Cura2 z-height adjustment
jlund
Post by jlund » Tue Nov 28, 2017 2:38 am
In Lulzbot Cura I can offset z slightly in machine settings to reduce squished first layer. How can I do this in Cura2 where that option seems to be removed? :o
@home: Printrbot Jr. V2 kit, Lulzbot Mini, Flexystruder V2, Prusa I3 MK3 kit
@work: Lulzbot TAZ6, Flexydually V2
kmanley57
Re: Cura2 z-height adjustment
Post by kmanley57 » Tue Nov 28, 2017 7:17 am
I use M851 Z-1.10 in the command line of the console window for Cura. Then M500 to store the new value in EEPROM.
jlund
Post by jlund » Tue Nov 28, 2017 2:16 pm
Thanks, I will put it in start g-code instead then, as I print via Octopi and the setting generally is better across materials.
Hmm, I miss the same option with setting a general custom E-Steps value for a machine specific tool head - I guess it can go into start g-code as well then.
