Any reason this graphic smart lcd controller wouldnt work?
A forum dedicated to those intrepid few, that have built their own TAZ 3D printers using our KITTAZ.
PhoenixWRX
Post by PhoenixWRX » Fri Feb 20, 2015 7:42 pm
I'm tired of using a crappy old netbook and printrun to drive my printer and would like to get the graphic lcd controller and run off an SD card but paying $70 is way too much.
Would this work?
http://www.amazon.com/Sintron-Graphic-D ... +Smart+LCD
I assume I would need the RAMBO adapter:
http://www.amazon.com/Geeetech-Controll ... controller
Any other options that arent really expensive?
mhackney
Contact:
Re: Any reason this graphic smart lcd controller wouldnt wor
Post by mhackney » Fri Feb 20, 2015 9:41 pm
Yes, it will work and I can't imagine finding a graphic controller for less than this. The board in the Amazon page even has the RRD name, URL and full graphic smart controller stenciled on it. I suppose there is some risk that the board is not compatible but they do link to a private Marlin distribution that has support so there would be enough "documentation" there to get it to work if required - provided you have the knowledge and time to do that if required.
BTW, the RAMBo adapter makes connecting A LOT easier. Before this device existed we would have to wire the glcd manually and that as painful.
cheers,
Michael
Sublime Layers - my blog on Musings and Experiments in 3D Printing Technology and Art
Start here:
A Strategy for Obtaining Great Prints
Strategies for Resolving Print Artifacts
The Eclectic Angler
jebba
Site Admin
Post by jebba » Sat Feb 21, 2015 1:06 pm
Our cabling is way better, just sayin'.
mhackney
Contact:
Post by mhackney » Sat Feb 21, 2015 2:21 pm
I agree jabba, way too many projects start out to be "budget" and ended up taking 2-3 hours or more to compete. I value my time greatly but let's say you value your time at $20/hr. It would be much more cost effective to purchase the purpose built product. And even more so in cases like this, I really dislike wiring!
Cheers,
Michael
Start here:
The Eclectic Angler
Orias
Post by Orias » Mon Feb 23, 2015 8:28 am
The adapter shown in the product listing photo will only work on a RAMPS electroncis (AO-100, most DIY 3D printers used this kind of board), not the RAMBo electronics (All TAZ).
RAMPS electroncis adapter information:
http://reprap.org/wiki/RepRapDiscount_Smart_Controller
For RAMBo electronics you'll want to use this:
https://ultimachine.com/content/lcd-sma ... -kit-rambo (Great vendor, but they're out of stock currently)
http://reprapelectro.com/product/rambo- ... d-adapter/
Source:
https://github.com/ultimachine/RAMBo/tr ... oSCadapter
mhackney
Contact:
Post by mhackney » Thu Mar 05, 2015 1:53 pm
Just FYI...
I ordered this exact Sintron unit from Amazon. I had double checked the firmware (link on amazon site) and the schematics with the RepRapDiscount version. They appear identical, there were no differences in firmware or pins on the connectors.
It came in today and I hooked it up to my mini kossel that has a working GLCD connected. The Sintron unit did not work. I also tried it on 2 other printers with known working RRD GLCDs on a RAMBo board running Marlin, Smoothieware board and a X3 Pro board running Repetier. It didn't work anywhere, just a flash on startup, a beep and a blank screen. I double checked the published schematics. I also, for grins, tried the supplied Marlin firmware on a RAMPS board with the RAMPS connector. It did not work.
I am returning it and I notice now that they are out of stock. A quick search on google shows that Sintron has a horrible rap on eBay and their shop was been closed in the last month or so.
Spare yourself the pain! Finding an original RRD GLCD in stock is a bit of a challenge but can be done if you look around.
Start here:
The Eclectic Angler
do-it-for-science-
Post by do-it-for-science- » Tue Apr 21, 2015 12:12 pm
man, I wish I had known that even the reprapdiscount smartlcd controller did not come with the adaptor appropriate for the RAMBo. I guess I wait another two weeks... :|
open source, open heart,
Jeff Hunt,
Renewable Energy Engineering student OIT
do-it-for-science-
Post by do-it-for-science- » Sat May 09, 2015 5:40 pm
just an fyi, I bought that RAMBo to Smarcontroller adapter 1.0a from ultimachine that is linked to in this post and it was NOT the correct adapter for the full graphic LCD controller. I know this seems obvious now, but if your in a rush, don't just click on the link and buy.
as far as I can tell no one currently sells any adapter.
Jeff Hunt,
do-it-for-science-
Post by do-it-for-science- » Fri May 22, 2015 11:14 pm
just for completeness I would like to report that I ended up wiring up the harness for the display myself and it works great. I did it based on the schematic posted in the Graphical Smart LCD Wiring Harness item links section. It was not terribly difficult, just nerve wracking and a bit expensive since I had to purchase the special molex crimper (I tried the one I already had and it was a definite no go), and I'm sure you all could do this for yourself. alternately I could do this for anyone else that is looking to get a lcd hooked up to their KitTaz and is frustrated like I was if they tossed a few coins my way :D.
http://download.lulzbot.com/TAZ/3.1/pro ... arness.PDF
Jeff Hunt,
piercet
Contact:
Post by piercet » Sat May 23, 2015 12:34 am
There's also a pictoral step by step instruction set here if anyone needs it: https://ohai-kit.alephobjects.com/project/kittaz-glcd/
