Z-Hop settings Taz5
gtrplaya101
Z-Hop settings Taz5
Post by gtrplaya101 » Tue Mar 24, 2015 8:17 am
What height is everyone using for Z-hop? I am getting a lot of nozzle drag when moving across the part. I had a print last night fail because the nozzle dragged and pulled some of the first layer up with it.
BaltimoreBully
Re: Z-Hop settings Taz5
Post by BaltimoreBully » Tue Mar 24, 2015 10:40 am
If your nozzle is dragging through the first layer of a print, that sounds more like your end stop on your z axis is set too low. If you are getting scratches and scars on your top layer, that is something that can be offset with z hop. Z hop only works after a retraction when the nozzle is traveling. Not when the nozzle is extruding.
kcchen_00
Post by kcchen_00 » Tue Mar 24, 2015 7:06 pm
Also check that you're not over-extruding... spot measure the filament diameter, or dial down the flow multiplier.
An easy way to recover during a print is to use the dial on the LCD panel... the knob seems defaults to FR on my TAZ5, turning will increase and decrease flow percentage.
If you have a fragile print... lots of columns, then enable nozzle retract (in addition to filament retract) on move in the slicer program.
