AO-100 "vibrations"
A forum dedicated to the stock LulzBot AO-101/AO-100 3D Printer
sportbikeryder
AO-100 "vibrations"
Post by sportbikeryder » Wed Apr 24, 2013 5:57 am
I have an AO-100, still in original AO-100 configuration with original firmware. Recently (last night) I noticed an unusual vibration in the X and Y travel.
I have a bit of experience in CNC setupm and is seems as if it is a motor tuning issue. This causes the printer to loose its position midway through a print (~ .500" off) in one direction. The print continues fine afterwards, but when losing its steps, a fairly ominous buzz / vibration occurs (again, sounds like the stepper is fighting itself).
Additionally, the vibration seems to be stepper induced rather than an issue with the linear motion slides as it does not change with light hand pressure on the carriage or table while in motion.
The vibration is evident int eh printed material as well as the extrusions are not smooth, rather slightly rough looking.
I have the smaller motor pulleys to change the X adn Y drive ratio, perhaps this is a good time to change them out and tweak the machine parameters accordingly to see it it helps.
I have been using the machine for some parts for my turbocharged dragbike, namely brackets to relocate the fairings, as well as some tools to aid in marking tubing for the turbo system plumbing.
John
Orias
Re: AO-100 "vibrations"
Post by Orias » Tue May 07, 2013 7:26 am
You can see if the current on the Pololu stepper drivers need to be adjusted. You can find a guide in our Support section. Are any of the stepper motors getting hot? How hot are the stepper drivers?
sportbikeryder
Post by sportbikeryder » Wed May 08, 2013 12:10 pm
As an update on this, the issue basically disappeared on its own and hasn't returned. No unusual heating on the steppers when it did happen.
