TAZ Very loose Solid rod bearings?
1013
Re: TAZ Very loose Solid rod bearings?
Post by 1013 » Tue Jun 11, 2013 11:50 am
Thanks,
If new bearings from Lulzbot don't do the job. I was thinking of trying these out. http://www.realrecreationusa.com/p/10pc ... 85616.html
But at that price, they are probably not that accurate.
Orias
Post by Orias » Tue Jun 11, 2013 12:14 pm
One thing we've tried today is loosening the double and single bearing holder on the X-carriage. Squeeze them towards each other and then tighten them back. That pushes pressure against the bearings and still allows for smooth movement.
1013
Post by 1013 » Tue Jun 11, 2013 4:57 pm
i will try that. it should help some
aadamson
Post by aadamson » Tue Jun 11, 2013 8:41 pm
You noticed that too... Mine are *extremely loose... you can rattle my X axis quite a bit. I noticed this when I went to clean the nozzle and the whole bottom of the assembly moved... granted it has a bit of weight so it doesn't move unless you try to move it, but there is lots of *slop* in the X axis bearings from what I can tell.
In looking at my 1 week old TAZ it has a double bearing on the top X rod, and a single on the bottom. Both are loose, but the bottom moreso than the top. Should the bottom bearing setup be a double as well?
And this isn't isn't the white bearing in the holder, it's the white bearing on the shaft. There is probably on the order of 1/32 or more *play* between the white *teeth* of the bearing and the rods. I looked at the top one as well and it was better, but not by much... I haven't even looked at the Z or Y axis stuff to see if they suffer from the same problem.
If the bottom of the X is supposed to be a double, how do we get another bearing?
Looks like I as well will try the squeeze test...
Alan
1013
Post by 1013 » Wed Jun 12, 2013 6:47 am
Tried the squeeze mod. You do have to hold the squeeze as you tighten all the bolts, but it is certainly better.
jebba
Site Admin
Post by jebba » Wed Jun 12, 2013 9:13 am
The bottom on the extruder just has one, not two, by design.
elgullitch
Post by elgullitch » Thu Jun 13, 2013 7:57 am
I've been getting very irregular layers and waviness in my prints. It seemed like there was excessive vibration with resonances. After reading this post, I checked my linear bearings and about half of them have the same problem discussed here. There is significant slop in two of my y-axis bearings and all three of my x-axis bearings. This seems to be a real issue -- I'm going to file a support ticket.
aadamson
Post by aadamson » Fri Jun 14, 2013 7:18 pm
Speculation, but if you read the data sheet these are designed as a press-to-fit part and as such the documentation says that they were will oversized in *free state*...
http://www.igus.com/wpck/default.aspx?p ... n_r_rjm_01
Quote from the datasheet
Designed as a press-fit part, it will be oversized in free-state
Might the other 10mm versions that have the same outside dimensions be a better solution and closer tolerance? I doubt much *pressing together* is going to do anything for the tolerance issue, you are just expecting that stretching those tolerances against the outside of the 2 rods will address the issue, but unfortunately, that will only occur in one dimension...
Just a thought,
Alan
1013
Post by 1013 » Fri Jun 14, 2013 7:25 pm
elgullitch wrote:I've been getting very irregular layers and waviness in my prints. It seemed like there was excessive vibration with resonances. After reading this post, I checked my linear bearings and about half of them have the same problem discussed here. There is significant slop in two of my y-axis bearings and all three of my x-axis bearings. This seems to be a real issue -- I'm going to file a support ticket.
check the tightness of EVERY screw....i found several that were loose. They can loosen during printing too, I would re-check them periodically too.
1013
Post by 1013 » Fri Jun 14, 2013 7:33 pm
aadamson wrote:Speculation, but if you read the data sheet these are designed as a press-to-fit part and as such the documentation says that they were will oversized in *free state*...
Just a thought,
Alan
Good catch, and that makes sense as to why they are all a little loose.
I did replace the 3 in the X-carriage with ball bearings, Since I added the extra weight of another extruder/hotend and wanted to reduce the friction. Nice and tight now. Might replace all of them with ball bearings eventually....I have noticed some hysteresis in the Z-axis, and excess friction certainly does not help that. The Y axis seems OK with these bearings though.
