NylonX is the best, who else prints it on a mini?
this is my new favorite filament.
Sure you need hardened extruder parts (aerostruder with hardened gears, break, nozzle),
and you have to crank up the heat to 270 (lower makes the parts weak and brittle),
and you need to dry it and keep it dry,
but it prints so well, and makes great looking and VERY stiff and strong parts.
Also the support material comes off as one ribbon, it seperates well if setup correctly (1 layer z gap)
CFPLA is stiffer, but the nylon just flows MUCH better, and is still plenty stiff.
PVA glue on the pei sheet works fine to hold moderate size parts, but may be damaging the pei over time (pulling it up). going for garolite next.
Anybody else use NylonX ?
I have a TAZ 5 I just got my first roll of 3DXTech’s CarbonX, which is a carbon-fber-nylon equivalent. I also do have a hardened steel 0.6mm nozzle that I’m about to install, but I wanted to do a test print, so here is my second print with the original 0.5mm brass nozzle. I cobbled together a Cura printing profile from a Carbon-PLA profile and a Nylon profile.
Print is not perfect, I’ve never really tried to custom make a profile before.
I’d be curious to see print settings you are using for NylonX
[profile]
layer_height = 0.4
wall_thickness = 1.2
retraction_enable = True
solid_layer_thickness = 1.14
fill_density = 50
perimeter_before_infill = True
nozzle_size = 0.5
print_speed = 50
print_temperature = 260
print_temperature2 = 0
print_temperature3 = 0
print_temperature4 = 0
print_temperature5 = 0
print_bed_temperature = 110
support = None
platform_adhesion = None
support_dual_extrusion = Both
wipe_tower = False
wipe_tower_volume = 15
ooze_shield = False
filament_diameter = 2.88
filament_diameter2 = 0
filament_diameter3 = 0
filament_diameter4 = 0
filament_diameter5 = 0
filament_flow = 100.0
retraction_speed = 50
retraction_amount = 3
retraction_dual_amount = 16.5
retraction_min_travel = 1.5
retraction_combing = All
retraction_minimal_extrusion = 0.01
retraction_hop = 0.1
bottom_thickness = 0.38
layer0_width_factor = 125
object_sink = 0.0
overlap_dual = 0.15
travel_speed = 180
bottom_layer_speed = 15
infill_speed = 50
solidarea_speed = 40
inset0_speed = 40
insetx_speed = 45
cool_min_layer_time = 20
fan_enabled = False
skirt_line_count = 1
skirt_gap = 6
skirt_minimal_length = 0
fan_full_height = 0.5
fan_speed = 40
fan_speed_max = 50
cool_min_feedrate = 7
cool_head_lift = False
solid_top = True
solid_bottom = True
fill_overlap = 15
support_type = Lines
support_angle = 45
support_fill_rate = 30
support_xy_distance = 1.5
support_z_distance = 0.2
spiralize = False
simple_mode = False
brim_line_count = 10
raft_margin = 5.0
raft_line_spacing = 3.0
raft_base_thickness = 0.3
raft_base_linewidth = 1.0
raft_interface_thickness = 0.27
raft_interface_linewidth = 0.4
raft_airgap_all = 0.0
raft_airgap = 0.5
raft_surface_layers = 2
raft_surface_thickness = 0.27
raft_surface_linewidth = 0.4
fix_horrible_union_all_type_a = True
fix_horrible_union_all_type_b = False
fix_horrible_use_open_bits = False
fix_horrible_extensive_stitching = False
plugin_config =
object_center_x = -1
object_center_y = -1
simplemodesettings =
simplemodeprofile = 2_normal
simplemodematerial =
simplemodematerialtype = Beginner
[alterations]
start.gcode = ;Sliced at: {day} {date} {time}
	;Basic settings: Layer height: {layer_height} Walls: {wall_thickness} Fill: {fill_density}
	;Print time: {print_time}
	;Filament used: {filament_amount}m {filament_weight}g
	;Filament cost: {filament_cost}
	;M190 R{print_bed_temperature} ;Uncomment to add your own bed temperature line
	;M109 R{print_temperature} ;Uncomment to add your own temperature line
	G21                     ;metric values
	G90                     ;absolute positioning
	M82                     ;set extruder to absolute mode
	M107                    ;start with the fan off
	G28 X0 Y0               ;move X/Y to min endstops
	G28 Z0                  ;move Z to min endstops
	G1 Z15.0 F{travel_speed};move the platform down 15mm
	G92 E0                  ; zero the extruded length
	G1 F200 E0              ; extrude 3mm of feed stock
	G92 E0                  ; zero the extruded length again
	G1 F{travel_speed}      ; set travel speed
	M203 X192 Y208 Z3       ; speed limits
	M117 Printing...        ; send message to LCD
end.gcode = M400
	M104 S0                        ; hotend off
	M140 S0                        ; heated bed heater off (if you have it)
	M107                           ; fans off
	G91                            ; relative positioning
	G1 E-1 F300                    ; retract the filament a bit before lifting the nozzle, to release some of the pressure
	G1 Z+0.5 E-5 X-20 Y-20 F3000   ; move Z up a bit and retract filament even more
	G90                            ; absolute positioning
	G1 X0 Y250                     ; move to cooling position
	M84                            ; steppers off
	M117 TAZ Ready.
	;{profile_string}
start2.gcode = ;Sliced at: {day} {date} {time}
	;M104 S{print_temperature} ;Uncomment to add your own temperature line
	;M109 T1 S{print_temperature2} ;Uncomment to add your own temperature line
	;M109 T0 S{print_temperature} ;Uncomment to add your own temperature line
	G21        ;metric values
	G1 Z15.0 F{travel_speed} ;move the platform down 15mm
	T1                      ;Switch to the 2nd extruder
	G92 E0                  ;zero the extruded length
	G1 F200 E10             ;extrude 10mm of feed stock
	G92 E0                  ;zero the extruded length again
	G1 F200 E-{retraction_dual_amount}
	T0                      ;Switch to the first extruder
	G1 F{travel_speed}
	;Put printing message on LCD screen
	M117 Printing...
end2.gcode = ;End GCode
	M104 T0 S0                     ;extruder heater off
	M104 T1 S0                     ;extruder heater off
	M140 S0                     ;heated bed heater off (if you have it)
	G91                                    ;relative positioning
	G1 E-1 F300                            ;retract the filament a bit before lifting the nozzle, to release some of the pressure
	G1 Z+0.5 E-5 X-20 Y-20 F{travel_speed} ;move Z up a bit and retract filament even more
	G28 X0 Y0                              ;move X/Y to min endstops, so the head is out of the way
	M84                         ;steppers off
	;{profile_string}
start3.gcode = ;Sliced at: {day} {date} {time}
	G21        ;metric values
	T2                      ;Switch to the 2nd extruder
	G1 F{travel_speed}
	M117 Printing...
end3.gcode = ;End GCode
	M104 T2 S0                     ;extruder heater off
	M84                         ;steppers off
	;{profile_string}
start4.gcode = ;Sliced at: {day} {date} {time}
	;M109 T2 S{print_temperature2} ;Uncomment to add your own temperature line
	G21        ;metric values
	T3                      ;Switch to the 4th extruder
	T2                      ;Switch to the 3th extruder
	G1 F{travel_speed}
	M117 Printing...
end4.gcode = ;End GCode
	M104 T3 S0                     ;extruder heater off
	M84                         ;steppers off
	;{profile_string}
support_start.gcode =
support_end.gcode =
cool_start.gcode =
cool_end.gcode =
replace.csv =
preswitchextruder.gcode = ;Switch between the current extruder and the next extruder, when printing with multiple extruders.
	;This code is added before the T(n)
postswitchextruder.gcode = ;Switch between the current extruder and the next extruder, when printing with multiple extruders.
	;This code is added after the T(n)
I am actually using a 0.4mm nozzle and it is working great… 26hour print no jams.
But I do have the nozzle in Cura called out as a 0.35mm
This is what I am using as a profile in cura2, based off the nylon 910 material
version = 2
name = Nylonx detail
definition = lulzbot_mini_aerostruder
[metadata]
type = quality_changes
setting_version = 1
quality_type = high detail
[values]
adhesion_type = brim
alternate_extra_perimeter = True
bottom_thickness = 1
cool_fan_enabled = False
cool_min_layer_time = 5
cool_min_layer_time_fan_speed_max = 40
default_material_print_temperature = 270
infill_pattern = tetrahedral
infill_sparse_density = 50
layer_0_z_overlap = =raft_airgap / 2
layer_height = 0.15
layer_height_0 = 0.2
line_width = =machine_nozzle_size
material_bed_temperature = 90
material_final_print_temperature = 270
material_flow = 105
material_initial_print_temperature = 270
material_keep_part_removal_temperature = False
material_part_removal_temperature = 50
material_print_temperature_layer_0 = =material_print_temperature + 5
material_probe_temperature = 200
material_wipe_temperature = 200
retraction_amount = 0.4
retraction_combing = noskin
skirt_line_count = 2
speed_infill = =speed_print
speed_layer_0 = =speed_print * 30 / 60
speed_print = 50
speed_slowdown_layers = 1
speed_topbottom = =speed_print / 2
speed_wall_0 = =speed_wall
speed_wall_x = =speed_wall * 2
support_angle = 47
support_enable = True
support_infill_rate = 40
support_pattern = grid
support_type = buildplate
support_xy_distance = 0.5
top_bottom_pattern = concentric
top_bottom_pattern_0 = =top_bottom_pattern
top_thickness = 1
wall_line_count = 3
