Flexystruder v2 mount .stl
Posted: Sun Jan 29, 2017 4:15 pm
by ocelot27
Hi,
i've searched everywhere in the online repository of parts but I cannot find the .stl file (or any other file) for the Flexystruder v2 mount?
I just received the Flexystruder V2 from Lulz and the only mount I could find that's even remotely like it is not the correct one?
Any help pointing to this file would be greatly appreciated!!!
-john
Re: Flexystruder v2 body .stl
Posted: Sun Jan 29, 2017 4:52 pm
by kmanley57
Maybe it is in here.
/devel.lulzbot.com/TAZ/accessories/kanyu/production_parts/printed_parts/flexystruder_body_v2.0_for_hexagon/
Posted: Sun Jan 29, 2017 5:48 pm
by piercet
Did you buy the one for the Lulzbot mini instead of the one intended for the Taz? The mini one has a triangular mount point on the back. If it's the mini one and you need the Taz mount, you'll just want to grab the equivalent stock tool head mount for either the Taz 5 or the Taz 6, depending on which printer you own.
Posted: Mon Jan 30, 2017 6:02 am
by ocelot27
kmanley57 wrote:Maybe it is in here.
Sorry I meant the mount - not the body - the closest one I could find is just different than the one I have - and it's definitely not the mini...
As an aside - I use S3d - is there anything other than the correct number of esteps that I have to change in the firmware to switch to using it and switch back?
-john
Re: Flexystruder v2 mount .stl
Posted: Mon Jan 30, 2017 10:46 pm
by piercet
Ok, what Taz are you trying to fit the flexystruder to? If this is a Taz 3 or a Taz 4, the mounting notch is the same, but the mount height is different than a 5 or a 6. The main difference has to do with where the extruder actually sits height wise. What isn't working with the stock one? Can you post a picture of the one you have and the fit issue you are running into?
Posted: Tue Jan 31, 2017 6:04 am
by ocelot27
piercet wrote:Ok, what Taz are you trying to fit the flexystruder to? If this is a Taz 3 or a Taz 4, the mounting notch is the same, but the mount height is different than a 5 or a 6. The main difference has to do with where the extruder actually sits height wise. What isn't working with the stock one? Can you post a picture of the one you have and the fit issue you are running into?
It's a brand new T6 - the flexy V2 fits fine - I'm just looking for the mount file for a laser project - I found one that's close but not exactly the same... just strange that I can't find the exact production part that I have anywhere?
-john
Posted: Tue Jan 31, 2017 8:07 am
by kmanley57
I think you will find it is using the V1 mount.
https://devel.lulzbot.com/TAZ/Juniperbu ... mount_hex/
AKA - single right side fan mount or at least that is what it looks like in the picture.
