How to generate manifold printable .stl's from .ply
A forum dedicated to the development of Free Software, Libre Innovation, and Open Source Hardware (FLO) 3D Scanners
rufu5
Post by rufu5 » Wed Jun 10, 2015 1:49 pm
I've recently had the opportunity to try the Ciclop, an open source hardware desktop laser scanner. The recommended software is Horus, which will export a colored point cloud in .ply file format. You can't print a .ply directly, because the slicing engines available are designed to work with manifold surfaces, like those found in good .stl's, .obj's, and .amf's. As Horus is developed, I think we will see more file processing options, like trimming, alignment, "fusing", "flattening", hole filling, and other various file-prepping tools. In the mean time, Meshlab and Blender offer these tools, and can be used to make printable files from point cloud data.
Nothin' to it but to do it!
First: let's just open the file in blender and isolate some patches to see what we are working with. tab gets you into edit mode for the selected object. a deselects everything. c or b can be used to do a circle select or border select. Scroll the wheel to change the size of the circle and hit esc when you are finished selecting. shift+h hides all but the selection. alt+h shows everything.
Raw data
So many points.... 1046606 to be specific.
using the border select tool to take a cross-section of the data. Use shift+h to hide everything that's not selected
Face and nose. Can you see the two layers stacked on top of each other?
Isolated section of the nose. There are two surfaces there. Not good!
Top of the head. There is missing data there, but it's not easy to see. It's super easy to get disoriented when working with point clouds, because the backside and the front side look the same and you can see both.
rufu5
Re: How to generate manifold printable .stl's from .ply
Post by rufu5 » Wed Jun 10, 2015 2:14 pm
Now that we have an idea of what the mesh looks like, let's open it in meshlab and start applying some filters.
Note: filters are applied to the selected mesh only. Make sure you have the right mesh by selecting it from the layer dialogue. If you don't see the layer dialogue, then show it using the "view" menu.
File right after import. There is missing data on the top of the head, as you can see.
A view of the lady's face. The different tones are due to the stacked layers and (I think) the different normal directions. That's how it is in blender anyway.
Here is where you find the poisson disk subsampling filter.
This is how I configured the poisson disk subsampling algorithm. Make sure to check the "base mesh subsampling" option since it's not a mesh, it's just a point cloud (obvious, right?).
Original mesh before subsampling
Subsampled mesh. Notice how many fewer points there are when compared to the original.
rufu5
Post by rufu5 » Wed Jun 10, 2015 2:27 pm
So, this reconstruction failed, but I'm going to post it anyway and then try it again. I think that by trying to orient things better for screenshots I may have scaled and translated the model in ways that altered the outcome, or I used too high a octree depth
Where to find the computing normals filter
Settings for computing the normals
Where to find the Poisson surface reconstruction.
Poisson reconstruction with the settings I used.
The result of the reconstruction. Extra data that's a bit weird.
This is what I ended up with using these settings. I think it's usable with a trim and a boolean'd on base. Success?!!?
rufu5
Post by rufu5 » Wed Jun 10, 2015 2:51 pm
This is how you trim and Boolean on a base.
Supplementary info on the Boolean modifier: viewtopic.php?f=8&t=595&hilit=blender+basics
shortcut to selecting the stuff we want to trim
into the trash it goes
Booleans only work very well if the two meshes are manifold, so go ahead and check to see that they are with the "select non-manifold" tool. This is one of the strengths of the poisson surface reconstruction approach -- it usually gives manifold results.
overlay of the original ply and the reconstructed .stl from the previous step
Using the original .ply as a reference to line up a cube to union on.
Union'd base
rufu5
Post by rufu5 » Wed Jun 10, 2015 3:19 pm
So I ran through the same process with the octree depth set to 8 instead of 10 in the poisson surface reconstruction, and got results that didn't need to be trimmed, just needed the normals flipped and the base trimmed off a bit to give it a nice flat footprint for printing.
So that's all folks, if anyone posts some files they are trying to print, I'll try to help out. Part of what makes this process tricky is that the optimal parameters for these filters are completely application and geometry dependent. I personally prefer doing it manually this way (rather than having a all-in-one package that does it for you) because I have *complete control over what the final geometry looks like, rather than having to just go with whatever the native software spits out (if it spits out anything at all). That being said, many users *will probably want that for ease of use purposes. I think the best case would be to have both options.
Result of the reconstruction with the octree depth set to 8 instead of 10. The darker color means we are looking at the back of the faces -- the normals are inverted.
normals flipped the right way and the bulge left over from the surface reconstruction that we want to get rid of.
Adding in the cube to boolean difference off the bulge on the base
do-it-for-science-
Post by do-it-for-science- » Wed Oct 07, 2015 8:53 pm
this is some really good info thank you for the post! I am printing out the parts to make a piclops and this is exactly the sort of thing I was looking for on how to deal with the point clouds!
open source, open heart,
Jeff Hunt,
Renewable Energy Engineering student OIT
