Cura2 LulzBot Edition Beta Testers Needed!
masto
Re: Cura2 LulzBot Edition Beta Testers Needed!
Post by masto » Fri Dec 08, 2017 8:53 am
masto wrote:
Sun Nov 19, 2017 3:32 pm
material_bed_temperature is still set to 85 in quality/lulzbot_mini/HIPS_(Village_Plastics)_*.cfg in 2.6.43. I'm still overriding this setting to 110 in order to prevent failed prints, as well as removing the "Flow Temperature Graph" setting. I think Lulzbot have moved away from HIPS, but it's still the material of choice for our makerspace so it would be great to see this profile work correctly out of the box.
I'm disappointed to see that the version was released with this simple mistake in the config, reported months ago, still present. This will prevent anyone from successfully printing with HIPS unless they know which settings to override. :-(
Brent.I
Post by Brent.I » Fri Dec 08, 2017 10:43 am
We specifically lowered the bed temp to 85c to prevent the yellowing of the base layer on longer prints. Through our testing we have found a glue stick on PEI at 85c does a great job! You can find details on this post: viewtopic.php?t=6947
nuroo
Post by nuroo » Mon Feb 26, 2018 7:44 am
Cura 3.2.8
After putting in the API key for Octoprint, then -
Try to uncheck "the start as soon as uploaded" for Octoprint, Cura program crashes.
nuroo
Post by nuroo » Tue Feb 27, 2018 7:23 pm
3.2.9
Brent.I
Post by Brent.I » Wed Feb 28, 2018 9:45 am
Cura 3.2.8
We're sorry to hear about the issues. The Cura LE 3.2.x branch is in early alpha at the moment, and every report helps us get this program in a better position. If you can pull an error log from the crash, it will greatly help us track it down. We are currently logging 3.2.x critical failures here: https://code.alephobjects.com/T1273
In windows it will be:
\Users\<username>\AppData\Local\cura-lulzbot\2.6\cura-lulzbot.log
or \Users\<username>\AppData\Roaming\cura-lulzbot\2.6\cura-lulzbot.log
Linux: /home/<username>/.local/share/cura-lulzbot/2.6/cura-lulzbot.log
Mac: /Users/<username>/Library/Application Support/cura-lulzbot/2.6/cura-lulzbot.log
We appreciate the help!
nuroo
Post by nuroo » Sat Mar 24, 2018 5:31 pm
3.2.14
log was not where u said, i found it here:
Users/<username>/AppData/Roaming/cura-lulzbot/3.2
2018-03-24 19:06:07,475 - CRITICAL - [(31964)-MainThread] cura.CrashHandler.__init__ [61]: An uncaught error has occurred!
2018-03-24 19:06:07,476 - CRITICAL - [(31964)-MainThread] cura.CrashHandler.__init__ [64]: Traceback (most recent call last):
2018-03-24 19:06:07,477 - CRITICAL - [(31964)-MainThread] cura.CrashHandler.__init__ [64]: File "d:\Program Files (x86)\cura-lulzbot 3.2\plugins\OctoPrintPlugin\DiscoverOctoPrintAction.py", line 202, in setContainerMetaDataEntry
2018-03-24 19:06:07,478 - CRITICAL - [(31964)-MainThread] cura.CrashHandler.__init__ [64]: containers = ContainerRegistry.getInstance().findContainers(None, id = container_id)
2018-03-24 19:06:07,479 - CRITICAL - [(31964)-MainThread] cura.CrashHandler.__init__ [64]: TypeError: findContainers() takes 1 positional argument but 2 were given
my log attached
cura-lulzbot.log
(322.37 KiB) Downloaded 44 times
nuroo
Post by nuroo » Tue Apr 03, 2018 6:36 pm
3.2.16
Biolumo
Contact:
Post by Biolumo » Fri Apr 20, 2018 1:54 pm
Well i've tried it and to be very blunt it sucks. I realize it probably has a lot of improvements to features like probably honeycomb infill pattern or stuff like that but the old cura version was MUCH better. Was easier on the eyes, and used less resources on the computer itself thereby not slowing down old computers who lacked memory or speed.
Go back to the old light version of cura! Or create a new light version of cura for those of us who hate the new one. You don't need to copy everything ultimaker does in terms of software.
