Dual Extruder V3 - why angle the filament channel?
tbilan
Post by tbilan » Sun Feb 25, 2018 9:33 pm
I've done several multi-hour prints that failed hours into the print because the filament gets stuck in the chamber and quits feeding. This never happened with the single extruder because the channel was straight so the filament didn't have to go through any gymnastics to make it to the nozzle. For some reason this head was designed in a way that requires the filament to have to significantly bend to feed. I've used the jig to tighten the screws to the right distance but it didn't matter. I tried a few turns tighter but it doesn't matter. Tightening these screws and the curved chamber also makes it way too hard to load filament. Most of the time I have to untighten the screws to be able to hold it open to load, which then has me counting turns to get it back to jig depth. This seems like a bad design to me.
I've wasted days and 2 spools of filament on this V3 head between the temperature issues recall and these feed problems. I wouldn't be so mad if it would screw up instantly so I didn't stand around waiting hours for a 15-hour print and have it suddenly get stuck 2 hours into the print.
Is anyone else having these kinds of issues?
GJennings
Re: Dual Extruder V3 - why angle the filament channel?
Post by GJennings » Sun Feb 25, 2018 10:25 pm
The shared heat break parts and hot ends close together are key features of the V3 design. The drive end is spaced widely apart by the big drive gear and stepper motors. So you get the curved path to bring the feeds close together.
I had a problem with the V3 grinding the filament after a while (several hours into a print). I ended up running the extruder(s) a little hotter (+5 ~ +10 degrees) and the grinding problem went away.
With the V3 it is really important to let it get completely warmed up before removing the filament, including extruding some before reversing and pulling out the rest. If it isn't hot enough the filament will stick in the heat sink, resulting in gnashing of teeth. Also, nozzle removal, disassembly and careful drilling to get the stuck filament out.
kcchen_00
Post by kcchen_00 » Mon Feb 26, 2018 12:34 am
If the filament channel were vertical, the idler/tensioner levers would be practically inoperable... not to mention no access to the tension thmbscrews.
The Dual v3 gets even better when the filament breaks past the hobbed gear. Time for some filament runout sensors...
silent_ninja1
Post by silent_ninja1 » Mon Feb 26, 2018 9:41 pm
Im actually amazed at this point they havent incorporated one into a tool head. My cheap chinese CR10 ships with one... For my 2 S5 (500mm^3) machines its an absolute necessity. Just finished a part that used more than a 3kg spool...
I considered this guy as an active monitor
https://www.toybuilderlabs.com/products ... nt-monitor
Since itll detect jams and such as the OP was seeing.
Aha
Post by Aha » Wed Feb 28, 2018 5:31 pm
I would suggest you look at your temp settings. There's a few massive flaws in the cura programming - the cold start can cause jamming issues if you don't let it warm up before starting extrusion. If you run your temps higher and wait longer to start, you'll see some improvement. Also, loop your filament differently than currently set up if you have an issue. The more you have the filament trying to reverse curl, the more you'll fight it. If the curl is going with you, it will be a bit less. And more heat makes it much easier.
Then you should look into ooze shields and your retraction settings since they will change once you up the heat.
That's certainly an interesting upgrade I'll have to look at to check for filament feed; though I've just about never had a problem with running out of filament, it's always something going wrong in the hot end or at the roll so it just doesn't MOVE.
Artful_dodger
Post by Artful_dodger » Sun Mar 18, 2018 4:48 pm
I've noticed this problem with the feed angle and hobbed gear chewing the material and stopping the feed. I have had to tear down my dual extruder v3 a couple of times to recover.
Once a small chunk (3mm x 3mm) of material got stuck in between the feeder and heating block when pulling material for swap. Too high to melt it, and wouldn't drop into the nozzle because of the change in angle where the two components meet.
Another the hobbed gear chewed the material feed early into an overnight print, and enough material oozed out to create a void in the nozzle, with the block unable to melt the material at the top of the block. Had to disassemble and torch to clean out that one.
I would recommend an increased diameter hobbed gear, with more surface area to grab the feed material. Increases resistance to both chewing filament and the force required to feed.
The single extruder feed mechanism is certainly more robust.
kcchen_00
Post by kcchen_00 » Sun Mar 18, 2018 7:01 pm
Sounds like your idler levers aren't applying enough pressure on the filament for the hobbed bolt to get a good bite. When you unload the filament, can you feel the teeth of the hobbed bolt against the filament?
Make sure to use the idler spacer to get the right tension on the lever springs. I like using the spacer on the unloaded lever... And honestly, it doesn't hurt to give it another turn or so. The limiting factor would be the ability to unclamping to remove the filament. I guess, as long as you get 3-5mm of movement on the lever it should be clamping the filament to the hobbed gear pretty well.
I've found that I have to print filament a little hotter with the V3...
Oh well... My Dual V3 is doing great. Prints from either extruder look like a single nozzle toolhead. There is a learning curve coming from the v2. I think there's a lack of appreciation for this toolhead from those who didn't experience the cludginess of the v2.
Artful_dodger
Post by Artful_dodger » Mon Mar 19, 2018 2:30 pm
In my case for the idler to hobbed gear tension, yes, I can see/feel where it bites the material when retracted. It's a couple of turns tighter than spec (spacer with no filament loaded). Could try clamping down all the way. Was thinking of replacing the idler bearing with a rubber bushing to see if it provides more even pressure against the gear.
Last attempt to up temperature for less resistance going into the nozzle wasn't helpful. I felt it made it easier for a nozzle void to be created once the feed stopped.
I'm currently planning to change either the approach angle of filament again, or attempting to lubricate the reel in order to have less friction through the channel. I switched to an overhead filament holder when I received the v3 because of binding at the entry point to the tool head. But might try a tabletop holder on the left and right of the bed so the spool curvature matches the entry curvature better...
Spacemonkey1023
Post by Spacemonkey1023 » Mon Mar 19, 2018 6:25 pm
I just wish there was an easier way to load the filament. It's pretty much a blind procedure and if I'm unlucky it takes forever until the filament finds its way into the channel just right.
kcchen_00
Post by kcchen_00 » Mon Mar 19, 2018 8:54 pm
Okay... understand what you mean by nozzle void from "ooze". If the increase in temp worked, then try adjusting the retraction distance. The retraction will create a vacuum that reduces / slows the ooze or dripping of melted filament...
@Spacemonkey1033 - You're probably doing it, but make sure to cut the filament into a "chisel" before inserting. Then insert chisel tip down... This is a case where a picture is worth 1000 words: https://ohai.lulzbot.com/project/LulzBo ... cessories/
