Best Glues??
AverageVeganDude
Best Glues??
Post by AverageVeganDude » Tue Sep 06, 2016 7:08 am
Just curious what is the strongest bonding glue for printed parts. I usually print in nGen, or PLA. I have a project that needs a strong bond. Do you guys just purchase products like Gorilla Glue from home Depot?
Thanks,
Chris
DougZ
Contact:
Re: Best Glues??
Post by DougZ » Tue Sep 06, 2016 8:33 am
I was at a boat show last year and there was a booth where a guy had some Max 1 glue. Looked like super glue, smelled like super glue, even tasted like super glue! kidding, of course.
He took a .5" rubber o-ring and snipped it. Put a drop of the glue on one end then rolled the two ends together and held it tight for about 10 seconds. He handed it to me and I pulled on it quite hard and it did not separate. He broke a small tile in half, brushed an accelerator on one side then the glue on the other, held the two pieces together, I could not break them apart. There were of course other demos. I was impressed enough I had to buy some even though I didn't need it. A tad expensive, but it was the boat show so...
Since then I have used it successfully many times. My daughter somehow broke a plate in the microwave baking a potato. Glued it back together and it was as good as new (except for the hairline of the crack). I've repaired a rubber bracelet of hers, similar to the original demo.
And, to your question, I have bonded several ABS and PLA, and PETG parts together like there's no tomorrow. It is Max 1 glue. Plain name but really good stuff.
I've used Loctite super glue gel with success as well. The gel is nice because it stays in place - particularly convenient when you have long, thin parts to bond that may even require multiple axis bonding.
Lulzbot Mini
Lulzbot TAZ6
Follow me on Twitter! @tech3_design
piercet
Contact:
Re: Best Glues??
Post by piercet » Tue Sep 06, 2016 10:13 am
I like Plastruct Plastic weld for bonding ABS.
mikronano
Re: Best Glues??
Post by mikronano » Thu Sep 08, 2016 9:08 am
AverageVeganDude wrote:Just curious what is the strongest bonding glue for printed parts. I usually print in nGen, or PLA. I have a project that needs a strong bond. Do you guys just purchase products like Gorilla Glue from home Depot?
Thanks,
Chris
In regards to nGen and any other co-polyester (PETG, PETT, T-Glase, ColorfabbXT & HT, etc), the acrylic cements are the ones you need. Look up for Weld-On #3 or #4 (faster or slower setting) on Amazon (you better look for a needle applicator too). These cements work also on ABS and Polycarbonate by definition. What you do, is to get your two printed pieces together and carefully pour a little of these water-like welders at the joining point. The liquid is so thin it will creep right in between the connecting surfaces and there it will break the chemical bonds of the material to be joined and when the thinner in them evaporates (#3 really fast, #4 a bit slower) the chemical bonds will reform and the two parts will become one and you won't be able again to separate them at that point.
In regards to PLA I'm afraid I am not aware of any specific glue. What I have tried is the new type of "super glue" that is out there and works also well on nylon. Taulman3D calls it "ComPlete". On Amazon you can find it as "RapidFix". They are all the same. It does work better than the traditional "super glue" but it is still a glue.
That all said, if you are looking to making something big that it will look like one piece at the end, without being afraid of coming apart at the joining points, I would suggest to use the nGen or any other material (co-polyester, ABS, Polycarbonate, etc) where you can use a plastic cement.
Press a key to continue or any other key to quit
AverageVeganDude
Re: Best Glues??
Post by AverageVeganDude » Thu Sep 08, 2016 11:36 am
Reviews say the Weld-On #3 is very hard to use at first. Runs everywhere. Any suggestions?
bout2print
Re: Best Glues??
Post by bout2print » Thu Sep 08, 2016 12:01 pm
download/file.php?mode=view&id=7072 I've had good results with this particular brand.
Plastic Glue.JPG (51.35 KiB) Viewed 3031 times
We are Never Too Old to Learn Something New
AverageVeganDude
Re: Best Glues??
Post by AverageVeganDude » Thu Sep 08, 2016 12:04 pm
Do you guys think the glues you are recommending work well with big parts as well as small? Here are my prints.
AverageVeganDude
Re: Best Glues??
Post by AverageVeganDude » Thu Sep 08, 2016 12:05 pm
Is Loctite a quick drying glue?
mikronano
Re: Best Glues??
Post by mikronano » Thu Sep 08, 2016 2:34 pm
AverageVeganDude wrote:Reviews say the Weld-On #3 is very hard to use at first. Runs everywhere. Any suggestions?
Truth to be told, there is no perfect solution for everything. But it is also true that all depends on what you are used at.
Is true that with Weld-On and all products like this, due to their extremely small viscosity, is difficult at first to apply them because they tend to run everywhere like water. What you need is a glass surface to practice a bit with the applicator on how to control the flow. After that you won't go back to using glues.
A great advantage over glues is that you bring all pieces together in place and then you apply the cement at the joining surfaces. It just goes by itself in the tightest places using the capillary effect. Leaves no residue and if anything drops on the glass it gets cleaned very easily. Parts' size doesn't matter ;)
One disadvantage is that if you accidentally lose alignment you don't have much time before the two parts become one forever.
Another disadvantage is that I have yet to find the perfect applicator. It's the only thing missing in the whole process. Best control you can achieve is with a syringe with a very small needle. The only problem is that the cement corrodes the piston rubber seal, in all of them, rendering the syringe useless pretty quick.
mikronano
Re: Best Glues??
Post by mikronano » Thu Sep 08, 2016 3:15 pm
AverageVeganDude wrote:Do you guys think the glues you are recommending work well with big parts as well as small? Here are my prints.
Small parts are always easier to glue/weld together with either type.
Big parts put a bigger challenge, mostly for the quick curing glues like the Loctite and all the super glues. By the time you complete laying the last section with the glue, the first sections might be cured already before you actually have the time to bring the pieces together!
That is where the slow cure 2-part epoxy glues come into play. The only problem is that they don't do very well with all plastics.
If I'm not mistaken from your picture, you are looking into putting together parts with large flat surfaces. If you can set these surfaces on the horizontal then I believe the epoxies are a viable option. If you can bring the surfaces together on the vertical then the cements, I believe, are better choice.
