TAZ TK0
robtheslob
Re: TAZ TK0
Post by robtheslob » Fri Jun 21, 2013 10:57 pm
Here is a picture of the bed plates, as promised:
These are straight off the waterjet (raw finish) so will be some scuffs or scratches on the plate. They can definitely be polished, although I don't know why you would do that considering this part isn't really visible...
Anyway, I paid about $35 per plate with shipping, looking for $45 to pay for the time to ship them. PM me if interested!
Good luck with the TAZ build!
rsilvers
Re: TAZ TK0
Post by rsilvers » Sat Jun 22, 2013 12:45 pm
This is my BOM so far. I have $730 into it. It has part numbers and sources that should help a lot of people.
http://forums.reprap.org/file.php?1,fil ... download=1
rsilvers
Re: TAZ TK0
Post by rsilvers » Sat Jun 22, 2013 12:52 pm
I am using these:
http://store.makerstoolworks.com/motion ... -set-of-2/
It would be nice to adapt the parts to accept this Delrin ACME nut.
robtheslob
Re: TAZ TK0
Post by robtheslob » Sat Jun 22, 2013 1:39 pm
Hey TAZzers,
I just read through rsilvers' BOM and I lament my failure to post this earlier...
I just want to post a rave about http://www.boltdepot.com. I ordered (almost) all of my TAZ hardware from them as opposed to buying bags of 100 or whatever from McMaster; yes, they sell individual pieces at a very reasonable (sometimes better) price! Although there is nothing wrong with having leftover hardware...
The black oil finish they offer is much like black oxide, but with a more metallic, oily sheen to it. It has different mechanical properties, but the difference shouldn't affect this build. It looks great, and I think I actually prefer it to black oxide.
I hope this potentially saves people some $$$!
rsilvers
Re: TAZ TK0
Post by rsilvers » Sat Jun 22, 2013 4:12 pm
Awesome! http://www.boltdepot.com/
You just saved me (and everyone who was buying from McMaster) $84.16!
Anything close to 100 - buy as 100 packs - cheaper than buying the 80 or 88.
rsilvers
Re: TAZ TK0
Post by rsilvers » Sat Jun 22, 2013 4:28 pm
Your Order
Product# Description Quantity Unit Price Subtotal
13633 Metric socket cap, Class 12.9 steel black oil finish, 3mm x 0.5mm x 5mm 30 pcs $0.10 $3.00
13637 Metric socket cap, Class 12.9 steel black oil finish, 3mm x 0.5mm x 12mm 100 pcs $5.56/100 $5.56
13640 Metric socket cap, Class 12.9 steel black oil finish, 3mm x 0.5mm x 25mm 4 pcs $0.13 $0.52
6510 Metric socket cap, Class 12.9 steel black oil finish, 4mm x 0.7mm x 20mm 4 pcs $0.13 $0.52
15435 Metric socket cap, Class 12.9 steel black oil finish, 4mm x 0.7mm x 60mm 3 pcs $0.21 $0.63
6519 Metric socket cap, Class 12.9 steel black oil finish, 5mm x 0.8mm x 10mm 100 pcs $5.63/100 $5.63
6521 Metric socket cap, Class 12.9 steel black oil finish, 5mm x 0.8mm x 14mm 8 pcs $0.10 $0.80
6564 Metric socket cap, Class 12.9 steel black oil finish, 8mm x 1.25mm x 35mm 2 pcs $0.27 $0.54
8827 Metric set screws, Allen, Cup point, Class 14.9 steel black oil finish, 3mm x 0.5mm x 5mm 12 pcs $0.09 $1.08
4806 Metric hex lock nuts nylon insert, Zinc plated class 8.8 steel, 8mm x 1.25mm 5 pcs $0.11 $0.55
4524 Metric flat washers, Zinc plated steel, 3mm 100 pcs $1.16/100 $1.16
4525 Metric flat washers, Zinc plated steel, 4mm 15 pcs $0.05 $0.75
4526 Metric flat washers, Zinc plated steel, 5mm 100 pcs $1.40/100 $1.40
4529 Metric flat washers, Zinc plated steel, 8mm 15 pcs $0.05 $0.75
4783 Metric hex nuts, Zinc plated class 8.8 steel, 3mm x 0.5mm 4 pcs $0.05 $0.20
4784 Metric hex nuts, Zinc plated class 8.8 steel, 4mm x 0.7mm 6 pcs $0.05 $0.30
4788 Metric hex nuts, Zinc plated class 8.8 steel, 8mm x 1.25mm 5 pcs $0.06 $0.30
6041 Metric tap bolts, Zinc plated class 8.8 steel, 4mm x 0.7mm x 20mm 6 pcs $0.12 $0.72
13339 Metric socket button head, Class 12.9 steel black oil finish, 4mm x 0.7mm x 8mm 6 pcs $0.09 $0.54
6896 Metric wing nuts, Stainless steel 18-8, 4mm x 0.7mm 6 pcs $0.39 $2.34
6899 Metric wing nuts, Stainless steel 18-8, 8mm x 1.25mm 1 piece $0.67 $0.67
Summary
Subtotal: $27.96
Tax: $1.75
Shipping: $6.83
Total: $36.54
rsilvers
Re: TAZ TK0
Post by rsilvers » Sat Jun 22, 2013 5:51 pm
Is 2 meters of total belt enough? Or do I really need 1.164M per belt?
Gemini64
Re: TAZ TK0
Post by Gemini64 » Sat Jun 22, 2013 10:36 pm
rsilvers wrote:I am using these:
I'm guessing the Delrin nut would need to be fastened to a modified Z_Nut_Spring?
http://downloads.lulzbot.com/lulzbot/TA ... spring_m6/
1013
Re: TAZ TK0
Post by 1013 » Sun Jun 23, 2013 7:40 am
Going with ACME screws and nuts on the Z-axis is WAY overkill. ACME is great if you have tons of weight to move, that is the reason it was designed (superior thread strength, and easier to rotate under large loads). If you have a hundred pound spindle to move, yes ACME is the way to go. But for a 10 to 20 pound X axis carriage on a 3D printer it is not worth the extra cost and complexity. I am sticking with the standard M8 all-thread and nuts.
Backlash in the screw is not as big of a deal either because you have very little Z-force trying to push the carriage up when you are extruding from a tiny nozzle. not like on a milling machine where there is a lot of force pushing back up like when you are drilling metal.
The weight of the X carriage assembly on a 3D printer will always be many more times that of the force from the pressure created from extruding the plastic, so simply relying on the weight to remove the backlash is perfectly fine.
...no need to over-complicate things IMO
rsilvers
Re: TAZ TK0
Post by rsilvers » Sun Jun 23, 2013 8:46 am
The higher efficiency of ACME is probably not needed since there is no heavy weight to add lots of resistance. But standard threaded rod is not designed to have minimum wobble or be straight - it is designed to be cheap, as it is usually used for hanging air-conditioner ducts, and price matters way more than precision - so they thread-roll them.
The ACME I ordered, while I am not sure that it is ground, was at least selected for linear-motion applications, and is more likely straight and concentric. Also the ends are reduced for coupling and so you don't need to grab on the pointy-threads - which are not necessarily concentric with the thread-pitch diameter. And finally it has a nice large base to the nut which is going to be more perpendicular to the threads once installed.
The cost is only $19 more, assuming you had to buy a whole bag of brass nuts as I would have.
