Marlin 1.1.8.59 On Original (not V2) Lulzbot Mini
mikehill85
Post by mikehill85 » Wed Jul 04, 2018 7:52 am
Apologies if this has been answered somewhere else. I did search the forums but didn't find an answer. I am trying to install Marlin 1.1.8.59 on my original Lulzbot Mini. I modified my Mini to have an E3DV6 1.75mm hotend along with a Titan extruder. I, therefore, need to make adjustments to the Y minimum position among other things (e.g. inverting the extruder direction (which I realize can be done with hardware instead)).
I reached out to tech support to ask them if they had the Marlin firmware files which could be edited and flashed with Arduino to the machine but they said that "the simplest way to flash your firmware is through Cura or manually by downloading the hex file." and that "Any changes to firmware is unsupported...don't change your hardware or software...blah blah blah" despite the fact that an earlier version of the Marlin firmware files came with the original flash drive which accompanied my machine (e.g. http://download.lulzbot.com/Mini/1.04/s ... re/Source/).
My main question is does anyone know where I can find these files? Tech support did point me to these files https://code.alephobjects.com/diffusion/MARLIN/,however, I am not sure which of the branches is 1.18.59. This one https://code.alephobjects.com/diffusion ... eam_1.1.8/?
Also, I am wondering why there is a .config file with the .hex files (which can be flashed through Cura). Is the .config file simply the configuration.h file which can be flashed with Arduino or is there a way that the .config file can modify the .hex file which I am unaware of?
Any help with this would be much appreciated. While I am impressed with how quickly tech support responded to my questions, I am underwhelmed by the fact they are selling a printer which runs on open source firmware, is well documented and basically designed for modding but tell you to get lost if you ask them how to flash the latest firmware in a format which could have been modded.
mrvanes
Re: Marlin 1.1.8.59 On Original (not V2) Lulzbot Mini
Post by mrvanes » Wed Jul 04, 2018 9:27 am
I had good results checking out and compiling https://code.alephobjects.com/diffusion ... evel/after changing the Makefile to cater for some minor differences in the gcc release of my distribution. Also, I adjusted build-lulzbot-firmware.sh to only build fw the for my mini.
mikehill85
Post by mikehill85 » Wed Jul 04, 2018 11:00 am
Please excuse the very basic questions, I am quite a newb at modifying firmware. What do you mean by "gcc release of my distribution". Did you flash with Arduino? If so, what did you use for your configuration.h file? It seems the .config file I linked in my original post is pretty much what you need for the mini.
mrvanes
Post by mrvanes » Thu Jul 05, 2018 12:41 am
The repository contains all you need, including the default configurations for all Lulzbot printers. build-lulzbot-firmware.sh will compile all printer firmwares for you, if you have installed the required build tools and toolchain. I can't tell you exactly what those are (I try untill it works) but build-essential is at least one of them (debian/ubuntu based distro). The result(s) are .hex files in the build/ directory which you can flash using cura or any other compatible flash tool.
It's up to you to change what needs to be changed in the respective config files for your configuration.
b-morgan
Post by b-morgan » Thu Jul 05, 2018 7:13 am
There are two places to find Marlin firmware for LulzBot printers. The first contains the pre-compiled .hex files with a .config file for each that shows the configuration parameters that were used.
The second is the GIT repository of the Marlin sources used to build the .hex files. To use it, you need to install GIT and the Arduino IDE.
After cloning the GIT repository, go into the git checkout directory and type "git checkout devel" (or a specific version number).
The Arduino IDE needs to be configured with the files from ArduinoAddons folder. For compiling using the Arduino 1.8.x IDE, just edit "Configuration_LulzBot.h" in the Marlin folder with the following values (add lines after the version number and pick your toolhead):
#define LULZBOT_Gladiola_Mini
#define TOOLHEAD_?
In the IDE, navigate to the Marlin.ino file in the Marlin folder and you should then be able to compile and upload the hex file (you want the non-bootloader .hex file). You can use Sketch, Verify/Compile to just build the .hex file(s) without uploading.
I wasn't able to use the build-lulzbot-firmware.sh as it needs a Linux environment and my attempts to use the Windows 10 Linux were not successful but the above describes the method used to build a single variant at a time. I made a copy of my local GIT repository and made my changes in that directory tree so that my local GIT repository remains a copy of the LulzBot version.
mikehill85
Post by mikehill85 » Thu Jul 05, 2018 7:25 am
Thanks so much for the help. I was able to get the new firmware on my printer last night.
mikehill85
Post by mikehill85 » Thu Jul 05, 2018 7:29 am
#define TOOLHEAD_?
Thanks for taking the time to respond to my post. I was able to flash the new firmware last night. I was hoping this would help alleviate some banding I had been seeing in my prints (ever since I got my printer). It didn't help but was worth a shot.
mrvanes
Post by mrvanes » Thu Jul 05, 2018 11:39 am
But you are now lucky to enable FWRETRACT and LIN_ADVANCE if you want :lol:
mikehill85
Post by mikehill85 » Fri Jul 06, 2018 7:17 am
There goes my weekend.
