TAZ6 Bed Vibration
pops
TAZ6 Bed Vibration
Post by pops » Fri Feb 15, 2019 9:04 am
My bed has started to vibrate when moving (see movie) and I cannot detect where the vibration is coming from. It is getting worse the more I print. I have wiped the rails with a microfiber dry cloth and the bed motor seems tight in its mount. The belt also seems snug.
Can anyone help me with this issue?
IMG_0575.MOV
(12.94 MiB) Downloaded 33 times
Orias
Re: TAZ6 Bed Vibration
Post by Orias » Fri Feb 15, 2019 9:32 am
Try using a green scrub pad to clean your smooth rods. Over time, the self-lubricating bushings will leave a residue on the smooth rods. Reach out to the support team for detailed assistance after that.
piercet
Contact:
Post by piercet » Sat Feb 16, 2019 12:54 am
I agree, those rods definitely look like they need a wipe down.
kmanley57
Post by kmanley57 » Sat Feb 16, 2019 3:06 pm
I would check and see if you are not rubbing one of the belt ends on the teeth of the belt.
pops
Post by pops » Thu Mar 14, 2019 10:47 am
I've wiped, checked belts, confirmed belt tightness, changed linear bearings and still have this bed vibration. It is so violent that it induces layer shifting. I've been working with support but have not fixed this issue. It's like some harmonic resonance takes over only on the Y axis.
Open for more ideas......
nopick
Post by nopick » Thu Mar 14, 2019 11:53 am
That could be a failing Y motor drive on the Rambo.
kcchen_00
Post by kcchen_00 » Thu Mar 14, 2019 9:26 pm
Check the belt mounts on the bottom of the bed... The screws can loosen over time.
pops
Post by pops » Mon Mar 25, 2019 7:17 am
Following "Supports" suggested tests it has been determined that my Rambo board's Y axis is bad. New board on the way.
nopick
Post by nopick » Mon Mar 25, 2019 2:54 pm
Glad you got it sorted out.
