Don't skimp on wiring! / Taz 5 + duet + rebuild
pepperoni
Post by pepperoni » Sun May 20, 2018 6:25 pm
My Taz has been good to me for the past 3-4 years. However, I randomly discovered that the bed connector was a bit charred and that could have made for a bad day. I wanted to give the printer an overhaul, which included replacing the Rambo with a Duet. I had a lapse in judgement when I decided to extend the bed wiring with 16awg. Started to smell after I fired up the printer but at least it didn't quite smoke. Ended up bypassing the Amp connector and ran PowerPole connectors straight to the Duet and crimping a new pigtail for the sensor.
kmanley57
Re: Don't skimp on wiring!
Post by kmanley57 » Mon May 21, 2018 6:18 am
Well a couple years ago I ran the 16 Gauge bed wires straight through the AMP connectors to the Bed plate connector, Have not had an issue since, but not everyone has the AMP connector pin removal tool like I did.
pepperoni
Post by pepperoni » Mon May 21, 2018 3:05 pm
Do you mind posting a shot of what your amp removal tool looks like? I have the one from Molex to remove circular Molex pins and while it fits the pin perfectly, I'm unable to fit it between the pin and the connector housing. I'm referring to the female pins. Perhaps I'm not even removing it right.
This is what my Molex tool looks like.
kmanley57
Post by kmanley57 » Tue May 22, 2018 9:04 pm
Looks like this Amazon LInk
pepperoni
Post by pepperoni » Tue May 22, 2018 10:16 pm
Oh I've seen that before but it looks remarkably similar to what I have. Will it extract female pins as well?
kmanley57
Post by kmanley57 » Wed May 23, 2018 5:15 am
Yours will release the locking tabs but requires you to pull the pin out, while the other has a plunger that helps press it out. Both work to release the tabs the same, one just makes it easier to remove the pin if the wire comes out of the crimp.
silent_ninja1
Post by silent_ninja1 » Wed May 23, 2018 4:50 pm
Not all wire types are created equal! Different flex ratings and ampacity for say THHN vs MTW vs UF, Aluminum vs Copper. Check what you use :)
piercet
Contact:
Post by piercet » Fri May 25, 2018 1:07 pm
Part of the problem with that bed connector specifically is it isn't rated for the full theoretical amp draw of the bed connection. So it can melt.
pepperoni
Post by pepperoni » Sun May 27, 2018 3:24 am
Going straight from Duet to Anderson PowerPoles now. While I have the printer apart, I'm re-printing all your openbuild mods, and every stock Taz part in CF Nylon :)
piercet
Contact:
Post by piercet » Sun May 27, 2018 5:33 pm
Nice! That will be rediculoudly sturdy!
