Printing WAX
saramos
Re: Printing WAX
Post by saramos » Sat Nov 21, 2015 6:40 pm
Here's a couple of photos of the result. I think there's still some room for improvement. A little sanding and a quick pass with a pen torch cleaned things up a bit better too. If I adjust the supports a little, it should make for some easier cleanup too.
The print looks worse in the photo because of the reflections
Successful print, no lifting from bed
Face of wheel
Inside of wheel after supports removed
Cheers,
Scott
saramos
Re: Printing WAX
Post by saramos » Mon Nov 23, 2015 12:14 pm
Looks like hair spray is the key. Also, a first layer at a higher temp. The second print using this method worked even better than the first. At some point I may try and eliminate the solid base.
Scott
saramos
Re: Printing WAX
Post by saramos » Wed Nov 25, 2015 8:07 pm
Two wheels printed. I need to improve my technique for joining the two halves together.
Using Simplify3D helped to really speed up the prints. They are half the time as my Cura prints due to being able to print the lower layers at a larger layer size.
Cheers,
Scott
aaronkeit
Re: Printing WAX
Post by aaronkeit » Fri Sep 16, 2016 10:55 am
Have you refined your technique for printing machinable wax since you last posted? Wonder if you've developed a reliable method.
Thanks,
Aaron
Jrny4wrd
Re: Printing WAX
Post by Jrny4wrd » Sun Feb 10, 2019 10:03 pm
Cheers,
Scott
What lultzbot did you use? Do you currently use wax, or have you compromised to another filiment?
ritmopat
Re: Printing WAX
Post by ritmopat » Thu Mar 14, 2019 2:43 pm
still printing with wax ? how's it going if you are...
