp = stop timer
// M109 (extruder with wait) - high temp = start timer, low temp = stop timer
// M190 (bed with wait) - high temp = start timer, low temp = none
// In all cases the timer can be started and stopped using
// the following commands:
// - M75  - Start the print job timer
// - M76  - Pause the print job timer
// - M77  - Stop the print job timer
#define PRINTJOB_TIMER_AUTOSTART
// Print Counter
// When enabled Marlin will keep track of some print statistical data such as:
//  - Total print jobs
//  - Total successful print jobs
//  - Total failed print jobs
//  - Total time printing
// This information can be viewed by the M78 command.
//#define PRINTCOUNTER
//============================= LCD and SD support ============================
// @section lcd
// LCD LANGUAGE
// Here you may choose the language used by Marlin on the LCD menus, the following
// list of languages are available:
//    en, an, bg, ca, cn, cz, de, el, el-gr, es, eu, fi, fr, gl, hr, it,
//    kana, kana_utf8, nl, pl, pt, pt_utf8, pt-br, pt-br_utf8, ru, tr, uk, test
// :{ 'en':'English', 'an':'Aragonese', 'bg':'Bulgarian', 'ca':'Catalan', 'cn':'Chinese', 'cz':'Czech', 'de':'German', 'el':'Greek', 'el-gr':'Greek (Greece)', 'es':'Spanish', 'eu':'Basque-Euskera', 'fi':'Finnish', 'fr':'French', 'gl':'Galician', 'hr':'Croatian', 'it':'Italian', 'kana':'Japanese', 'kana_utf8':'Japanese (UTF8)', 'nl':'Dutch', 'pl':'Polish', 'pt':'Portuguese', 'pt-br':'Portuguese (Brazilian)', 'pt-br_utf8':'Portuguese (Brazilian UTF8)', 'pt_utf8':'Portuguese (UTF8)', 'ru':'Russian', 'tr':'Turkish', 'uk':'Ukrainian', 'test':'TEST' }
#define LCD_LANGUAGE en
// LCD Character Set
// Note: This option is NOT applicable to Graphical Displays.
// All character-based LCD's provide ASCII plus one of these
// language extensions:
//  - JAPANESE ... the most common
//  - WESTERN  ... with more accented characters
//  - CYRILLIC ... for the Russian language
// To determine the language extension installed on your controller:
//  - Compile and upload with LCD_LANGUAGE set to 'test'
//  - Click the controller to view the LCD menu
//  - The LCD will display Japanese, Western, or Cyrillic text
// See https://github.com/MarlinFirmware/Marlin/wiki/LCD-Language
// :['JAPANESE', 'WESTERN', 'CYRILLIC']
#define DISPLAY_CHARSET_HD44780 JAPANESE
// LCD TYPE
// You may choose ULTRA_LCD if you have character based LCD with 16x2, 16x4, 20x2,
// 20x4 char/lines or DOGLCD for the full graphics display with 128x64 pixels
// (ST7565R family). (This option will be set automatically for certain displays.)
// IMPORTANT NOTE: The U8glib library is required for Full Graphic Display!
//                 https://github.com/olikraus/U8glib_Arduino
//#define ULTRA_LCD   // Character based
//#define DOGLCD      // Full graphics display
// SD CARD
// SD Card support is disabled by default. If your controller has an SD slot,
// you must uncomment the following option or it won't work.
#define SDSUPPORT
// SD CARD: SPI SPEED
// Uncomment ONE of the following items to use a slower SPI transfer
// speed. This is usually required if you're getting volume init errors.
//#define SPI_SPEED SPI_HALF_SPEED
//#define SPI_SPEED SPI_QUARTER_SPEED
//#define SPI_SPEED SPI_EIGHTH_SPEED
// SD CARD: ENABLE CRC
// Use CRC checks and retries on the SD communication.
//#define SD_CHECK_AND_RETRY
// ENCODER SETTINGS
// This option overrides the default number of encoder pulses needed to
// produce one step. Should be increased for high-resolution encoders.
//#define ENCODER_PULSES_PER_STEP 1
// Use this option to override the number of step signals required to
// move between next/prev menu items.
//#define ENCODER_STEPS_PER_MENU_ITEM 5
 * Encoder Direction Options
 * Test your encoder's behavior first with both options disabled.
 *  Reversed Value Edit and Menu Nav? Enable REVERSE_ENCODER_DIRECTION.
 *  Reversed Menu Navigation only?    Enable REVERSE_MENU_DIRECTION.
 *  Reversed Value Editing only?      Enable BOTH options.
// This option reverses the encoder direction everywhere
//  Set this option if CLOCKWISE causes values to DECREASE
//#define REVERSE_ENCODER_DIRECTION
// This option reverses the encoder direction for navigating LCD menus.
//  If CLOCKWISE normally moves DOWN this makes it go UP.
//  If CLOCKWISE normally moves UP this makes it go DOWN.
//#define REVERSE_MENU_DIRECTION
// Individual Axis Homing
// Add individual axis homing items (Home X, Home Y, and Home Z) to the LCD menu.
//#define INDIVIDUAL_AXIS_HOMING_MENU
// SPEAKER/BUZZER
// If you have a speaker that can produce tones, enable it here.
// By default Marlin assumes you have a buzzer with a fixed frequency.
//#define SPEAKER
// The duration and frequency for the UI feedback sound.
// Set these to 0 to disable audio feedback in the LCD menus.
// Note: Test audio output with the G-Code:
//  M300 S<frequency Hz> P<duration ms>
//#define LCD_FEEDBACK_FREQUENCY_DURATION_MS 100
//#define LCD_FEEDBACK_FREQUENCY_HZ 1000
// CONTROLLER TYPE: Standard
// Marlin supports a wide variety of controllers.
// Enable one of the following options to specify your controller.
// ULTIMAKER Controller.
//#define ULTIMAKERCONTROLLER
// ULTIPANEL as seen on Thingiverse.
//#define ULTIPANEL
// Cartesio UI
// http://mauk.cc/webshop/cartesio-shop/electronics/user-interface
//#define CARTESIO_UI
// PanelOne from T3P3 (via RAMPS 1.4 AUX2/AUX3)
// http://reprap.org/wiki/PanelOne
//#define PANEL_ONE
// MaKr3d Makr-Panel with graphic controller and SD support.
// http://reprap.org/wiki/MaKr3d_MaKrPanel
//#define MAKRPANEL
// ReprapWorld Graphical LCD
// https://reprapworld.com/?products_details&products_id/1218
//#define REPRAPWORLD_GRAPHICAL_LCD
// Activate one of these if you have a Panucatt Devices
// Viki 2.0 or mini Viki with Graphic LCD
// http://panucatt.com
//#define VIKI2
//#define miniVIKI
// Adafruit ST7565 Full Graphic Controller.
// https://github.com/eboston/Adafruit-ST7565-Full-Graphic-Controller/
//#define ELB_FULL_GRAPHIC_CONTROLLER
// RepRapDiscount Smart Controller.
// http://reprap.org/wiki/RepRapDiscount_Smart_Controller
// Note: Usually sold with a white PCB.
//#define REPRAP_DISCOUNT_SMART_CONTROLLER
// GADGETS3D G3D LCD/SD Controller
// http://reprap.org/wiki/RAMPS_1.3/1.4_GADGETS3D_Shield_with_Panel
// Note: Usually sold with a blue PCB.
//#define G3D_PANEL
// RepRapDiscount FULL GRAPHIC Smart Controller
// http://reprap.org/wiki/RepRapDiscount_Full_Graphic_Smart_Controller
#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER
// MakerLab Mini Panel with graphic
// controller and SD support - http://reprap.org/wiki/Mini_panel
//#define MINIPANEL
// RepRapWorld REPRAPWORLD_KEYPAD v1.1
// http://reprapworld.com/?products_details&products_id=202&cPath=1591_1626
// REPRAPWORLD_KEYPAD_MOVE_STEP sets how much should the robot move when a key
// is pressed, a value of 10.0 means 10mm per click.
//#define REPRAPWORLD_KEYPAD
//#define REPRAPWORLD_KEYPAD_MOVE_STEP 1.0
// RigidBot Panel V1.0
// http://www.inventapart.com/
//#define RIGIDBOT_PANEL
// BQ LCD Smart Controller shipped by
// default with the BQ Hephestos 2 and Witbox 2.
//#define BQ_LCD_SMART_CONTROLLER
// CONTROLLER TYPE: I2C
// Note: These controllers require the installation of Arduino's LiquidCrystal_I2C
// library. For more info: https://github.com/kiyoshigawa/LiquidCrystal_I2C
// Elefu RA Board Control Panel
// http://www.elefu.com/index.php?route=product/product&product_id=53
//#define RA_CONTROL_PANEL
// Sainsmart YW Robot (LCM1602) LCD Display
//#define LCD_I2C_SAINSMART_YWROBOT
// Generic LCM1602 LCD adapter
//#define LCM1602
// PANELOLU2 LCD with status LEDs,
// separate encoder and click inputs.
// Note: This controller requires Arduino's LiquidTWI2 library v1.2.3 or later.
// For more info: https://github.com/lincomatic/LiquidTWI2
// Note: The PANELOLU2 encoder click input can either be directly connected to
// a pin (if BTN_ENC defined to != -1) or read through I2C (when BTN_ENC == -1).
//#define LCD_I2C_PANELOLU2
// Panucatt VIKI LCD with status LEDs,
// integrated click & L/R/U/D buttons, separate encoder inputs.
//#define LCD_I2C_VIKI
// SSD1306 OLED full graphics generic display
//#define U8GLIB_SSD1306
// SAV OLEd LCD module support using either SSD1306 or SH1106 based LCD modules
//#define SAV_3DGLCD
#if ENABLED(SAV_3DGLCD)
  #define U8GLIB_SH1106
#endif
// CONTROLLER TYPE: Shift register panels
// 2 wire Non-latching LCD SR from https://goo.gl/aJJ4sH
// LCD configuration: http://reprap.org/wiki/SAV_3D_LCD
//#define SAV_3DLCD
//=============================== Extra Features ==============================
// @section extras
// Increase the FAN PWM frequency. Removes the PWM noise but increases heating in the FET/Arduino
//#define FAST_PWM_FAN
// Use software PWM to drive the fan, as for the heaters. This uses a very low frequency
// which is not as annoying as with the hardware PWM. On the other hand, if this frequency
// is too low, you should also increment SOFT_PWM_SCALE.
//#define FAN_SOFT_PWM
// Incrementing this by 1 will double the software PWM frequency,
// affecting heaters, and the fan if FAN_SOFT_PWM is enabled.
// However, control resolution will be halved for each increment;
// at zero value, there are 128 effective control positions.
#define SOFT_PWM_SCALE 0
// Temperature status LEDs that display the hotend and bed temperature.
// If all hotends and bed temperature and temperature setpoint are < 54C then the BLUE led is on.
// Otherwise the RED led is on. There is 1C hysteresis.
//#define TEMP_STAT_LEDS
// M240  Triggers a camera by emulating a Canon RC-1 Remote
// Data from: http://www.doc-diy.net/photo/rc-1_hacked/
//#define PHOTOGRAPH_PIN     23
// SkeinForge sends the wrong arc g-codes when using Arc Point as fillet procedure
//#define SF_ARC_FIX
// Support for the BariCUDA Paste Extruder.
//#define BARICUDA
//define BlinkM/CyzRgb Support
//#define BLINKM
// Support for an RGB LED using 3 separate pins with optional PWM
//#define RGB_LED
#if ENABLED(RGB_LED)
  #define RGB_LED_R_PIN 34
  #define RGB_LED_G_PIN 43
  #define RGB_LED_B_PIN 35
#endif
* R/C SERVO support
* Sponsored by TrinityLabs, Reworked by codexmas
// Number of servos
// If you select a configuration below, this will receive a default value and does not need to be set manually
// set it manually if you have more servos than extruders and wish to manually control some
// leaving it undefined or defining as 0 will disable the servo subsystem
// If unsure, leave commented / disabled
//#define NUM_SERVOS 3 // Servo index starts with 0 for M280 command
// Delay (in microseconds) before the next move will start, to give the servo time to reach its target angle.
// 300ms is a good value but you can try less delay.
// If the servo can't reach the requested position, increase it.
//#define SERVO_DELAY 300
// Servo deactivation
// With this option servos are powered only during movement, then turned off to prevent jitter.
//#define DEACTIVATE_SERVOS_AFTER_MOVE
 * Support for a filament diameter sensor
 * Also allows adjustment of diameter at print time (vs  at slicing)
 * Single extruder only at this point (extruder 0)
 * Motherboards
 * 34 - RAMPS1.4 - uses Analog input 5 on the AUX2 connector
 * 81 - Printrboard - Uses Analog input 2 on the Exp1 connector (version B,C,D,E)
 * 301 - Rambo  - uses Analog input 3
 * Note may require analog pins to be defined for different motherboards
// Uncomment below to enable
//#define FILAMENT_WIDTH_SENSOR
#define DEFAULT_NOMINAL_FILAMENT_DIA 3.00  //Enter the diameter (in mm) of the filament generally used (3.0 mm or 1.75 mm) - this is then used in the slicer software.  Used for sensor reading validation
#if ENABLED(FILAMENT_WIDTH_SENSOR)
  #define FILAMENT_SENSOR_EXTRUDER_NUM 0   //The number of the extruder that has the filament sensor (0,1,2)
  #define MEASUREMENT_DELAY_CM        14   //measurement delay in cm.  This is the distance from filament sensor to middle of barrel
  #define MEASURED_UPPER_LIMIT         3.30  //upper limit factor used for sensor reading validation in mm
  #define MEASURED_LOWER_LIMIT         1.90  //lower limit factor for sensor reading validation in mm
  #define MAX_MEASUREMENT_DELAY       20     //delay buffer size in bytes (1 byte = 1cm)- limits maximum measurement delay allowable (must be larger than MEASUREMENT_DELAY_CM  and lower number saves RAM)
  #define DEFAULT_MEASURED_FILAMENT_DIA  DEFAULT_NOMINAL_FILAMENT_DIA  //set measured to nominal initially
  //When using an LCD, uncomment the line below to display the Filament sensor data on the last line instead of status.  Status will appear for 5 sec.
  //#define FILAMENT_LCD_DISPLAY
#endif
#endif // CONFIGURATION_H
billyd
Post by billyd » Tue Jan 17, 2017 5:24 pm
Note this has my goofy runaway parameters to avoid thermal runaway but may be causing problems.
Code: Select all
 * Configuration_adv.h
 * Advanced settings.
 * Only change these if you know exactly what you're doing.
 * Some of these settings can damage your printer if improperly set!
 * Basic settings can be found in Configuration.h
#ifndef CONFIGURATION_ADV_H
#define CONFIGURATION_ADV_H
#define CONFIGURATION_ADV_H_VERSION 010100
//=============================Thermal Settings  ============================
#if DISABLED(PIDTEMPBED)
  #define BED_CHECK_INTERVAL 5000 // ms between checks in bang-bang control
  #if ENABLED(BED_LIMIT_SWITCHING)
    #define BED_HYSTERESIS 2 // Only disable heating if T>target+BED_HYSTERESIS and enable heating if T>target-BED_HYSTERESIS
  #endif
#endif
 * The solution: Once the temperature reaches the target, start observing.
 * If the temperature stays too far below the target (hysteresis) for too long (period),
 * the firmware will halt the machine as a safety precaution.
 * If you get false positives for "Thermal Runaway" increase THERMAL_PROTECTION_HYSTERESIS and/or THERMAL_PROTECTION_PERIOD
#if ENABLED(THERMAL_PROTECTION_HOTENDS)
  #define THERMAL_PROTECTION_PERIOD 200        // Seconds
  #define THERMAL_PROTECTION_HYSTERESIS 20     // Degrees Celsius
   * Whenever an M104 or M109 increases the target temperature the firmware will wait for the
   * WATCH_TEMP_PERIOD to expire, and if the temperature hasn't increased by WATCH_TEMP_INCREASE
   * degrees, the machine is halted, requiring a hard reset. This test restarts with any M104/M109,
   * but only if the current temperature is far enough below the target for a reliable test.
   * If you get false positives for "Heating failed" increase WATCH_TEMP_PERIOD and/or decrease WATCH_TEMP_INCREASE
   * WATCH_TEMP_INCREASE should not be below 2.
  #define WATCH_TEMP_PERIOD 40                // Seconds
  #define WATCH_TEMP_INCREASE 2               // Degrees Celsius
#endif
 * Thermal Protection parameters for the bed are just as above for hotends.
#if ENABLED(THERMAL_PROTECTION_BED)
  #define THERMAL_PROTECTION_BED_PERIOD 200    // Seconds
  #define THERMAL_PROTECTION_BED_HYSTERESIS 20 // Degrees Celsius
   * Whenever an M140 or M190 increases the target temperature the firmware will wait for the
   * WATCH_BED_TEMP_PERIOD to expire, and if the temperature hasn't increased by WATCH_BED_TEMP_INCREASE
   * degrees, the machine is halted, requiring a hard reset. This test restarts with any M140/M190,
   * If you get too many "Heating failed" errors, increase WATCH_BED_TEMP_PERIOD and/or decrease
   * WATCH_BED_TEMP_INCREASE. (WATCH_BED_TEMP_INCREASE should not be below 2.)
  #define WATCH_BED_TEMP_PERIOD 90                // Seconds
  #define WATCH_BED_TEMP_INCREASE 2               // Degrees Celsius
#endif
  // this adds an experimental additional term to the heating power, proportional to the extrusion speed.
  // if Kc is chosen well, the additional required power due to increased melting should be compensated.
  //#define PID_EXTRUSION_SCALING
  #if ENABLED(PID_EXTRUSION_SCALING)
    #define DEFAULT_Kc (100) //heating power=Kc*(e_speed)
    #define LPQ_MAX_LEN 50
  #endif
#endif
 * Automatic Temperature:
 * The hotend target temperature is calculated by all the buffered lines of gcode.
 * The maximum buffered steps/sec of the extruder motor is called "se".
 * Start autotemp mode with M109 S<mintemp> B<maxtemp> F<factor>
 * The target temperature is set to mintemp+factor*se[steps/sec] and is limited by
 * mintemp and maxtemp. Turn this off by executing M109 without F*
 * Also, if the temperature is set to a value below mintemp, it will not be changed by autotemp.
 * On an Ultimaker, some initial testing worked with M109 S215 B260 F1 in the start.gcode
#define AUTOTEMP
#if ENABLED(AUTOTEMP)
  #define AUTOTEMP_OLDWEIGHT 0.98
#endif
//Show Temperature ADC value
//The M105 command return, besides traditional information, the ADC value read from temperature sensors.
//#define SHOW_TEMP_ADC_VALUES
 * High Temperature Thermistor Support
 * Thermistors able to support high temperature tend to have a hard time getting
 * good readings at room and lower temperatures. This means HEATER_X_RAW_LO_TEMP
 * will probably be caught when the heating element first turns on during the
 * preheating process, which will trigger a min_temp_error as a safety measure
 * and force stop everything.
 * To circumvent this limitation, we allow for a preheat time (during which,
 * min_temp_error won't be triggered) and add a min_temp buffer to handle
 * aberrant readings.
 * If you want to enable this feature for your hotend thermistor(s)
 * uncomment and set values > 0 in the constants below
// The number of consecutive low temperature errors that can occur
// before a min_temp_error is triggered. (Shouldn't be more than 10.)
//#define MAX_CONSECUTIVE_LOW_TEMPERATURE_ERROR_ALLOWED 0
// The number of milliseconds a hotend will preheat before starting to check
// the temperature. This value should NOT be set to the time it takes the
// hot end to reach the target temperature, but the time it takes to reach
// the minimum temperature your thermistor can read. The lower the better/safer.
// This shouldn't need to be more than 30 seconds (30000)
//#define MILLISECONDS_PREHEAT_TIME 0
// Extruder runout prevention.
// If the machine is idle and the temperature over MINTEMP
// then extrude some filament every couple of SECONDS.
//#define EXTRUDER_RUNOUT_PREVENT
#if ENABLED(EXTRUDER_RUNOUT_PREVENT)
  #define EXTRUDER_RUNOUT_MINTEMP 190
  #define EXTRUDER_RUNOUT_SECONDS 30
  #define EXTRUDER_RUNOUT_SPEED 1500  // mm/m
  #define EXTRUDER_RUNOUT_EXTRUDE 100   // mm CHANGED FROM 5
#endif
//These defines help to calibrate the AD595 sensor in case you get wrong temperature measurements.
//The measured temperature is defined as "actualTemp = (measuredTemp * TEMP_SENSOR_AD595_GAIN) + TEMP_SENSOR_AD595_OFFSET"
#define TEMP_SENSOR_AD595_OFFSET 0.0
#define TEMP_SENSOR_AD595_GAIN   1.0
//This is for controlling a fan to cool down the stepper drivers
//it will turn on when any driver is enabled
//and turn off after the set amount of seconds from last driver being disabled again
#define CONTROLLERFAN_PIN FAN2_PIN //Pin used for the fan to cool controller (-1 to disable)
#define CONTROLLERFAN_SECS 60 //How many seconds, after all motors were disabled, the fan should run
#define CONTROLLERFAN_SPEED 130  // == full speed
// When first starting the main fan, run it at full speed for the
// given number of milliseconds.  This gets the fan spinning reliably
// before setting a PWM value. (Does not work with software PWM for fan on Sanguinololu)
//#define FAN_KICKSTART_TIME 100
// This defines the minimal speed for the main fan, run in PWM mode
// to enable uncomment and set minimal PWM speed for reliable running (1-255)
// if fan speed is [1 - (FAN_MIN_PWM-1)] it is set to FAN_MIN_PWM
//#define FAN_MIN_PWM 50
 * Extruder cooling fans
 * Extruder auto fans automatically turn on when their extruders'
 * temperatures go above EXTRUDER_AUTO_FAN_TEMPERATURE.
 * Your board's pins file specifies the recommended pins. Override those here
 * or set to -1 to disable completely.
 * Multiple extruders can be assigned to the same pin in which case
 * the fan will turn on when any selected extruder is above the threshold.
#define E0_AUTO_FAN_PIN FAN1_PIN
#define E1_AUTO_FAN_PIN -1
#define E2_AUTO_FAN_PIN -1
#define E3_AUTO_FAN_PIN -1
#define EXTRUDER_AUTO_FAN_TEMPERATURE 50
#define EXTRUDER_AUTO_FAN_SPEED   255  // == full speed
// Define a pin to turn case light on/off
//#define CASE_LIGHT_PIN 4
#if PIN_EXISTS(CASE_LIGHT)
  #define INVERT_CASE_LIGHT false   // Set to true if HIGH is the OFF state (active low)
  //#define CASE_LIGHT_DEFAULT_ON   // Uncomment to set default state to on
  //#define MENU_ITEM_CASE_LIGHT    // Uncomment to have a Case Light On / Off entry in main menu
#endif
//============================ Mechanical Settings ==========================
// @section homing
// If you want endstops to stay on (by default) even when not homing
// enable this option. Override at any time with M120, M121.
//#define ENDSTOPS_ALWAYS_ON_DEFAULT
// @section extras
//#define Z_LATE_ENABLE // Enable Z the last moment. Needed if your Z driver overheats.
// Dual X Steppers
// Uncomment this option to drive two X axis motors.
// The next unused E driver will be assigned to the second X stepper.
//#define X_DUAL_STEPPER_DRIVERS
#if ENABLED(X_DUAL_STEPPER_DRIVERS)
  // Set true if the two X motors need to rotate in opposite directions
  #define INVERT_X2_VS_X_DIR true
#endif
// Dual Y Steppers
// Uncomment this option to drive two Y axis motors.
// The next unused E driver will be assigned to the second Y stepper.
//#define Y_DUAL_STEPPER_DRIVERS
#if ENABLED(Y_DUAL_STEPPER_DRIVERS)
  // Set true if the two Y motors need to rotate in opposite directions
  #define INVERT_Y2_VS_Y_DIR true
#endif
// A single Z stepper driver is usually used to drive 2 stepper motors.
// Uncomment this option to use a separate stepper driver for each Z axis motor.
// The next unused E driver will be assigned to the second Z stepper.
//#define Z_DUAL_STEPPER_DRIVERS
#if ENABLED(Z_DUAL_STEPPER_DRIVERS)
  // Z_DUAL_ENDSTOPS is a feature to enable the use of 2 endstops for both Z steppers - Let's call them Z stepper and Z2 stepper.
  // That way the machine is capable to align the bed during home, since both Z steppers are homed.
  // There is also an implementation of M666 (software endstops adjustment) to this feature.
  // After Z homing, this adjustment is applied to just one of the steppers in order to align the bed.
  // One just need to home the Z axis and measure the distance difference between both Z axis and apply the math: Z adjust = Z - Z2.
  // If the Z stepper axis is closer to the bed, the measure Z > Z2 (yes, it is.. think about it) and the Z adjust would be positive.
  // Play a little bit with small adjustments (0.5mm) and check the behaviour.
  // The M119 (endstops report) will start reporting the Z2 Endstop as well.
  //#define Z_DUAL_ENDSTOPS
  #if ENABLED(Z_DUAL_ENDSTOPS)
    #define Z2_USE_ENDSTOP _XMAX_
  #endif
#endif // Z_DUAL_STEPPER_DRIVERS
// Enable this for dual x-carriage printers.
// A dual x-carriage design has the advantage that the inactive extruder can be parked which
// prevents hot-end ooze contaminating the print. It also reduces the weight of each x-carriage
// allowing faster printing speeds. Connect your X2 stepper to the first unused E plug.
//#define DUAL_X_CARRIAGE
#if ENABLED(DUAL_X_CARRIAGE)
  // Configuration for second X-carriage
  // Note: the first x-carriage is defined as the x-carriage which homes to the minimum endstop;
  // the second x-carriage always homes to the maximum endstop.
  #define X2_MIN_POS 80     // set minimum to ensure second x-carriage doesn't hit the parked first X-carriage
  #define X2_MAX_POS 353    // set maximum to the distance between toolheads when both heads are homed
  #define X2_HOME_DIR 1     // the second X-carriage always homes to the maximum endstop position
  #define X2_HOME_POS X2_MAX_POS // default home position is the maximum carriage position
      // However: In this mode the HOTEND_OFFSET_X value for the second extruder provides a software
      // override for X2_HOME_POS. This also allow recalibration of the distance between the two endstops
      // without modifying the firmware (through the "M218 T1 X???" command).
      // Remember: you should set the second extruder x-offset to 0 in your slicer.
  // There are a few selectable movement modes for dual x-carriages using M605 S<mode>
  //    Mode 0 (DXC_FULL_CONTROL_MODE): Full control. The slicer has full control over both x-carriages and can achieve optimal travel results
  //                                    as long as it supports dual x-carriages. (M605 S0)
  //    Mode 1 (DXC_AUTO_PARK_MODE)   : Auto-park mode. The firmware will automatically park and unpark the x-carriages on tool changes so
  //                                    that additional slicer support is not required. (M605 S1)
  //    Mode 2 (DXC_DUPLICATION_MODE) : Duplication mode. The firmware will transparently make the second x-carriage and extruder copy all
  //                                    actions of the first x-carriage. This allows the printer to print 2 arbitrary items at
  //                                    once. (2nd extruder x offset and temp offset are set using: M605 S2 [Xnnn] [Rmmm])
  // This is the default power-up mode which can be later using M605.
  #define DEFAULT_DUAL_X_CARRIAGE_MODE 0
  // Default settings in "Auto-park Mode"
  #define TOOLCHANGE_PARK_ZLIFT   0.2      // the distance to raise Z axis when parking an extruder
  #define TOOLCHANGE_UNPARK_ZLIFT 1        // the distance to raise Z axis when unparking an extruder
  // Default x offset in duplication mode (typically set to half print bed width)
  #define DEFAULT_DUPLICATION_X_OFFSET 100
#endif //DUAL_X_CARRIAGE
// @section homing
//homing hits the endstop, then retracts by this distance, before it tries to slowly bump again:
#define X_HOME_BUMP_MM 5
#define Y_HOME_BUMP_MM 5
#define Z_HOME_BUMP_MM 2
#define HOMING_BUMP_DIVISOR {2, 2, 2}  // Re-Bump Speed Divisor (Divides the Homing Feedrate)
#define QUICK_HOME  //if this is defined, if both x and y are to be homed, a diagonal move will be performed initially.
// When G28 is called, this option will make Y home before X
//#define HOME_Y_BEFORE_X
// @section machine
#define AXIS_RELATIVE_MODES {false, false, false, false}
// Allow duplication mode with a basic dual-nozzle extruder
//#define DUAL_NOZZLE_DUPLICATION_MODE
// By default pololu step drivers require an active high signal. However, some high power drivers require an active low signal as step.
#define INVERT_X_STEP_PIN false
#define INVERT_Y_STEP_PIN false
#define INVERT_Z_STEP_PIN false
#define INVERT_E_STEP_PIN false
// Default stepper release if idle. Set to 0 to deactivate.
// Steppers will shut down DEFAULT_STEPPER_DEACTIVE_TIME seconds after the last move when DISABLE_INACTIVE_? is true.
// Time can be set by M18 and M84.
#define DEFAULT_STEPPER_DEACTIVE_TIME 120
#define DISABLE_INACTIVE_X true
#define DISABLE_INACTIVE_Y true
#define DISABLE_INACTIVE_Z true  // set to false if the nozzle will fall down on your printed part when print has finished.
#define DISABLE_INACTIVE_E true
#define DEFAULT_MINIMUMFEEDRATE       0.0     // minimum feedrate
#define DEFAULT_MINTRAVELFEEDRATE     0.0
// @section lcd
#if ENABLED(ULTIPANEL)
  #define MANUAL_FEEDRATE {50*60, 50*60, 4*60, 60} // Feedrates for manual moves along X, Y, Z, E from panel
  #define ULTIPANEL_FEEDMULTIPLY  // Comment to disable setting feedrate multiplier via encoder
#endif
// @section extras
// minimum time in microseconds that a movement needs to take if the buffer is emptied.
#define DEFAULT_MINSEGMENTTIME        20000
// If defined the movements slow down when the look ahead buffer is only half full
#define SLOWDOWN
// Frequency limit
// See nophead's blog for more info
// Not working O
//#define XY_FREQUENCY_LIMIT  15
// Minimum planner junction speed. Sets the default minimum speed the planner plans for at the end
// of the buffer and all stops. This should not be much greater than zero and should only be changed
// if unwanted behavior is observed on a user's machine when running at very slow speeds.
#define MINIMUM_PLANNER_SPEED 0.05// (mm/sec)
// Microstep setting (Only functional when stepper driver microstep pins are connected to MCU.
#define MICROSTEP_MODES {16,16,16,16,16} // [1,2,4,8,16]
// Motor Current setting (Only functional when motor driver current ref pins are connected to a digital trimpot on supported boards)
#define DIGIPOT_MOTOR_CURRENT {175,175,240,135,135} // Values 0-255 (RAMBO 135 = ~0.75A, 185 = ~1A)
// Motor Current controlled via PWM (Overridable on supported boards with PWM-driven motor driver current)
//#define PWM_MOTOR_CURRENT {1300, 1300, 1250} // Values in milliamps
// uncomment to enable an I2C based DIGIPOT like on the Azteeg X3 Pro
//#define DIGIPOT_I2C
// Number of channels available for I2C digipot, For Azteeg X3 Pro we have 8
#define DIGIPOT_I2C_NUM_CHANNELS 8
// actual motor currents in Amps, need as many here as DIGIPOT_I2C_NUM_CHANNELS
#define DIGIPOT_I2C_MOTOR_CURRENTS {1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0}
//=============================Additional Features===========================
#define ENCODER_RATE_MULTIPLIER         // If defined, certain menu edit operations automatically multiply the steps when the encoder is moved quickly
#define ENCODER_10X_STEPS_PER_SEC 75    // If the encoder steps per sec exceeds this value, multiply steps moved x10 to quickly advance the value
#define ENCODER_100X_STEPS_PER_SEC 160  // If the encoder steps per sec exceeds this value, multiply steps moved x100 to really quickly advance the value
//#define CHDK 4        //Pin for triggering CHDK to take a picture see how to use it here http://captain-slow.dk/2014/03/09/3d-printing-timelapses/
#define CHDK_DELAY 50 //How long in ms the pin should stay HIGH before going LOW again
// @section lcd
// Include a page of printer information in the LCD Main Menu
//#define LCD_INFO_MENU
// On the Info Screen, display XY with one decimal place when possible
//#define LCD_DECIMAL_SMALL_XY
#if ENABLED(SDSUPPORT)
  // Some RAMPS and other boards don't detect when an SD card is inserted. You can work
  // around this by connecting a push button or single throw switch to the pin defined
  // as SD_DETECT_PIN in your board's pins definitions.
  // This setting should be disabled unless you are using a push button, pulling the pin to ground.
  // Note: This is always disabled for ULTIPANEL (except ELB_FULL_GRAPHIC_CONTROLLER).
  #define SD_DETECT_INVERTED
  #define SD_FINISHED_STEPPERRELEASE true  //if sd support and the file is finished: disable steppers?
  #define SD_FINISHED_RELEASECOMMAND "M84 X Y Z E" // You might want to keep the z enabled so your bed stays in place.
  #define SDCARD_RATHERRECENTFIRST  //reverse file order of sd card menu display. Its sorted practically after the file system block order.
  // if a file is deleted, it frees a block. hence, the order is not purely chronological. To still have auto0.g accessible, there is again the option to do that.
  // using:
  //#define MENU_ADDAUTOSTART
  // Show a progress bar on HD44780 LCDs for SD printing
  //#define LCD_PROGRESS_BAR
  #if ENABLED(LCD_PROGRESS_BAR)
    // Amount of time (ms) to show the bar
    #define PROGRESS_BAR_BAR_TIME 2000
    // Amount of time (ms) to show the status message
    #define PROGRESS_BAR_MSG_TIME 3000
    // Amount of time (ms) to retain the status message (0=forever)
    #define PROGRESS_MSG_EXPIRE   0
    // Enable this to show messages for MSG_TIME then hide them
    //#define PROGRESS_MSG_ONCE
    // Add a menu item to test the progress bar:
    //#define LCD_PROGRESS_BAR_TEST
  #endif
  // This allows hosts to request long names for files and folders with M33
  //#define LONG_FILENAME_HOST_SUPPORT
  // This option allows you to abort SD printing when any endstop is triggered.
  // This feature must be enabled with "M540 S1" or from the LCD menu.
  // To have any effect, endstops must be enabled during SD printing.
  //#define ABORT_ON_ENDSTOP_HIT_FEATURE_ENABLED
#endif // SDSUPPORT
 * Additional options for Graphical Displays
 * Use the optimizations here to improve printing performance,
 * which can be adversely affected by graphical display drawing,
 * especially when doing several short moves, and when printing
 * on DELTA and SCARA machines.
 * Some of these options may result in the display lagging behind
 * controller events, as there is a trade-off between reliable
 * printing performance versus fast display updates.
#if ENABLED(DOGLCD)
  // Enable to save many cycles by drawing a hollow frame on the Info Screen
  #define XYZ_HOLLOW_FRAME
  // Enable to save many cycles by drawing a hollow frame on Menu Screens
  #define MENU_HOLLOW_FRAME
  // A bigger font is available for edit items. Costs 3120 bytes of PROGMEM.
  // Western only. Not available for Cyrillic, Kana, Turkish, Greek, or Chinese.
  //#define USE_BIG_EDIT_FONT
  // A smaller font may be used on the Info Screen. Costs 2300 bytes of PROGMEM.
  //#define USE_SMALL_INFOFONT
  // Enable this option and reduce the value to optimize screen updates.
  // The normal delay is 10µs. Use the lowest value that still gives a reliable display.
  //#define DOGM_SPI_DELAY_US 5
#endif // DOGLCD
// @section safety
// The hardware watchdog should reset the microcontroller disabling all outputs,
// in case the firmware gets stuck and doesn't do temperature regulation.
//#define USE_WATCHDOG
#if ENABLED(USE_WATCHDOG)
  // If you have a watchdog reboot in an ArduinoMega2560 then the device will hang forever, as a watchdog reset will leave the watchdog on.
  // The "WATCHDOG_RESET_MANUAL" goes around this by not using the hardware reset.
  //  However, THIS FEATURE IS UNSAFE!, as it will only work if interrupts are disabled. And the code could hang in an interrupt routine with interrupts disabled.
  //#define WATCHDOG_RESET_MANUAL
#endif
// @section lcd
// Babystepping enables the user to control the axis in tiny amounts, independently from the normal printing process
// it can e.g. be used to change z-positions in the print startup phase in real-time
// does not respect endstops!
//#define BABYSTEPPING
#if ENABLED(BABYSTEPPING)
  #define BABYSTEP_XY  //not only z, but also XY in the menu. more clutter, more functions
                       //not implemented for deltabots!
  #define BABYSTEP_INVERT_Z false  //true for inverse movements in Z
  #define BABYSTEP_MULTIPLICATOR 1 //faster movements
#endif
// extruder advance constant (s2/mm3)
// advance (steps) = STEPS_PER_CUBIC_MM_E * EXTRUDER_ADVANCE_K * cubic mm per second ^ 2
// Hooke's law says:    force = k * distance
// Bernoulli's principle says:  v ^ 2 / 2 + g . h + pressure / density = constant
// so: v ^ 2 is proportional to number of steps we advance the extruder
//#define ADVANCE
#if ENABLED(ADVANCE)
  #define EXTRUDER_ADVANCE_K .0
  #define D_FILAMENT 2.85
#endif
 * Implementation of linear pressure control
 * Assumption: advance = k * (delta velocity)
 * K=0 means advance disabled.
 * See Marlin documentation for calibration instructions.
#define LIN_ADVANCE
#if ENABLED(LIN_ADVANCE)
  #define LIN_ADVANCE_K 110 // WAS 75 sebastian recs 110 for pla hex extruder
#endif
// @section leveling
// Default mesh area is an area with an inset margin on the print area.
// Below are the macros that are used to define the borders for the mesh area,
// made available here for specialized needs, ie dual extruder setup.
  #define MESH_MIN_X (X_MIN_POS + MESH_INSET)
  #define MESH_MAX_X (X_MAX_POS - (MESH_INSET))
  #define MESH_MIN_Y (Y_MIN_POS + MESH_INSET)
  #define MESH_MAX_Y (Y_MAX_POS - (MESH_INSET))
#endif
// @section extras
// Arc interpretation settings:
#define ARC_SUPPORT  // Disabling this saves ~2738 bytes
#define MM_PER_ARC_SEGMENT 1
#define N_ARC_CORRECTION 25
// Support for G5 with XYZE destination and IJPQ offsets. Requires ~2666 bytes.
//#define BEZIER_CURVE_SUPPORT
// G38.2 and G38.3 Probe Target
//#define G38_PROBE_TARGET
#if ENABLED(G38_PROBE_TARGET)
  #define G38_MINIMUM_MOVE 0.0275 // minimum distance in mm that will produce a move (determined using the print statement in check_move)
#endif
// Moves (or segments) with fewer steps than this will be joined with the next move
#define MIN_STEPS_PER_SEGMENT 5
// The minimum pulse width (in µs) for stepping a stepper.
// Set this if you find stepping unreliable, or if using a very fast CPU.
#define MINIMUM_STEPPER_PULSE 0 // (µs) The smallest stepper pulse allowed
// @section temperature
// Control heater 0 and heater 1 in parallel.
//#define HEATERS_PARALLEL
//================================= Buffers =================================
// @section hidden
// The number of linear motions that can be in the plan at any give time.
// THE BLOCK_BUFFER_SIZE NEEDS TO BE A POWER OF 2, i.g. 8,16,32 because shifts and ors are used to do the ring-buffering.
  #define BLOCK_BUFFER_SIZE 16 // SD,LCD,Buttons take more memory, block buffer needs to be smaller
#else
  #define BLOCK_BUFFER_SIZE 16 // maximize block buffer
#endif
// @section serial
// The ASCII buffer for serial input
#define MAX_CMD_SIZE 96
#define BUFSIZE 4
// Transfer Buffer Size
// To save 386 bytes of PROGMEM (and TX_BUFFER_SIZE+3 bytes of RAM) set to 0.
// To buffer a simple "ok" you need 4 bytes.
// For ADVANCED_OK (M105) you need 32 bytes.
// For debug-echo: 128 bytes for the optimal speed.
// Other output doesn't need to be that speedy.
// :[0, 2, 4, 8, 16, 32, 64, 128, 256]
#define TX_BUFFER_SIZE 0
// Enable an emergency-command parser to intercept certain commands as they
// enter the serial receive buffer, so they cannot be blocked.
// Currently handles M108, M112, M410
// Does not work on boards using AT90USB (USBCON) processors!
//#define EMERGENCY_PARSER
// Bad Serial-connections can miss a received command by sending an 'ok'
// Therefore some clients abort after 30 seconds in a timeout.
// Some other clients start sending commands while receiving a 'wait'.
// This "wait" is only sent when the buffer is empty. 1 second is a good value here.
//#define NO_TIMEOUTS 1000 // Milliseconds
// Some clients will have this feature soon. This could make the NO_TIMEOUTS unnecessary.
//#define ADVANCED_OK
// @section fwretract
// Firmware based and LCD controlled retract
// M207 and M208 can be used to define parameters for the retraction.
// The retraction can be called by the slicer using G10 and G11
// until then, intended retractions can be detected by moves that only extrude and the direction.
// the moves are than replaced by the firmware controlled ones.
#define FWRETRACT  //ONLY PARTIALLY TESTED
#if ENABLED(FWRETRACT)
  #define MIN_RETRACT 0.1                //minimum extruded mm to accept a automatic gcode retraction attempt
  #define RETRACT_LENGTH .75               //default retract length (positive mm)
  #define RETRACT_LENGTH_SWAP 13         //default swap retract length (positive mm), for extruder change
  #define RETRACT_FEEDRATE 40            //default feedrate for retracting (mm/s)
  #define RETRACT_ZLIFT 0                //default retract Z-lift
  #define RETRACT_RECOVER_LENGTH 0       //default additional recover length (mm, added to retract length when recovering)
  #define RETRACT_RECOVER_LENGTH_SWAP 0  //default additional swap recover length (mm, added to retract length when recovering from extruder change)
  #define RETRACT_RECOVER_FEEDRATE 8     //default feedrate for recovering from retraction (mm/s)
#endif
 * Filament Change
 * Experimental filament change support.
 * Adds the GCode M600 for initiating filament change.
 * Requires an LCD display.
 * This feature is required for the default FILAMENT_RUNOUT_SCRIPT.
//#define FILAMENT_CHANGE_FEATURE
#if ENABLED(FILAMENT_CHANGE_FEATURE)
  #define FILAMENT_CHANGE_X_POS 3             // X position of hotend
  #define FILAMENT_CHANGE_Y_POS 3             // Y position of hotend
  #define FILAMENT_CHANGE_Z_ADD 10            // Z addition of hotend (lift)
  #define FILAMENT_CHANGE_XY_FEEDRATE 100     // X and Y axes feedrate in mm/s (also used for delta printers Z axis)
  #define FILAMENT_CHANGE_Z_FEEDRATE 5        // Z axis feedrate in mm/s (not used for delta printers)
  #define FILAMENT_CHANGE_RETRACT_LENGTH 2    // Initial retract in mm
                                              // It is a short retract used immediately after print interrupt before move to filament exchange position
  #define FILAMENT_CHANGE_RETRACT_FEEDRATE 60 // Initial retract feedrate in mm/s
  #define FILAMENT_CHANGE_UNLOAD_LENGTH 100   // Unload filament length from hotend in mm
                                              // Longer length for bowden printers to unload filament from whole bowden tube,
                                              // shorter lenght for printers without bowden to unload filament from extruder only,
                                              // 0 to disable unloading for manual unloading
  #define FILAMENT_CHANGE_UNLOAD_FEEDRATE 10  // Unload filament feedrate in mm/s - filament unloading can be fast
  #define FILAMENT_CHANGE_LOAD_LENGTH 0       // Load filament length over hotend in mm
                                              // Longer length for bowden printers to fast load filament into whole bowden tube over the hotend,
                                              // Short or zero length for printers without bowden where loading is not used
  #define FILAMENT_CHANGE_LOAD_FEEDRATE 10    // Load filament feedrate in mm/s - filament loading into the bowden tube can be fast
  #define FILAMENT_CHANGE_EXTRUDE_LENGTH 50   // Extrude filament length in mm after filament is load over the hotend,
                                              // 0 to disable for manual extrusion
                                              // Filament can be extruded repeatedly from the filament exchange menu to fill the hotend,
                                              // or until outcoming filament color is not clear for filament color change
  #define FILAMENT_CHANGE_EXTRUDE_FEEDRATE 3  // Extrude filament feedrate in mm/s - must be slower than load feedrate
#endif
 * enable this section if you have TMC26X motor drivers.
 * you need to import the TMC26XStepper library into the Arduino IDE for this
// @section tmc
//#define HAVE_TMCDRIVER
#if ENABLED(HAVE_TMCDRIVER)
  //#define X_IS_TMC
  //#define X2_IS_TMC
  //#define Y_IS_TMC
  //#define Y2_IS_TMC
  //#define Z_IS_TMC
  //#define Z2_IS_TMC
  //#define E0_IS_TMC
  //#define E1_IS_TMC
  //#define E2_IS_TMC
  //#define E3_IS_TMC
  #define X_MAX_CURRENT     1000 // in mA
  #define X_SENSE_RESISTOR    91 // in mOhms
  #define X_MICROSTEPS        16 // number of microsteps
  #define X2_MAX_CURRENT    1000
  #define X2_SENSE_RESISTOR   91
  #define X2_MICROSTEPS       16
  #define Y_MAX_CURRENT     1000
  #define Y_SENSE_RESISTOR    91
  #define Y_MICROSTEPS        16
  #define Y2_MAX_CURRENT    1000
  #define Y2_SENSE_RESISTOR   91
  #define Y2_MICROSTEPS       16
  #define Z_MAX_CURRENT     1000
  #define Z_SENSE_RESISTOR    91
  #define Z_MICROSTEPS        16
  #define Z2_MAX_CURRENT    1000
  #define Z2_SENSE_RESISTOR   91
  #define Z2_MICROSTEPS       16
  #define E0_MAX_CURRENT    1000
  #define E0_SENSE_RESISTOR   91
  #define E0_MICROSTEPS       16
  #define E1_MAX_CURRENT    1000
  #define E1_SENSE_RESISTOR   91
  #define E1_MICROSTEPS       16
  #define E2_MAX_CURRENT    1000
  #define E2_SENSE_RESISTOR   91
  #define E2_MICROSTEPS       16
  #define E3_MAX_CURRENT    1000
  #define E3_SENSE_RESISTOR   91
  #define E3_MICROSTEPS       16
#endif
// @section TMC2130
 * Enable this for SilentStepStick Trinamic TMC2130 SPI-configurable stepper drivers.
 * To use TMC2130 drivers in SPI mode, you'll also need the TMC2130 Arduino library
 * (https://github.com/makertum/Trinamic_TMC2130).
 * To use TMC2130 stepper drivers in SPI mode connect your SPI2130 pins to
 * the hardware SPI interface on your board and define the required CS pins
 * in your `pins_MYBOARD.h` file. (e.g., RAMPS 1.4 uses AUX3 pins `X_CS_PIN 53`, `Y_CS_PIN 49`, etc.).
//#define HAVE_TMC2130DRIVER
#if ENABLED(HAVE_TMC2130DRIVER)
  //#define TMC2130_ADVANCED_CONFIGURATION
  // CHOOSE YOUR MOTORS HERE, THIS IS MANDATORY
  //#define X_IS_TMC2130
  //#define X2_IS_TMC2130
  //#define Y_IS_TMC2130
  //#define Y2_IS_TMC2130
  //#define Z_IS_TMC2130
  //#define Z2_IS_TMC2130
  //#define E0_IS_TMC2130
  //#define E1_IS_TMC2130
  //#define E2_IS_TMC2130
  //#define E3_IS_TMC2130
  #if ENABLED(TMC2130_ADVANCED_CONFIGURATION)
    // If you've enabled TMC2130_ADVANCED_CONFIGURATION, define global settings below.
    // Enabled settings will be automatically applied to all axes specified above.
    // Please read the TMC2130 datasheet:
    // http://www.trinamic.com/_articles/products/integrated-circuits/tmc2130/_datasheet/TMC2130_datasheet.pdf
    // All settings here have the same (sometimes cryptic) names as in the datasheet.
    // The following, uncommented settings are only suggestion.
    /* GENERAL CONFIGURATION */
    //#define GLOBAL_EN_PWM_MODE        0
    #define GLOBAL_I_SCALE_ANALOG     1 // [0,1] 0: Normal, 1: AIN
    //#define GLOBAL_INTERNAL_RSENSE    0 // [0,1] 0: Normal, 1: Internal
    #define GLOBAL_EN_PWM_MODE        0 // [0,1] 0: Normal, 1: stealthChop with velocity threshold
    //#define GLOBAL_ENC_COMMUTATION    0 // [0,1]
    #define GLOBAL_SHAFT              0 // [0,1] 0: normal, 1: invert
    //#define GLOBAL_DIAG0_ERROR        0 // [0,1]
    //#define GLOBAL_DIAG0_OTPW         0 // [0,1]
    //#define GLOBAL_DIAG0_STALL        0 // [0,1]
    //#define GLOBAL_DIAG1_STALL        0 // [0,1]
    //#define GLOBAL_DIAG1_INDEX        0 // [0,1]
    //#define GLOBAL_DIAG1_ONSTATE      0 // [0,1]
    //#define GLOBAL_DIAG0_INT_PUSHPULL 0 // [0,1]
    //#define GLOBAL_DIAG1_INT_PUSHPULL 0 // [0,1]
    //#define GLOBAL_SMALL_HYSTERESIS   0 // [0,1]
    //#define GLOBAL_STOP_ENABLE        0 // [0,1]
    //#define GLOBAL_DIRECT_MODE        0 // [0,1]
    /* VELOCITY-DEPENDENT DRIVE FEATURES */
    #define GLOBAL_IHOLD             22 // [0-31] 0: min, 31: max
    #define GLOBAL_IRUN              31 // [0-31] 0: min, 31: max
    #define GLOBAL_IHOLDDELAY        15 // [0-15] 0: min, 15: about 4 seconds
    //#define GLOBAL_TPOWERDOWN         0 // [0-255] 0: min, 255: about 4 seconds
    //#define GLOBAL_TPWMTHRS           0 // [0-1048576] e.g. 20 corresponds with 2000 steps/s
    //#define GLOBAL_TCOOLTHRS          0 // [0-1048576] e.g. 20 corresponds with 2000 steps/s
    #define GLOBAL_THIGH             10 // [0-1048576] e.g. 20 corresponds with 2000 steps/s
    /* SPI MODE CONFIGURATION */
    //#define GLOBAL_XDIRECT            0
    /* DCSTEP MINIMUM VELOCITY */
    //#define GLOBAL_VDCMIN             0
    /* MOTOR DRIVER CONFIGURATION*/
    //#define GLOBAL_DEDGE              0
    //#define GLOBAL_DISS2G             0
    #define GLOBAL_INTPOL             1 // 0: off 1: 256 microstep interpolation
    #define GLOBAL_MRES              16 // number of microsteps
    #define GLOBAL_SYNC               1 // [0-15]
    #define GLOBAL_VHIGHCHM           1 // [0,1] 0: normal, 1: high velocity stepper mode
    #define GLOBAL_VHIGHFS            0 // [0,1] 0: normal, 1: switch to full steps for high velocities
    // #define GLOBAL_VSENSE            0 // [0,1] 0: normal, 1: high sensitivity (not recommended)
    #define GLOBAL_TBL                1 // 0-3: set comparator blank time to 16, 24, 36 or 54 clocks, 1 or 2 is recommended
    #define GLOBAL_CHM                0 // [0,1] 0: spreadCycle, 1: Constant off time with fast decay time.
    //#define GLOBAL_RNDTF              0
    //#define GLOBAL_DISFDCC            0
    //#define GLOBAL_FD                 0
    //#define GLOBAL_HEND               0
    //#define GLOBAL_HSTRT              0
    #define GLOBAL_TOFF              10 // 0: driver disable, 1: use only with TBL>2, 2-15: off time setting during slow decay phase
    //#define GLOBAL_SFILT              0
    //#define GLOBAL_SGT                0
    //#define GLOBAL_SEIMIN             0
    //#define GLOBAL_SEDN               0
    //#define GLOBAL_SEMAX              0
    //#define GLOBAL_SEUP               0
    //#define GLOBAL_SEMIN              0
    //#define GLOBAL_DC_TIME            0
    //#define GLOBAL_DC_SG              0
    //#define GLOBAL_FREEWHEEL          0
    //#define GLOBAL_PWM_SYMMETRIC      0
    //#define GLOBAL_PWM_AUTOSCALE      0
    //#define GLOBAL_PWM_FREQ           0
    //#define GLOBAL_PWM_GRAD           0
    //#define GLOBAL_PWM_AMPL           0
    //#define GLOBAL_ENCM_CTRL          0
  #else
    #define X_IHOLD          31 // [0-31] 0: min, 31: max
    #define X_IRUN           31 // [0-31] 0: min, 31: max
    #define X_IHOLDDELAY     15 // [0-15] 0: min, 15: about 4 seconds
    #define X_I_SCALE_ANALOG  1 // 0: Normal, 1: AIN
    #define X_MRES           16 // number of microsteps
    #define X_TBL             1 // 0-3: set comparator blank time to 16, 24, 36 or 54 clocks, 1 or 2 is recommended
    #define X_TOFF            8 // 0: driver disable, 1: use only with TBL>2, 2-15: off time setting during slow decay phase
    #define X2_IHOLD         31
    #define X2_IRUN          31
    #define X2_IHOLDDELAY    15
    #define X2_I_SCALE_ANALOG 1
    #define X2_MRES          16
    #define X2_TBL            1
    #define X2_TOFF           8
    #define Y_IHOLD          31
    #define Y_IRUN           31
    #define Y_IHOLDDELAY     15
    #define Y_I_SCALE_ANALOG  1
    #define Y_MRES           16
    #define Y_TBL             1
    #define Y_TOFF            8
    #define Y2_IHOLD         31
    #define Y2_IRUN          31
    #define Y2_IHOLDDELAY    15
    #define Y2_I_SCALE_ANALOG 1
    #define Y2_MRES          16
    #define Y2_TBL            1
    #define Y2_TOFF           8
    #define Z_IHOLD          31
    #define Z_IRUN           31
    #define Z_IHOLDDELAY     15
    #define Z_I_SCALE_ANALOG  1
    #define Z_MRES           16
    #define Z_TBL             1
    #define Z_TOFF            8
    #define Z2_IHOLD         31
    #define Z2_IRUN          31
    #define Z2_IHOLDDELAY    15
    #define Z2_I_SCALE_ANALOG 1
    #define Z2_MRES          16
    #define Z2_TBL            1
    #define Z2_TOFF           8
    #define E0_IHOLD         31
    #define E0_IRUN          31
    #define E0_IHOLDDELAY    15
    #define E0_I_SCALE_ANALOG 1
    #define E0_MRES          16
    #define E0_TBL            1
    #define E0_TOFF           8
    #define E1_IHOLD         31
    #define E1_IRUN          31
    #define E1_IHOLDDELAY    15
    #define E1_I_SCALE_ANALOG 1
    #define E1_MRES          16
    #define E1_TBL            1
    #define E1_TOFF           8
    #define E2_IHOLD         31
    #define E2_IRUN          31
    #define E2_IHOLDDELAY    15
    #define E2_I_SCALE_ANALOG 1
    #define E2_MRES          16
    #define E2_TBL            1
    #define E2_TOFF           8
    #define E3_IHOLD         31
    #define E3_IRUN          31
    #define E3_IHOLDDELAY    15
    #define E3_I_SCALE_ANALOG 1
    #define E3_MRES          16
    #define E3_TBL            1
    #define E3_TOFF           8
  #endif // TMC2130_ADVANCED_CONFIGURATION
#endif // HAVE_TMC2130DRIVER
// @section L6470
 * Enable this section if you have L6470 motor drivers.
 * You need to import the L6470 library into the Arduino IDE for this.
 * (https://github.com/ameyer/Arduino-L6470)
//#define HAVE_L6470DRIVER
#if ENABLED(HAVE_L6470DRIVER)
  //#define X_IS_L6470
  //#define X2_IS_L6470
  //#define Y_IS_L6470
  //#define Y2_IS_L6470
  //#define Z_IS_L6470
  //#define Z2_IS_L6470
  //#define E0_IS_L6470
  //#define E1_IS_L6470
  //#define E2_IS_L6470
  //#define E3_IS_L6470
  #define X_K_VAL           50 // 0 - 255, Higher values, are higher power. Be careful not to go too high
  #define X_OVERCURRENT   2000 // maxc current in mA. If the current goes over this value, the driver will switch off
  #define X_STALLCURRENT  1500 // current in mA where the driver will detect a stall
  #define X2_K_VAL          50
  #define X2_OVERCURRENT  2000
  #define X2_STALLCURRENT 1500
  #define Y_K_VAL           50
  #define Y_OVERCURRENT   2000
  #define Y_STALLCURRENT  1500
  #define Y2_K_VAL          50
  #define Y2_OVERCURRENT  2000
  #define Y2_STALLCURRENT 1500
  #define Z_K_VAL           50
  #define Z_OVERCURRENT   2000
  #define Z_STALLCURRENT  1500
  #define Z2_K_VAL          50
  #define Z2_OVERCURRENT  2000
  #define Z2_STALLCURRENT 1500
  #define E0_K_VAL          50
  #define E0_OVERCURRENT  2000
  #define E0_STALLCURRENT 1500
  #define E1_K_VAL          50
  #define E1_OVERCURRENT  2000
  #define E1_STALLCURRENT 1500
  #define E2_K_VAL          50
  #define E2_OVERCURRENT  2000
  #define E2_STALLCURRENT 1500
  #define E3_K_VAL          50
  #define E3_OVERCURRENT  2000
  #define E3_STALLCURRENT 1500
#endif
 * TWI/I2C BUS
 * This feature is an EXPERIMENTAL feature so it shall not be used on production
 * machines. Enabling this will allow you to send and receive I2C data from slave
 * devices on the bus.
 * ; Example #1
 * ; This macro send the string "Marlin" to the slave device with address 0x63 (99)
 * ; It uses multiple M260 commands with one B<base 10> arg
 * M260 A99  ; Target slave address
 * M260 B77  ; M
 * M260 B97  ; a
 * M260 B114 ; r
 * M260 B108 ; l
 * M260 B105 ; i
 * M260 B110 ; n
 * M260 S1   ; Send the current buffer
 * ; Example #2
 * ; Request 6 bytes from slave device with address 0x63 (99)
 * M261 A99 B5
 * ; Example #3
 * ; Example serial output of a M261 request
 * echo:i2c-reply: from:99 bytes:5 data:hello
// @section i2cbus
//#define EXPERIMENTAL_I2CBUS
#define I2C_SLAVE_ADDRESS  0 // Set a value from 8 to 127 to act as a slave
 * Add M43 command for pins info and testing
//#define PINS_DEBUGGING
 * Auto-report temperatures with M155 S<seconds>
//#define AUTO_REPORT_TEMPERATURES
 * Include capabilities in M115 output
//#define EXTENDED_CAPABILITIES_REPORT
#endif // CONFIGURATION_ADV_H
Sebastian
Re: Latest Firmware for TAZ5 - advanced development version
Post by Sebastian » Thu Jan 19, 2017 12:35 pm
Thanks, I will do further tests on weekend. I will find no time until then :?
billyd
Post by billyd » Thu Jan 19, 2017 10:32 pm
It's really odd because I was able to get through these prints before.
I reset my thermal runaway parameters to stock and redid the PIDS and I am trying the print again. For the first 3 hours everything is fine.
This could be a problem with my printer. I have no idea what it could be though. Everything seems perfect right now.
billyd
Post by billyd » Sat Jan 28, 2017 9:33 am
Turned out to be my extruder thermistor sorry for the trouble sebastian. Bad luck that it failed right after upgrading.
Sebastian
Post by Sebastian » Mon Feb 13, 2017 10:29 am
If someone else still has problems, there is a bad bug I introduced when I changed the behaviour of the Marlin temperature and stepper interrupt service routines. It could lead to wrong temperature readings (resulting in spikes visible in the temp. graph or even min./max. temp errors where the printer stops) and even complete printer freezing.
This, and another (in my opinion not bug-related) thing can now be fixed with a PR I created yesterday for Marlin. If you want to have one code set with this updates already built into it, you can download the code from my repository here. This one is not configured specific for the TAZ, but if you want to start with my config for TAZ5 as a baseline, you can grab the Configuration.h and Configuration_adv.h files from here. Just copy and paste it over the existing ones from the first link.
Sorry for this, I think now it should be stable again even in prints that takes days to finish. I'm just finishing a pangolin that took over 11h.
IceDragonIDGN
Post by IceDragonIDGN » Thu Apr 13, 2017 10:49 pm
I'm new to the forum and the Taz line in general, but kind of getting to be a bit more knowledgeable on 3D printers and working on them. I wanted to say thank you for all the helpful information and HOURS of work and insight you've shared. I'm working on a Taz 5 system for a buddy. The Taz 5 is a great printer, but some of the firmware and wiring has been temperamental and painful to work on since it's just a hair different from other printers I've worked on. So seriously appreciate the advice and files. Cheers!
aliasmeum
Post by aliasmeum » Thu Jul 06, 2017 4:05 pm
Hello, and thank you for the tremendous effort that all off you put into development, and helping others on this forum!
I am in the start of trying to learn how to edit and update the firmware for my Taz5. Until now, I have only updated the firmware from Cura. I just finished reading through this entire topic and are looking forward to try this firmware.
I tried to copy and paste the configuration files like Sebastian describes here:
Sebastian wrote:If someone else still has problems, there is a bad bug I introduced when I changed the behaviour of the Marlin temperature and stepper interrupt service routines. It could lead to wrong temperature readings (resulting in spikes visible in the temp. graph or even min./max. temp errors where the printer stops) and even complete printer freezing.
In Arduino IDE I can compile the code downloaded from the repository, but after replacing the configuration files it will not compile. I get the following error messages:
"Arduino: 1.8.3 (Linux), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
sketch/Marlin_main.cpp: In function 'void filament_change_beep()':
Marlin_main.cpp:7312: error: 'FILAMENT_CHANGE_NUMBER_OF_ALERT_BEEPS' was not declared in this scope
if (runout_beep <= FILAMENT_CHANGE_NUMBER_OF_ALERT_BEEPS + 5) { // Only beep as long as we're supposed to
sketch/Marlin_main.cpp: In function 'void gcode_M600()':
Marlin_main.cpp:7423: error: 'FILAMENT_CHANGE_NOZZLE_TIMEOUT' was not declared in this scope
millis_t nozzle_timeout = millis() + FILAMENT_CHANGE_NOZZLE_TIMEOUT * 1000L;
exit status 1
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
I hope someone can tell me what I need to do to make the firmware compile, or point me in the direction of another working firmware, if this one is to complicated for a beginner like me.
Regards Robert
