Marlin 1.1 config for TAZ6?
marcio
Re: Marlin 1.1 config for TAZ6?
Post by marcio » Fri Sep 29, 2017 1:40 pm
nuroo wrote:
Fri Sep 29, 2017 12:57 pm
Marcio,
I would love to have the new features of 1.1.5.x and 4 point bed leveling, if only to compare. But i'll need to compile the firmware myself? b4 i downloaded hex and updated in Cura. Is there a guide?
Just this once, I've attached two firmware files for you to compare...
marcio
Post by marcio » Fri Sep 29, 2017 1:46 pm
For the TAZ 6...
nuroo
Post by nuroo » Fri Sep 29, 2017 1:48 pm
Marcio,
Marlin_Mini_SingleExtruder_Three_Point_Leveling_1.1.5.15_324c87767.hex.txt
Marlin_Mini_SingleExtruder_1.1.5.15_four_point_leveling_324c87767.hex.txt
You are the man.......Thanks alot.
nuroo
Post by nuroo » Fri Sep 29, 2017 1:49 pm
I have Taz6, firmware says MINI?
marcio
Post by marcio » Fri Sep 29, 2017 1:50 pm
See above. I caught my mistake and reposted :)
nuroo
Post by nuroo » Fri Sep 29, 2017 2:32 pm
Marlin_TAZ6_SingleExtruder_1.1.5.15a_four_point_leveling_324c87767.hex
(Probes out of order, as mentioned ------ but works so who cares)
Im still adjusting to find a good z offset. But problem solved.
Even with this preliminary z offset (-1.100) which is too high. Started high just incase problems. All of the squares are same squish, even the rear left.
nuroo
Post by nuroo » Fri Sep 29, 2017 3:14 pm
Code: Select all
< Setting Print and Travel Acceleration: 100.00
< ok N42 P3 B2
< Bilinear Leveling Grid:
<       0      1
0 -0.051 +1.524
<  1 +0.799 +0.806
< X:288.00 Y:289.00 Z:6.15 E:-20.00 Count X:28944 Y:29045 Z:11130
< ok N43 P15 B1
< Setting Print and Travel Acceleration: 500.00
< ok N44 P15 B2
< ok N45 P14 B3
< ok N46 P15 B1
< ok N47 P15 B1
< ok N48 P15 B2
< ok N49 P15 B3
I remember it used to give you the deviation (which turns out was ok after all) of your build plate in the console after it probed the points. But this is now better leveled then old firmware. Impressive !
Rp1030
Post by Rp1030 » Fri Oct 13, 2017 9:11 pm
Guya this might be a stupid question, but. how do ypu download the firmware from here?
https://code.alephobjects.com/diffusion ... wse/devel/
nuroo
Post by nuroo » Fri Oct 13, 2017 9:17 pm
Rp1030
Post by Rp1030 » Fri Oct 13, 2017 10:31 pm
https://devel.lulzbot.com/software/Marlin/
I'm looking for a file that i can modify and enable g29 though
