Extruder Struggling
A forum dedicated to the stock LulzBot AO-101/AO-100 3D Printer
jebba
Site Admin
Re: Extruder Struggling
Post by jebba » Fri Jan 10, 2014 4:00 pm
The ABS is all pretty similar, but some colors just seem to have a better finish than others. The LulzBot green looks pretty awesome. Good old black works well, etc. Probably the only one that is a bit different is the glow in the dark.
piercet
Contact:
Post by piercet » Fri Jan 10, 2014 4:09 pm
Learning to print with dark green on dark green Kapton tape is to be avoided if you can. I learned that the hard way heh.
Theycallmejohn
Post by Theycallmejohn » Sat Jan 11, 2014 8:03 pm
Well now I did it... I messed up the nozzle. I tried to take off the nozzle without heating it up and I ended up stripping out the threads on the shaft. I think the nozzle is still salvageable.
I am very frustrated with myself because this now mean I won't be able to print for another weekend!!!
Does anyone have any suggestions on how to get the PEEK insulator off with out ruining it?
Also I found the original problem I think. The nozzle was not fully seated on the threaded rod...
Stripped Shaft
Theycallmejohn
Post by Theycallmejohn » Sun Jan 12, 2014 10:43 pm
Success (or at least from the moment). Today I made the long drive out to Deezmakers in Pasadena CA. They were able to hook me up with some spare parts and gave me some good advice.
Lessons Learned
1) MAKE SURE THE NOZZLE IS ALL THE WAY ON!!!
2) Use some anti-seize when you take your nozzle off.
3) Nozzles are not meant to be taken on and off frequently
4) Listen to others advice (Like Orias - would have saved me several hours and about 60 bucks)
5) Patience. I tried to rush a couple things and it ended up costing me time and money.
Well I am happy to be back up and printing...
Back up and running
jebba
Site Admin
Post by jebba » Mon Jan 13, 2014 10:20 am
Cool, glad you got it up & running. :)
lotw
Post by lotw » Mon Jan 13, 2014 12:34 pm
Theycallmejohn wrote:Well now I did it... I messed up the nozzle. I tried to take off the nozzle without heating it up and I ended up stripping out the threads on the shaft. I think the nozzle is still salvageable.
That happened to me too. They tell, in the instructions to use plumbers tape, but when the unit ships doesn't have any on it, so you cannot replace top easily after a while without out the stripping happening. I have two nozzles now, one with a 0.50mm tip and one with a 0.25mm tip. Normally only use the 0.50mm unless I want really good quality and have lots of time.
Orias
Post by Orias » Tue Jan 14, 2014 9:34 am
We ship all Budaschnozzles with a treatment of high-temp anti-sieze compound on the nozzle threads. If you were to use the PTFE plumbing tape, you'll find that it can make removing the nozzle really, really hard. The anti-sieze compound was found to work best, but the type we are using is not readily available in smaller quantities and so, if you're not going to be removing the nozzle, plumber's tape is a more readily available solution. If you are going to be switching nozzles often, use high-temp anti-sieze compound instead.
Theycallmejohn
Post by Theycallmejohn » Sun Jan 19, 2014 1:50 pm
I just used some Permatex Anti-Seize Lubricant http://shop.advanceautoparts.com/webapp ... anti-seize it seems to work okay so far.
So I apparently I didn't seat the PEEK Insulator all the way and now its clogged and in the process the heat resistor broke. I was going to order some repalcement parts from Lulzbot but they are out of stock. Does anyone know if something like the 12V 40W Reprap Cartridge Heater http://www.robotdigg.com/product/19/12V ... dge-Heater would work with the Budaschnozzle? If so what changes would I have to make? Would the best way to secure it be with a set screw?
Also does anyone know where I could get the little wire crimper things?
What size is the set screw for the Budaschnozzle block?
Theycallmejohn
Post by Theycallmejohn » Tue Feb 11, 2014 12:26 pm
Hey Guys,
I am still having issues. I don't know if its the filament our what but I got the new heater installed ran the PID update. I had a couple successful prints then a third of the way thru printing a job a on Friday night. The extruder jams again.
I stopped the print pulled out the filament, cleaned out the hobbled bolt and put the filament back in.
After warming it back up I used the manual extrude on Repetier and probably a small amount of filament came out put not the normal amount. I went to run a print and there wasn't enough pressure.
I also checked the filament and it was spinning freely.
Would pointing a fan at the heat sinks help? My only though is that as it heats up it starts to jam.
I am getting pretty frustrated and could really use some advice. Maybe this is why this printer was for sale on ebay... :cry:
piercet
Contact:
Post by piercet » Tue Feb 11, 2014 12:55 pm
With extruder issues, you want to start at the source spool and work your way down to check things.
1. Can the filliament spool move freely, or is it caught on something?
2. is the filliament feed tube allowing the filliament to move through freely with no restriction (spcifically are the zip ties holding the tube in place too tight?)
3. Is the filliament binding where the idler filliament guide contacts the upper extruder body? (If so, sand some material away until it is able to move freely
4. Is the hobbed bolt grinding chunks out of your filliament?
A. If yes, you have either a temperature or force issue for feeding.
B. If no, your small gear on your NEMA motor isn't tightened at the set screw all the way or your main gear is installed on the hobbed bolt incorrectly.
If you are getting chunks ground out of your filliament, there are several possibilities. One is that your idler is either not tight enough, or too tight. Not tight enough will wear away filliment slowly and won't move it much. Too tight will immidiatly rip chunks out of the filliament. A clogged filliament chamber can also do this. Remove any excess shavings, make sure the bearings are not impacted, and clean the hobs of the bolt out with a toothpick or other pointy object.
If all that looks correct and you still aren't able to feed filliament through the hot end, I'd suspect that it is not actually getting up to temperature. That would be really rare, and usually you would just see a working or dead hotend, not one kind of working unless the temperature was set wrong. If you are extruding ABS at 230 degrees C, it should come out with almost no resistance at all. If you try and print too close to the bed for the first layer and don't catch it in time, that backpressure can cause the filliament to stop and get chunks ground out of it.. If the extruder itself has a malformed filliament channel that can cause binding and cause the grinding issue, Stick a piece of filliament in that section and see if it moves properly. if it sticks, grind the hole out bigger on the ABS plastic exruder body itself (not your hot end)
Another troubleshooting step, dismount the hot end entirely and run filliament through the extruder. if its moving and moving properly, the trouble may not be there.
If you can, take a bunch of pictures of your extruder, the hot end, the idler chamber, the gears, etc. and post them here. maybe we'll get lucky and spot the issue?
