Hundreds of Print Profiles on TAZ 6?
AverageVeganDude
Post by AverageVeganDude » Tue May 03, 2016 2:00 pm
How is this possible? Is this in Cura or Marlin? Can you put this on a TAZ 5?
Where do I get this upgrade does anyone know :)
Thanks,
Chris
Orias
Re: Hundreds of Print Profiles on TAZ 6?
Post by Orias » Tue May 03, 2016 3:56 pm
The print profiles are built into Cura LulzBot Edition. That version of Cura supports three different LulzBot 3D printers, with potentially 14 different printer:tool head permutations, with 30 different filaments, each of which has at least one different Quickprint profile.
To get the latest tested Quickprint profiles update Cura by checking LulzBot.com/Cura.
If you'd like to see what goes into our profiles, they can be found here: https://code.alephobjects.com/diffusion ... se/master/ and https://code.alephobjects.com/diffusion ... erimental/
jebba
Site Admin
Post by jebba » Tue May 03, 2016 4:17 pm
These are all the profiles for all LulzBot printers in Cura. So it includes older machines and multiple profiles for various materials (e.g. ABS has three profiles). In sum:
Code: Select all
/usr/share/cura/resources/quickprint/lulzbot_profiles$ find . -type f | wc -l
297
AverageVeganDude
Post by AverageVeganDude » Tue May 03, 2016 10:01 pm
Is Cura v19 just for the new TAZ 6? or can I install it to use with my Taz 5?
Thanks,
Chris
PdxSteve
Post by PdxSteve » Tue May 03, 2016 10:12 pm
AverageVeganDude wrote:Is Cura v19 just for the new TAZ 6? or can I install it to use with my Taz 5?
Thanks,
Chris
It's for all models, and non-lulzbot printers too... https://www.lulzbot.com/cura
