Substitute for ABS for electronic enclosures (heat)
PdxSteve
Post by PdxSteve » Sat Aug 20, 2016 12:58 pm
I've been using (attempting) to use abs to build some parts that will be housed in an electronic enclosure of sorts, which can get pretty hot. Maybe around 90-100C at max. It's for a 6 bay battery charger for my uav and I haven't actually measured the heat - it's just a rough guess (there is a fan to exchange air so it might not get that hot). This has been a long project. I have 2 pieces that are 300+ grams/15 hour prints and individually take up the entire bed of the Taz 6. They are 2 halves to a single part.
I've been trying to use ABS for these, but they warp pretty badly no matter what I do. The first 15 or so layers are pretty good, but then the corners start curling up after a few hours. I'm using a 10 line brim and can't increase it any more as there isn't space. These 2 parts connect together to make a surface that fits in a Pelican 1550 case. They need to be flat with no/VERY minimal warping. Ive had the heat bed set to 110-115C and tried various nozzle temps. I think my first layer is pretty bang on. Spent several hours calibrating the extruder, z-height, x/y/z axis and on a 40mm cube I'm at like 40.02 - 40.04mm within all axis.
The only reason I am trying to use ABS is its high heat tolerance. I really don't want to build an enclosure to print these. So, does anybody have a recommendation on a different filament that has minimal warping and is pretty high temp resistant? I've read that PLA can warp just sitting in a hot car. They need to be strong and take heated inserts.
The abs works really well for smaller parts, just not these large ones that take up the whole build plate. Yesterday it was really hot here (around 100). I would have thought that extra heat might help a bit but it didn't. I've gone through 2kg of abs and can't perfect it. So, I'm looking for a good solid alternative and would appreciate any suggestions. I don't have a very wide exposure to different filament types.
Edit: just to add I'm using Village Plastics ABS from the lulzbot store.
gapdev
Re: Substitute for ABS for electronic enclosures (heat)
Post by gapdev » Sat Aug 20, 2016 1:33 pm
Proto-Pasta High Temp PLA can withstand up to 140°C (285°F) after its been annealed.
Comes in Silver and Ice. And Coffee but the Coffee is more difficult to work with.
I print it at 215°C on an unheated Zebra Plate (PrintnZ) bed. I anneal at 180°F for 30 - 60 minutes. There can be a small amount of shrinkage that you may need to account for.
Kenny
PdxSteve
Post by PdxSteve » Sun Aug 21, 2016 11:27 am
That sounds interesting, although I was hoping to stick with black, which I didn't mention. Translucent would be ok too as there are 6 dual color LEDs in there which would be cool to see lit up.
I just tried some clear t-glase that I had and everything was great for about the first 8 or so hours of printing. Then during the night sometime, the 2 front corners started slowly (from appearance) bending up from the plate (60C) and then everything from there up was hosed, like the ABS. I wasn't getting layer separation with ABS (fan was off) or t-glase, just after time the corners would start to curl up just like the t-glase. This is the largest object, at least on the x/y plane, that I've attempted to print. It's about 1/2" thick. I'm wondering if the edges (outer 1") of the bed is not as hot as the inner part of the bed, or just the material, or the size of the print, or combination... I don't have enough experience to determine that yet.
Does anybody know the difference between n-vent and nGen? Same thing, different companies? I received nGen with the T6 and it printed the roctopus beautifully. Best print I've printed, until I tried to remove it and one of the tentacles just snapped off. Seems to be very brittle/no flex, which I can't have. Maybe it's a lot stronger when printed thicker. Those tentacles are pretty small and long. The material needs to be strong enough to take heated inserts and take quite a bit of torque holding pieces together as well as for mounting in the case.
kcchen_00
Post by kcchen_00 » Sun Aug 21, 2016 1:41 pm
Warping on plates and large area parts is hard to combat. The edge of the heated bed will always be less efficient than the middle of the plate. Covering the bottom of a Pelican case (assuming you're using something like a 1300) can be difficult.
Here are a few ideas that have helped me:
- Try rounding the corners. The different air flow seems to reduce warping.
- At 3-4mm: lower the bed temp, use fan cooling and increase extrusion temps by a few degrees. ABS plate gets pretty rigid at about 3-4mm, keeping the bed at 110C can keep the material malleable cancelling out the benefit of being locked in flat. Lower the bed temp 90 - 100C. Start a little fan ~40-50%, to help mitigate compounded heat of each layer. Increase the extrusion temp by 1-2C to promote layer adhesion and mitigate splitting.
- Try a little negative Z-offset in your slicer. This will increase adhesion... so make sure you have a good tool or designed in mechanism to get under the part for removal. Start with -.1mm. Look at the bottom of the print, check for a bottom that has little to no striatations from the extrusion. A flat surface, with little distinct striations and no elephant foot is would be ideal.
- Break your battery holder down into smaller sections. Are you putting in the batteries vertical, side by side? Use a mechanical joining mechanism like dovetail joints to assemble.
- A temporary enclosure... some folks have used blankets to trap the heat. In the winter I use a simple enclosure made from coroplast sheets to trap heat. Then disassemble when not needed.
Hope some of the ideas help. If you post a STL, we might be able to give you more ideas on design or print tips.
PdxSteve
Post by PdxSteve » Sun Aug 21, 2016 3:13 pm
Thanks for the reply and helpful suggestions. I think I have enough ABS for another try using them. It's a Pelican 1450 case, and the part is divided in half and will be joined using the heated inserts. I'd be happy to send you the STL, I unfortunately just can't post it in public. One of the corners that is warping is rounded, the other is 90deg. All prints so far have curled up, but only the 2 corners closest to the front of the bed. I supposed I could try rotating the part 90deg and seeing if that helps too.
Here are a few pics of the t-glase, the ABS looks pretty much identical though:
Whole thing (front lifting):
Left front:
Right Front:
Biolumo
Post by Biolumo » Sun Aug 21, 2016 3:27 pm
PdxSteve wrote:Does anybody know the difference between n-vent and nGen? Same thing, different companies? I received nGen with the T6 and it printed the roctopus beautifully. Best print I've printed, until I tried to remove it and one of the tentacles just snapped off. Seems to be very brittle/no flex, which I can't have. Maybe it's a lot stronger when printed thicker. Those tentacles are pretty small and long. The material needs to be strong enough to take heated inserts and take quite a bit of torque holding pieces together as well as for mounting in the case.
I've tried asking that before and Jamie from ITWorks3D.com is the only person who really has answered my question about that. Basically what he said is that The INOVA-1800 Amphora-based filament is like a high-quality replacement for ABS and is super strong, high heat resistant, has low warping issues, and has no awful fumes. I think what he said about nGen and n-vent is that they are like good, better, best in regards to the quality of the Amphora used. I think it goes in order of n-vent (like a higher quality PLA), nGen, and then Inova-1800 (High quality ABS). Don't quote me on that as i may have gotten the order wrong. nGen is made in Europe somewhere and nVent is made by a company here in Colorado in the U.S., so there is that difference too i think. But they all are interesting filaments with low warpage and low fumes and all very similar to each other.
nGen does seem stronger than ABS to me, but these Amphora-based filaments do seem to suction to the PEI tape and build table so they are a pain in the butt to remove, so that is probably why your octopus arm broke. I've heard some people say that using a glue stick helps these more suctiony filaments to be removed easier when they cool down then if you just use the PEI tape by itself, but i dont know if that is true for these, just something i had heard as rumor on the forum somewhere. Although try using a glue stick with your ABS, i think it has helped reduce some of my warping issues a little bit.
PdxSteve
Post by PdxSteve » Sun Aug 21, 2016 3:43 pm
Biolumo wrote: nGen does seem stronger than ABS to me, but these Amphora-based filaments do seem to suction to the PEI tape and build table so they are a pain in the butt to remove, so that is probably why your octopus arm broke. I've heard some people say that using a glue stick helps these more suctiony filaments to be removed easier when they cool down then if you just use the PEI tape by itself, but i dont know if that is true for these, just something i had heard as rumor on the forum somewhere. Although try using a glue stick with your ABS, i think it has helped reduce some of my warping issues a little bit.
Thank you, and that makes sense. I was wondering why the 1800 was 2x as much as the ngen/n-vent. I did use the gluestick that came with the taz6 as the instructions said to use it with the ngen while printing the sample roctopus. I appreciate your input.
So you're using the gluestick with ABS? I hadn't heard of that.
kcchen_00
Post by kcchen_00 » Sun Aug 21, 2016 8:12 pm
Hmm... could try a tall skirt to prevent air from hitting the part as it moves in the Y axis. Maybe a 5-10mm tall skirt with 1-2mm offset from the part.
Post a pic of the bottom. On the TAZ6, you can apply Z-offset through the LCD. They removed the Z-offset gcode in Cura for some reason. If using some other slicer like S3D, the Z-offset should still be active.
CoParaTech
Post by CoParaTech » Mon Aug 22, 2016 12:19 am
I've been using nGen, XT, and HT, all from ColorFabb with great success for smaller enclosures that are subject to heat in the 60-100° C range. HT is the newest high-temp filament from ColorFabb and it has been living up to there descriptions so far. Lean more about it here:
http://ht.colorfabb.com/
Also, Makergeeks has some hight-temp PLA that can be annealed to and handle temps up to 250° F. Learn more here:
http://www.makergeeks.com/rasepla.html
PdxSteve
Post by PdxSteve » Sat Aug 27, 2016 5:22 pm
Thank you all. I've purchased some Taulman n-vent, INOVA-1800 and ProtoPasta High Temp PLA based on what people have mentioned, and it finally arrived yesterday.
Last night I did a print with the N-Vent. Very impressed! The print was about 99.5% perfect - and no warping. I just have some minor adjustments to make as a few spots on the very top layer's surface didn't come out totally smooth and were a bit rough like finer grit sandpaper. But all lines were totally straight and my x/y/z seems pretty dialed in. It was a 16 hour print. There were also several tiny holes in some places where the the surface met a perimeter wall. I had turned my extrusion down a bit to 93% on the lower layers, so that might be why. I was using 25% infill, 230C nozzle and 60C bed. I also purchased Simplify3d and am loving it so far. Wonderful app.
Is there any chemical treatment that works with n-vent for smoothing like acetone does on abs?
Another thing I wasn't too happy with was the adhesion was wayyy too good. I put a liberal coat of the Elmers All-Purpose Glue Stick that came with the Taz 6 like the suggestions say for n-vent on the lulzbot store and used the recommended temps. I have a very long thin blade spatula that I use. It's .2mm at the tip and slowly thickens to .5mm for the 4" duration of the blade. It's about 1/2" wide. I never pry upwards. I slip it under a corner slowly and slide it under the part until 3/4 of the blade is under, then slowly rock back and forth and work sideways as I'm working my way around the object. That was pretty tough. After about 10 minutes of work the part came up. There were 4-5 large air bubbles under the PEI. I heated the bed to 100C and spent quite a bit of time pushing them towards the edge of the film using a sponge and got them to work themselves out, and it feels flat and you could definitely feel a bulge before. I had lots of tiny bubbles like everyone else before, but I haven't gotten these large ones like 1-2" diameter. I fear now that the good adhesion is gone between the glass and PEI that this will be a reoccurring theme now in those spots. Soooo..... what can I do to prevent that? I seriously put like 2 thick coats of glue down from edge to edge. This one print is costing so much money in materials and breaking taz lol. Argh.
I also worry about replacing the PEI sheet. I envision it being like trying to put window tint on a car and not having the proper equipment to get all of the bubbles out. The first time.
Again, thank you all for the help. I'm getting there!
