Supports for 28mm Miniatures
Show off your stuff!
Dabme
Post by Dabme » Mon Jun 18, 2018 2:23 pm
I have a Lulzbot Mini and I use Cura. My goal is to print 28mm tabletop miniatures (mostly for my D&D game)
I'm curious about support settings. I try to avoid supports but when I do use them they are terribly difficult to remove. So what is your strategy for supports for 28mm models?
Your thoughts are appreciated.
-Dave
Luis
Re: Supports for 28mm Miniatures
Post by Luis » Tue Jun 19, 2018 7:44 am
I'd try to avoid using the supports if I could :)
NBradshaw
Post by NBradshaw » Tue Jun 19, 2018 10:44 am
If you do need to use support for these kinds of prints, then I would recommend changing the Support Z Distance a bit. As a standard it is usually set at a .1mm, but I have found that I can still get really good results with a .15 or even a .2mm setting. I also like to use a 15% support density for just about everything. I have found that these have worked well for most prints, even small, detailed prints.
