Setup and use.
smswedenburg
Setup and use.
Post by smswedenburg » Wed Jun 12, 2013 10:22 am
Lessons so far.
I need to replace a melted Lower left corner platen clip.
going to 0,0,0 with a hot extruder clobbered the clip.
These should probably be Aluminum or BECu.
I have printed several parts, few issues so far, mostly Z axis setup, and priming the extruder.
4 easy prints so far, no issues other than poorly edited G-Code on my part.
Looking for a chart with Material, Temperatures, rates. Starting my own spreadsheet but would appreciate a link to data if available.
Very good investment so far.
Orias
Re: Setup and use.
Post by Orias » Wed Jun 12, 2013 10:51 am
We have some information here: Filaments.
geneb
Re: Setup and use.
Post by geneb » Wed Jun 12, 2013 4:21 pm
smswedenburg, I'd recommend loosening the y axis mounts and sliding the whole thing towards you about 10-20mm. This will prevent the nozzle from striking the bed clip when at zero.
g.
1013
Re: Setup and use.
Post by 1013 » Wed Jun 12, 2013 4:50 pm
or just rotate the foot that clamps the glass 30 degrees or so....so it is out of the way, but still clamping
geneb
Re: Setup and use.
Post by geneb » Thu Jun 13, 2013 8:39 am
1013, that really doesn't work (at least with my TAZ it didn't). As-shipped, the zero point appears to be precisely on the corner of the glass. The only way to keep the hot end from striking the clamp is to either move the whole Y axis a bit as I suggested, or remove the clip. There's no position where it'll be out of the way as long as it's present.
g.
Orias
Re: Setup and use.
Post by Orias » Thu Jun 13, 2013 9:10 am
I've been able to just move the glass clip out of the way as well.
1013
Re: Setup and use.
Post by 1013 » Thu Jun 13, 2013 10:22 am
geneb wrote:1013, that really doesn't work (at least with my TAZ it didn't). As-shipped, the zero point appears to be precisely on the corner of the glass. The only way to keep the hot end from striking the clamp is to either move the whole Y axis a bit as I suggested, or remove the clip. There's no position where it'll be out of the way as long as it's present.
g.
It's possible that your Y-slide is in a slightly different place than mine. Or perhaps your X-axis (or Y-axis) limit switch is pushed in more, allowing the slide to shift over more....I could see moving the home switch in X or Y a small amount fixing your issue.
These things can shift a little in shipping too, and maybe your whole Y axis assembly is sitting in a slightly different spot than on my machine.
eric_german
Re: Setup and use.
Post by eric_german » Thu Jun 13, 2013 11:16 pm
is it possible to adjust the x axis limit switch? my extruder homes to x ~3mm towards the center of the bed, thus at the very extreme of x the extruder is off the bed entirely.
Orias
Re: Setup and use.
Post by Orias » Fri Jun 14, 2013 8:01 am
Take a look at the X axis endstop which is built into the motor X end. The plastic housing of the endstop microswitch should just be visible. You can adjust that as needed for a few millimeters by loosening the small set screw within the brass insert above the endstop microswitch. Tighten the set screw to secure the endstop once you have it positioned.
