This has just started and doesn’t happen all the time. The nozzle levels at the front two washers. But when it traverses to the right rear washer if falls a little sort of even getting there and the nozzle presses in to the bed. ???
Reach out to the support team at LulzBot.com/Support. They’ll be able to walk you through a quick check of your hardware. Some homework: check that the bed and tool head have a full range of travel and that nothing is blocking the endstops at the left hand side of the x-axis, and at the rear of the y-axis. You should hear an audible click when at the end of the travel range. Grab the latest firmware included within the current version of Cura LulzBot Edition as well.
