Linear bearing
Show off your stuff!
tmoore
Linear bearing
Post by tmoore » Fri Feb 14, 2014 10:03 pm
I just printed out this linear bearing. The overall runout on the shaft was less than .005" and there was only a couple of thousandths of play in the whole thing. I'm impressed with the accuracy of the TAZ 3.0.
TM
chriswh86
Re: Linear bearing
Post by chriswh86 » Tue Apr 15, 2014 3:28 pm
Great bearing tmoore. What are you end plans with this bearing and shaft setup?
Chris
Community Rep at Pinshape
Explore, Share & Download High-Quality 3D Printable Designs
www.Pinshape.com
tmoore
Re: Linear bearing
Post by tmoore » Thu Apr 24, 2014 9:45 pm
It was basically a test print to see what the printer was capable of. Not bad for the first few efforts. If need be you could certainly print bearings for short term use.
Orias
Re: Linear bearing
Post by Orias » Fri Apr 25, 2014 8:42 am
We're a bit excited about IGUS self-lubricating bushing filament for printing bushings and wear surfaces.
gannon
Re: Linear bearing
Post by gannon » Fri Apr 25, 2014 11:58 am
IGUS filament? That is exciting
