I’m trying to spiralize with my new Moar head and 'm getting strange results. The layer view does not show spiralized but rather discrete layers. I printed the first 10 layers and it is indeed printing in normal layer mode. Attached is a shot of the layer view along with the spiralized settings. You cans see the z-axis layer jump.
Send this screenshot, the stl file if possible, and a picture of the print. Include as well: filament type and print profile used: https://LulzBot.com/Support
In Cura LE there should be several material profiles with preset and tuned spiralize profiles, ideally you’d be able to use one of them. In the meantime, you may want to clear your cura cache to return Cura LE to the fresh, just installed state. Switch to custom, and enable spiralize again. Find instructions for your operating system at https://LulzBot.com/Cura.
