Does anyone know where I could get longer cables from the box to the printer so I can remove the control box from the frame and mount it somewhere else? A 10 foot or so harness would be ideal.
If you’d like to build your own longer harness, use the source files for your printer found here: http://download.lulzbot.com/. The connectors and pins we use are common and easy to build. The crimpers needed can be found online rather inexpensively.
