Rubber belt/tank track
Show off your stuff!
antfurn
Post by antfurn » Wed Jan 22, 2014 3:48 pm
I've upgraded my AO-101 with the FlexiStruder and thought I'd show some of my results.
Please feel free to ask questions.
I've uploaded my Slic3r v1.0.0RC2 config ini just in case you find that useful.
Oh and I've been using NinjaFlex filamant from http://3dfilaprint.com/
Flexi.ini
slic3r ini
(3.15 KiB) Downloaded 161 times
pic6
pic5
pic3
pic2
pic1
piercet
Contact:
Re: Rubber belt/tank track
Post by piercet » Wed Jan 22, 2014 4:43 pm
Huh, neat! I want to print a tank soon myself. What temperature does that stuff print at, and about how much does it run?
antfurn
Post by antfurn » Wed Jan 22, 2014 5:43 pm
Hi piercet, I've been running the hotend @220 and the bed @50.
Sticks very well to the standard AO-101 bed with the PET sheet still on.
I think I could drop to 215 but 210 seemed not to flow too well.
The main thing I found so far, is to try to get a constant print speed, as it does ooze quite a lot.
The place in the UK I got the Ninjaflex from charge ~£5 for 10m of 3mm filament, I think that's about $8. A full real (0.75kg) is £56.
piercet
Contact:
Post by piercet » Wed Jan 22, 2014 5:58 pm
That's not bad actually pricewise. I'm having trouble finding a source over here at the moment that has any in stock. That tank tread looks absolutely amazing though!
Also, PET Sheep is officially the best typo ever!
bwanamukubwa
Post by bwanamukubwa » Fri Jan 24, 2014 8:13 am
Oh wow, really cool. Do you have to print with high infill to get it to flex without tearing?
antfurn
Post by antfurn » Fri Jan 24, 2014 11:26 am
Hi bwanamukubwa, The belts/tank tracks have no in-fill at all. They are just 2 perimeters 'thick' @ 0.6mm each.
The rubber cup is printed in vase mode - so only 1 perimeter, although I did set that to be 1.2mm.
I've since printed a vase with no base (i.e. another belt, but spiral instead of layers) that is only 0.6mm thick and it's still very strong and almost no stretch (which surprised me a lot).
Antony
jebba
Site Admin
Post by jebba » Sat Jan 25, 2014 11:45 am
bwanamukubwa wrote:Oh wow, really cool. Do you have to print with high infill to get it to flex without tearing?
This stuff is super strong. One extrusion width wide is even strong. If you do two extrusion widths, you can barely pull it apart. It is really robust. It's awesome, I can't wait til it becomes more common.
chriswh86
Contact:
Post by chriswh86 » Tue Apr 15, 2014 3:35 pm
How do you find the cup for use-ability? Able to safely transport beverages without worry of swishing and the beverage spilling over?
Chris
Community Rep at Pinshape
Explore, Share & Download High-Quality 3D Printable Designs
www.Pinshape.com
