LulzBot TAZ Tool Head v2 skips filament
GekoCH
Post by GekoCH » Mon Aug 22, 2016 11:36 pm
Hy
Recently I upgraded my Taz4 to the new Toolhead v2.
With my timelapse camera I discovered some strange behavior for the first and sometimes second layer.
I uploaded a video to youtube: https://youtu.be/-NHitC6y6_k
On the right upper corner you see the filament spool turning. But suddenly it stops turning but the print head is still printing. So no filament is now printed just air. But then after a few moments the tool head started to feed again the filament.
What might cause this? Do you have an idea?
PS: Filament is normal PLA
Andy
piercet
Contact:
Re: LulzBot TAZ Tool Head v2 skips filament
Post by piercet » Mon Aug 22, 2016 11:45 pm
Check the extrude idler tension and the small gear setscrew. Also ensure that the bed isn't too high on that side. You may also have a motor cable short at full extension or retraction on x? But usually that is persistent. The video makes it almost impossible to see what is going on. A real time first layer clip with much higher resolution would be much more useful.
GekoCH
Post by GekoCH » Mon Aug 22, 2016 11:56 pm
thx for the help.
I think that the tension on the idler tension is already quite firm...
Or is maybe the bed too warm (60°C) and then the whole head gets to hot and the filament to flexible etc...
The short can't be the problem since the motor was still turning but somehow didn't push the filament through the nozzle...
And also the temperature was always at 205°C.
Andy
nopick
Post by nopick » Tue Aug 23, 2016 7:07 am
If the problem is reproducible, try aiming a small fan at the printer during the print to see if that corrects the problem. I have had an issue with the hotend fan on a couple printers where they are spinning but not at 100% so, on longer prints or prints with a lot of retraction, heat creep related filament swell will cause some sticking in the cold section of the hot end. That sticking results in intermittent stoppages and print failures.
kmanley57
Post by kmanley57 » Tue Aug 23, 2016 7:20 am
It might be a intermittent open on the motor wires is causing the motor to stop feeding on the right side of the bed.
GekoCH
Post by GekoCH » Wed Aug 24, 2016 6:04 am
nopick wrote:If the problem is reproducible, try aiming a small fan at the printer during the print to see if that corrects the problem. I have had an issue with the hotend fan on a couple printers where they are spinning but not at 100% so, on longer prints or prints with a lot of retraction, heat creep related filament swell will cause some sticking in the cold section of the hot end. That sticking results in intermittent stoppages and print failures.
Currently it is not reproducible however I will try this with the fan. I will switch the main Fan already on for the first layer and not just for the 2nd and higher.
Andy
killacycle
Post by killacycle » Wed Aug 24, 2016 2:29 pm
You are printing with PLA and I notice that you have the little blower cooling the heat sink on the hotend.
You are running into what is called "heat creep" in the PLA filament. Basically, the filament is softening too early in the extruder.
The new Taz 6 has gone away from the tiny blower and uses a big 40 mm muffin fan with a duct on the heat sink. (I think that is a bit overkill, but it does cure the problem.) Before they came out with that, I designed a duct and a 25mm fan for the heat sink similar to the ED3 design which pretty much cures the "heat creep" problem that you are having.
Here is a link to my duct design:
http://www.thingiverse.com/thing:1461335
Bill D.
nopick
Post by nopick » Wed Aug 24, 2016 3:32 pm
Andy
The filament cooling fan you can control won't have any effect if you have a heat creep problem. It is the small squirrel cage fan that can become weak and cause heat creep.
GekoCH
Post by GekoCH » Thu Aug 25, 2016 12:52 am
I have the v2 Toolhead this has the fan you describe or is it just too weak?
Andy
GekoCH
Post by GekoCH » Thu Aug 25, 2016 4:57 am
Sooo it just happend again... The print was 1/4 finished and suddenly it stopped feeding filament...
This time at a different position so it can't be the motor wire.
Andy
