Hi,
So I bought a new Rambo Board for my lulzbot Mini because my X-min and Y-min was triggered and after installed all the connection into the new rambo board now X-min, X-max, Y-min, Z-min are getting Triggered.
What is happening???
Hi,
Sounds like you messed up the connections during the install to your min and max switches or you weren’t grounded correctly and you fried the board. You may want to go over the OHAI instructions and use your old board as a guide.
On the back of your case is a serial number that starts with KT-PR0035NA.
If your last numbers are 07499 and below, use this installation guide: https://ohai.lulzbot.com/project/86510011-df83-408c-a220-1dcf8c5a7262/mini/
Otherwise, use this guide: https://ohai.lulzbot.com/group/mini-v104/
Make sure you follow the directions. There is an order to the the way that the wiring needs to be connected.
