RazzMaTAZZ - my KITTAZ Build
A forum dedicated to those intrepid few, that have built their own TAZ 3D printers using our KITTAZ.
mhackney
Contact:
Re: RazzMaTAZZ - my KITTAZ Build
Post by mhackney » Sun Mar 22, 2015 10:13 am
Great. And don't hesitate to ask questions.
Sublime Layers - my blog on Musings and Experiments in 3D Printing Technology and Art
Start here:
A Strategy for Obtaining Great Prints
Strategies for Resolving Print Artifacts
The Eclectic Angler
KosmoPi
Post by KosmoPi » Sun Mar 22, 2015 10:17 am
what price range should I expect from an ebay us seller on the rods? I am not finding any in stock US or otherwise, and mcmaster has them for $15/each (Seems high).
sain
Post by sain » Sun Mar 22, 2015 11:41 am
KosmoPi wrote:what price range should I expect from an ebay us seller on the rods? I am not finding any in stock US or otherwise, and mcmaster has them for $15/each (Seems high).
I went with McMaster for mine, as I couldn't find any on eBay either (not in 500mm/19") . Wasn't able to find much cheaper and I was also able to pick up a few other parts there aswell.
mhackney
Contact:
Post by mhackney » Sun Mar 22, 2015 11:49 am
I paid $15.each for mine ion eBay and they were 19" long. Perfect for X and Z but 5mm too short for Y. McMaster sounds like a good deal for 500mm rods.
http://www.ebay.com/itm/181479844918
Start here:
The Eclectic Angler
KosmoPi
Post by KosmoPi » Thu Mar 26, 2015 9:46 am
So I have all of the materials in. I am looking to do the upgrade this weekend.
Do you suggest lubricating the bearings/rods? If so, will the same white lithium grease used for the Z axis lead screws work for the bearings?
Also, For anyone's reference, Here are my US based sources:
1. bearings: JSB Bearings in Ann Arbor, MI:
https://www.jsbgreatbearings.com/lm10uu ... dbe9edb2fb
2. hardened steel rods from mcmaster:
http://www.mcmaster.com/#6112k47/=wh825o
3. Stepper Dampers from Ultibots:
http://www.ultibots.com/nema-17-damper- ... y17rmdamp/
mhackney
Contact:
Post by mhackney » Thu Mar 26, 2015 9:57 am
A little light machine oil is what I used.
Start here:
The Eclectic Angler
KosmoPi
Post by KosmoPi » Thu Mar 26, 2015 10:37 am
To answer my own question again. It is definitely okay to use white lithium grease:
http://reprap.org/wiki/Linear_bearing
http://forums.reprap.org/read.php?1,164061,164061
mhackney
Contact:
Post by mhackney » Thu Mar 26, 2015 10:52 am
I still like to use light oil on ball bearing linear guides. Grease is tacky and picks up grime and small particles of filament, etc. It doesn't take a lot of lubricant, just a few drips INSIDE the ball bearing guides and that's it.
Start here:
The Eclectic Angler
KosmoPi
Post by KosmoPi » Thu Mar 26, 2015 10:56 am
Good point, I dont need another place on my printer that can pick up cat hair.
I will probably go with 3 in 1 at Lowe's.
http://www.lowes.com/pd_95564-357-10038 ... facetInfo=
KosmoPi
Post by KosmoPi » Sat Mar 28, 2015 8:52 am
I am starting my upgrade today. I am starting with the Y axis.
question: Did you add dampers to the Z axis steppers as well? Seems like they might be a little more of a pain, but I am saving those for later (doing the Y now).
Also, for now I am using the small screws that came with the dampeners to attach the damper to the motor, then using the Lulzbot screws (2 of the 4) to attach the dampener+motor to the frame. That looks like what you did from the pictures. The black marks on the dampers are facing up (away from the motor). Let me know if that is wrong. Thanks
