Is it possible to print wider than 280mm?
I want to print an object that is 283 mm long.
Is there any way to “push” the printer to print a few millimeters wider or is it simply not possible?
You can try printing without a skirt, as skirts tend to take up a bit of space. Usually not a problem, but can be if you want to max out the bed.
You can also go into the machine settings in Cura and changes the printer settings, but we do not recommend that. It could cause some issues with the printer.
I was able to increase the width (x and y) from 280 to 285. That plus no skirt allowed me to get the print completed correctly.
