upgrade AO-101 with LulzBot v2 (Hexagon) Hot End
A forum dedicated to the stock LulzBot AO-101/AO-100 3D Printer
ic3wall
Post by ic3wall » Fri Nov 27, 2015 5:05 pm
Hi guys,
I just noticed that the LulzBot v2 (Hexagon) Hot End is supposed to be compatible with the AO-101.
I already have a budaschnozzle 2.0c, but I'm having clogging issues, so it looks like a good occasion to upgrade!
My question is how hard is it to fit an AO-101 with a LulzBot v2 (Hexagon) Hot End ? Are there any instructions somewhere ?
piercet
Contact:
Re: upgrade AO-101 with LulzBot v2 (Hexagon) Hot End
Post by piercet » Fri Nov 27, 2015 7:55 pm
The ao-101 is a 12 volt printer. You will need to source a 12v heater core or upgrade your entire electronics to 24v, which given the much improved bed heating time is not a bad idea. The 101 has the Rambo board if I remember right, so that might just take a bed and a power supply.
The wires are going to hook up the same, but I am pretty sure no one has made an a 101 hexagon firmware yet so you would need to adapt that from the taz 5 firmware. That's mainly going to be copy and paste if the relevant sections.
ic3wall
Post by ic3wall » Fri Nov 27, 2015 8:27 pm
Thank you Piercet but I'm not sure I want to dive in such modifications...
This printer is giving me headaches, there is always something that goes wrong .. I wish lulzbot had an upgrade program where you could get a discount on a new printer when you send the old one!
