Cura says there's a new firmware but is an older one
sk8er000
Post by sk8er000 » Fri Feb 15, 2019 3:39 am
Hello,
according to this page https://devel.lulzbot.com/software/Marlin/ the lastest taz 5 firmware for stock extruder 0.5 is Marlin_TAZ5_SingleExtruder_2.0.0.88.
Actually I have Marlin_TAZ5_SingleExtruder_2.0.0.86 installed a couple of das ago (when it was the lastest fw available). I usually use octoprint for regular printing, but if I connect my printer to CURA Lulzbot edition 3.2.32 it says that there's a new firmware available (even when 2.0.0.86 was the newer one). If I perform the auto update from CURA it flashes the 1.1.9.26 firmware. The release date of this version is 2018-10-29 and it's way older than 2.0.0.86 release date.
Am I missing something?
Can I use the newer firmwares and ignore the update messase in CURA or is it better to stay with the older firmware notified in CURA?
Thank you in advance
EDIT
I just realized that I posted on the wrong section, unfortunately I can't delete the post and post it again on the right place, sorry
nopick
Re: Cura says there's a new firmware but is an older one
Post by nopick » Fri Feb 15, 2019 7:27 am
You are pulling development firmware from devel.lulzbot.com. Cura is going to give you the latest released firmware.
sk8er000
Post by sk8er000 » Fri Feb 15, 2019 8:02 am
Thank you, for your answer. In that case I think I'll roll back to the suggested fw from cura. It should be the most stable one I think, right?
