Hotend REALLY clogged
mcamou
Post by mcamou » Tue Dec 19, 2017 12:07 pm
Hi,
I have an extremely bad PLA clog in the heatsink of my TAZ 5's Hexagon hotend (I assume due to heat creep?). In other cases I've been able to successfully clear rather nasty clogs by removing the nozzle and using a 2.5mm Allen wrench to push the clog back up, with the hotend at printing temperature. However, in this case the clog seems to be completely stuck: I've applied quite a bit of force and it refuses to come out.
I've gone so far as to disassemble the hotend, to the point where I have the heatsink with the pipe that goes in it. Using the Allen wrench to measure depths, the clog seems to be about 11mm long, starting about 15mm from the top of the heatsink. This being PLA, submerging it in Acentone will not help at all.
Any ideas how to clear this up? A Dual Extruder v3 is on its way to me but I was hoping to print a few things before Christmas!
I also wonder how unclogging the Dual v3 will work, since the filament path seems to be quite intricate, plus levelling the 2 nozzles after removing/replacing them could be a bit tricky.
mikronano
Re: Hotend REALLY clogged
Post by mikronano » Tue Dec 19, 2017 2:34 pm
Seems really bad. Have you tried to disassemble the hear break as well?
For dissolving the PLA, acetone might not be best but Weld-On No3 from SciGrip, believe me, it softens it very well. The thing is that being cooked and stuck in there so bad who really knows what kind of chemical could have any effect on that.
You could use a culinary blow torch or a hair dryer in an attempt to soften it up with heat and then try again to push it out. Just make sure you use pliers instead of bare hands to hold the hot heatsink!
Press a key to continue or any other key to quit
mcamou
Post by mcamou » Tue Dec 19, 2017 2:43 pm
D'Oh! You just reminded me of my heat gun. I'll attempt it that way. I'll also see if I can get that Weld-On stuff here in Spain, sounds good to have around!
mcamou
Post by mcamou » Wed Dec 20, 2017 4:17 am
The heat gun worked like a charm! Less than a minute at 350ºC right over the heat sink loosened it enough so I could push the clog out with a 2.5mm Allen wrench. Thanks!
mikronano
Post by mikronano » Wed Dec 20, 2017 7:30 am
Your're welcome! ;)
