TAZ 6 Bed leveling problems
Hi, all
I don’t what is happening with my 3D printer. I made sure several times that is perfectly balanced in the Z axis, but when it is printing, only on the right frontal corner is doing it correctly, when it goes to the opposite side, the filament barely touches the bed. When the printing continues, in that side the filament eventually does not reach the bed and gets stuck in the tip. I’ve tried several times now and the last time the printing stopped automatically indicating a bed leveling problem. Do you know if there is any way to do a calibration of the bed leveling please? You would help me a lot, thanks.
The TAZ 6 auto-levels before each print. Is that procedure working properly? Have you switched slicers or are you trying to print a gcode file? The only other thing I can think of is to check that the printer is on a level and stable table.
