Did I just kill my TAZ 6?
cloud2blue
Post by cloud2blue » Tue Mar 07, 2017 12:56 pm
I went to remove a blob on the nozzle with some tweezers. As I am making contact with the nozzle everything goes dead. The red power light comes on, but nothing else. Did I just short out my power supply? The only fuse I see is a 15amp blade on the board and it is fine.
Please help, I love this printer.
piercet
Contact:
Re: Did I just kill my TAZ 6?
Post by piercet » Tue Mar 07, 2017 1:15 pm
You just blew a fuse most likely. If you bridge the heater core wires to the nozzle with the auto leveling, BAD THINGS occur. You'll want to replace the two small grain of rice sized fuses inside the control box on the rambo board. The larger bed fuse should be ok. If you are still under warranty a call to support might not be a bad idea.
cloud2blue
Post by cloud2blue » Tue Mar 07, 2017 1:58 pm
I emailed support and then took a multi-meter to start checking continuity. By the time I moved everything to get to the panel and had removed it, I got a response from Tech Support. Piercet, you are correct, I blew Fuse F3: Logic, Heat, Fans according to this picture: http://reprap.org/wiki/File:Ramb1-2-fuses.jpg
The thing I love is they included links to replacement fuses from 4 different suppliers in the email response. Talk about above and beyond.
NEW RULE #1: NO metal anywhere near the nozzle when the power is connected. EVER!
vesteroid
Post by vesteroid » Sun Mar 12, 2017 9:27 pm
any chance you would copy paste the sources for those fuses, I would like to get a few spares on hand
lulz4ba
Post by lulz4ba » Sun Mar 31, 2019 2:41 am
This just happened to me. Would love to get links too if anyone has them while I hunt around for more info.
pops
Post by pops » Sun Mar 31, 2019 8:58 am
I did a similar thing using a wire brush in the nozzle. Keep those tweezers handy as you are going to need them once you see the size of the fuse you are going to have to replace. Should be a law against producing such a small object that fat fingers may have to be used. :)
lulz4ba
Post by lulz4ba » Sun Mar 31, 2019 9:12 am
I placed my Amazon order but am now looking for a place I might find one in an *actual store*, on a Sunday, in the Bay area.
Too bad I can't just jam a penny in there, or a gum wrapper. ;)
zachah
Post by zachah » Fri Apr 05, 2019 8:51 pm
We have fuses available in packs of 3 on our lulzbot.com store page:
https://www.lulzbot.com/store/parts/5-a ... olyfuse-x3
johnson
Post by johnson » Sun Apr 07, 2019 2:31 pm
If you are needing to buy the fuses locally, the small white fuse holders are Little Fuse OMNI-BLOCK fuse holders. They are compatible with NANO2 Fuses. Fast or very fast acting are recommended. An example part number for replacement fuses is 0448005.MR
