I have 2 taz 6’s running off the same computer using simplify 3d. I use the same profiles for both printers, one is running just fine, the other went to hell and i can not for the life of me figure it out. I am sure it is something simple that I am missing (one can hope right?)
Issue: The extruder head will not move in the negative direction on the x-asis. It will more to the positive side (right) with no issues. I have made sure the motor is working correctly. Also I have made sure the limit switch is function correctly. With having two identical printers, I am able to switch parts quickly and test if that is the issue or not. Also, I have updated the firmware on the printer, again not thinking this would fix the issue because only one printer is having this issue. That was my last effort before turning the the forms. Please help!
Visual aid: When I manually line everything up and start a print try to see what is going on, it will get to the wipe nozzle part, but refuse to move in both positive and negative directions on the x-axis. So i end up with the nozzle in the middle of the bed (thinking that his has wiped correctly) then goes to where it thinks the front right washer is for self leveling and starts to lower itself for that process. That is where I have to shut it off as it will push the nozzle straight into the middle of my printing surface.
