HS Tool Head 0.8 Made a expensive mistake
B-Hep-Spring
Post by B-Hep-Spring » Wed Jun 26, 2019 1:04 pm
Hi All
I purchased the HS Tool Head 0.8 thinking stupidly it was based on the Aeroe head but with hardened drives act,, I find it has a Volcano fitted which is not what I wanted to achieve I want to print with carbon but want to print fairly small parts with a .4 nozzle, which you cant buy in volcano nozzles,, question is it possible to remove the volcano and replace it for V6 parts, this will leave me with two problems the nozzle will be further away from the bed and the fan shroud would need replacing, would the esteps then be out of sync... any help and suggestion greatly received...
JoeBowler300
Re: HS Tool Head 0.8 Made a expensive mistake
Post by JoeBowler300 » Wed Jun 26, 2019 6:26 pm
I’m not sure what you mean that you can’t buy a .4 volcano nozzle? I just bought some on amazon for my dually v3. eBay sells them too. What you can’t find is, is a .5 volcano nozzle unless you by it directly from E3D in the UK.
B-Hep-Spring
Post by B-Hep-Spring » Thu Jun 27, 2019 12:42 pm
Joe
I stand corrected it must have been a senior moment :(
thank you for your reply is your volcano working well and is the nozzle easy to get out?? hot obvioulsy
JoeBowler300
Post by JoeBowler300 » Thu Jun 27, 2019 4:38 pm
It’s just as easy to get out as the standard nozzle just more threads. Use the same method, heat it up, shut the printer off, hold the heater block from twisting with a wrench or pliers, unscrew nozzle. Yes mine is working good, in fact, I think I like the volcanoes are better because of the longer melt zone. Good luck with your project. 👍
B-Hep-Spring
Post by B-Hep-Spring » Fri Jun 28, 2019 12:33 pm
Thank You for your reply a great help..
