My TAZ 5 stops and no longer wants to print
Ernesto Renteria
Post by Ernesto Renteria » Thu Jun 15, 2017 9:08 am
Everything was fine but today the printer no longer wants to print, when I want to make a piece the printer starts well, but suddenly stops and no longer continues. Already try to pause it and give it continue, does the calibration movement but does not continue with the work.
Cancel the works, the command to print again but the same thing happens again.
jim2386
Re: My TAZ 5 stops and no longer wants to print
Post by jim2386 » Thu Jun 15, 2017 1:54 pm
Ernesto Renteria wrote:Everything was fine but today the printer no longer wants to print, when I want to make a piece the printer starts well, but suddenly stops and no longer continues. Already try to pause it and give it continue, does the calibration movement but does not continue with the work.
What does your serial terminal say when it stops?
Does your temperature of your nozzle and bed go up or stay at room temp?
Ernesto Renteria
Post by Ernesto Renteria » Thu Jun 15, 2017 4:34 pm
Hi Jim
The terminal remains as if the machine is printing.
The room is cold but the bed and nozzle temperature stays warm.
Rookie
Post by Rookie » Thu Jun 15, 2017 7:39 pm
Was you STL file clean? Did you run it through a mesh mixer and correct errors? That got me once.
viewtopic.php?f=36&t=2365&hilit=stops
Ernesto Renteria
Post by Ernesto Renteria » Fri Jun 16, 2017 11:53 am
After two attempts and to restart the computer, the printer finished the piece.
It is a simple but large piece, I did not verify the STL file, I do not know how to do it.
