Hello,
I clicked the control window in the Cura 21.03 version on windows and it won’t open the settings so I can change filament and modify all of the temperatures. I’m not sure what to do. I was looking in the other forums and found the answer for another individual was the windows 8.1 version as opposed to older versions.
Could this be the problem? What should I do for windows 7?
Thanks
Additional information: I am using the Taz6 and have a 64 bit windows 7 system.
Cheers,
Sandersj1
what do you mean by “it won’t open the settings” ?
It should open the control dialog, with a port so you can select and connect to your printer.
Take print screens because i have no ideia what you are trying to say, and you are also posint on the incorrect place of the forum, it should be Board index / General / Software as this has nothing to do with development of new software.
