Kittaz build on pause.
A forum dedicated to those intrepid few, that have built their own TAZ 3D printers using our KITTAZ.
saramos
Post by saramos » Mon Mar 16, 2015 1:06 am
I purchased my kittaz back in November, and have finally got the chance to start it's assembly. Unfortunately, I hit a pause in the build when I discovered that the holes for the set screws on the belt pulleys are not tapped. I ordered a set of taps which I hope will be in by Tuesday so I can continue on this long long anticipated build.
Scott
mhackney
Contact:
Re: Kittaz build on pause.
Post by mhackney » Mon Mar 16, 2015 7:23 am
Why not contact Lulzbot and have them send you the correct part?
Sublime Layers - my blog on Musings and Experiments in 3D Printing Technology and Art
Start here:
A Strategy for Obtaining Great Prints
Strategies for Resolving Print Artifacts
The Eclectic Angler
saramos
Post by saramos » Mon Mar 16, 2015 10:55 am
I figured that I can get the taps quicker, and it's always good to get new tools
BTW, thanks for sharing your RazzMaTaz!
mhackney
Contact:
Post by mhackney » Mon Mar 16, 2015 11:27 am
I'm a tool monger myself so I know where you are coming from!
Michael
Start here:
The Eclectic Angler
saramos
Post by saramos » Mon Mar 16, 2015 12:07 pm
Well, whataya know?
I took another look at the pulleys this morning. I must have misread the instructions. I assumed that I would be using the 3M setscrews, but the pulleys use smaller setscrews and they are already installed. That means I am no longer on pause, and I have new tools coming too!.
Cheers,
Scott
mhackney
Contact:
Post by mhackney » Mon Mar 16, 2015 12:10 pm
A win-win!
Start here:
The Eclectic Angler
saramos
Post by saramos » Mon Mar 16, 2015 5:10 pm
Today, I ran into another hiccup. I am assembling the y axis assembly, and the rod end brackets which are printed, have brass heat inserts so you can lock the rods in with setscrews. Unfortunately, one of the brass heat inserts was set a little too deep and protrudes into the hole for the rod such that it prevents proper full insertion of the rod. I had to head off to work, so I'll deal with it either tonight when I get home, or in the morning.
I guess this is an example of one of the reasons they give for discontinuing the Kittaz, a loss of quality control. This is the small type of problem that would be found and resolved on an in-house assembled printer, but can slip through the cracks on a kit. I suppose my earlier 'perceived' problem with the setscrew is another. Though these small issues don't detract of my opinion of their products. These are the small type of problems that someone could encounter with any brand kit. Still, it's sad to see another company abandon the kit market.
Cheers
Scott
mhackney
Contact:
Post by mhackney » Mon Mar 16, 2015 5:34 pm
You should be able to push the insert out by using a screwdriver. Insert it in the hole, and lever the brass insert into place.
Ever read the label on a cereal box "some settling may occur"? That can happen here too, especially with cold or hot shipping temperatures.
Start here:
The Eclectic Angler
saramos
Post by saramos » Mon Mar 16, 2015 6:19 pm
Yea, what I had planned on trying tonight is to insert the back end of a drill (the unfluted section) slightly smaller than the 10MM rod, then run a screw into the insert and see if it would raise clear of the shaft hole. Failing that, I planned to then try and heat the insert with a soldering iron and lever it up a touch.
Scott
mhackney
Contact:
Post by mhackney » Mon Mar 16, 2015 6:22 pm
That will work.
Start here:
The Eclectic Angler
