ABS filament damaging bed, want alternative recommendations
kcchen_00
Re: ABS filament damaging bed, want alternative recommendations
Post by kcchen_00 » Thu Nov 29, 2018 9:36 pm
Object removal plays a part in the longevity of the adhesive. Its commonly recommended that the bed temp is ~50C when removing projects. Using a thin blade spatula to work your way around the object to remove is a gentler way of removing an object.
Prying up and "popping" the project off the bed is probably the worst for the adhesive.
pziu
Post by pziu » Fri Nov 30, 2018 4:21 pm
Hi folks. Just wanted to add a picture to the thread. I don't think the particular material causes issues, I think it is just a function of heating the bed to 110 deg C, which is causing separation. Trapped volatiles or water durning manufacturing/assembly? Here is what my bed did by the third print at this temperature:
I haven't noticed any issues in printing yet.
This is really neat: https://ntrs.nasa.gov/archive/nasa/casi ... 000214.pdf
https://www.lulzbot.com/learn/NASA-high ... e-printing
kcchen_00
Post by kcchen_00 » Fri Nov 30, 2018 5:50 pm
If that's a new printer bought direct from LB, you should send the picture in to their customer service. That's definitely not normal.
If you bought the printer from a third party or amazon... you should contact them... if still under warranty.
pziu
Post by pziu » Tue Dec 04, 2018 5:11 pm
Thanks, I will follow up.
