Hot end heating problem
A forum dedicated to the stock LulzBot AO-101/AO-100 3D Printer
gannon
Re: Hot end heating problem
Post by gannon » Thu Sep 05, 2013 8:58 am
Well, it could have been heated by the current passing through the connector (IIRC those are rated fro 1-2 amps), or it could have been heated externally (from the hotend).
I'm not sure which, but unless the connector was really close to the hotend I would guess the former.
Orias
Post by Orias » Thu Sep 05, 2013 9:24 am
It can be caused by an intermittent connection and the tiny bit of arcing that will occur. The connectors and pins you need are:
Male connector pins, 24-30 AWG Digi-Key 16-02-0108
Female connector pins, 22-24 AWG Digi-Key 16-02-0102
CONN HOUSING MALE 4POS .100 Digi-Key 0701070003
CONN HOUSING 4POS .100 W/LATCH Digi-Key 0050579404
QuantumVenom
Post by QuantumVenom » Thu Sep 05, 2013 10:48 am
Thanks for the help everyone! I will be ordering new pins and housing. Hopefully this will fix the issue and allow me to have a more permanent connection.
Thanks again,
Chris
kv1
Post by kv1 » Fri Apr 10, 2015 2:22 am
please check out this thread, as it evolved into the main something does not heat up thread:
viewtopic.php?f=36&t=104&p=11633#p4040
I posted an alternative to the green resistor here (same thread):
viewtopic.php?f=36&t=104&p=11633#p11633
