Printed parts shifting with the TAZ
3hassa3
Post by 3hassa3 » Wed Jun 12, 2013 10:43 am
I just got a new TAZ and I've attempted to print two different larger parts (6+ cm high) and both times the print shifts somewhere in the middle and ruins the print...very frustrating. Any help?
Orias
Re: Printed parts shifting with the TAZ
Post by Orias » Wed Jun 12, 2013 10:51 am
Can you post a picture of what's happening? Is it only happening on one axis?
3hassa3
Post by 3hassa3 » Wed Jun 12, 2013 10:59 am
I dont have a picture right now, but somewhere in the middle of the print, it shifts in both the x and y axis and continues to print on top of the shift
3hassa3
Post by 3hassa3 » Wed Jun 12, 2013 11:37 am
Actually the shift seems to be only in the x axis. Here's a picture, if i let it continue printing, it would have printed on top of the shift
Orias
Post by Orias » Wed Jun 12, 2013 12:02 pm
What speeds are you using? I would recommend looking at the tension of your X-axis belt. It should be as tight as the Y-axis belt. When you press on the belt it should have a little bit of movement then springiness. With the printer off, when you move the X carriage back and forth how does the belt respond? Is there any drooping of the belt? Is it staying on track?
3hassa3
Post by 3hassa3 » Wed Jun 12, 2013 12:19 pm
The x belt tension is good, it's springy, there is no drooping and it stays on track.
speeds:
perimeter: 120
infill: 160
Support: 150
travel: 200
__pepsi__
Post by __pepsi__ » Wed Jun 12, 2013 4:09 pm
Hi all,
Had this problem with the ao100. Seemed to be the stepper drivers that got too hot. Sloved it by adding heatsink to the drivers.
-Fredrik
Orias
Post by Orias » Thu Jun 13, 2013 7:58 am
The TAZ uses the RAMBo board, so heatsinks are not used. Have you noticed this with any other files? Is everything else on the x axis tight and secure (pulley, etc)?
